Old 03-30-2013, 05:26 PM   #1
Schlug OP
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
Help Needed:1150 lost headlight, turnsignals, lights in tach and speedo
For the last week or so my turn signals have been acting oddly in that they flash quickly as if a bulb is out, only both front and rear are fine. Sometimes one would flash normally and one would flash quickly, but most of the time they have both flashed quickly.
Today on the way in to work (5:30 AM) , I noticed I couldn't see my speedo or my tach. The lights on the RID are fine, the dash lights work fine (high beam, neutral, etc). As I was riding I could see the red light on the hazard flasher button flickering on and off. It was then I noticed I had no headlamp either. Once I got off the slab, I could see the headlamp flickering on and off as I rode.
When I got out of work I checked the fuses and they are all fine. I have no idea if turn signals, headlamp, and lights on the tach and speedo are on the same fuse or not. As I was mucking about with the saddle off, a coworker came over and watched me. I started the bike and the headlamp and turn signals were working fine, but the flashers were flashing quickly. I hit the high beam button and suddenly they started working normally. But after I started the bike and let it run for a few moments I lost my headlamp and turn signals compelely. I tried turning the bars, bouncing the bike, wiggling all the wiring I could see and nothing happened. On the way home I could see my hazard flasher button flickering again but by the time I reached home I had no lights again and this time nothing I did would make them return.
Any ideas?
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 03-30-2013, 05:31 PM   #2
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,113
loose ground - check hand control harness connectors for corrosion.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 03-30-2013, 06:39 PM   #3
Schlug OP
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
I don't quite understand.
Is there is plug at the switchgear which may have come loose?
Old 03-31-2013, 07:47 AM   #4
Schlug OP
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
let the help pour forth. The Dakar is in bits so I really could use this bike for the commute.
It's been a shitty winter and I've spent far too many hours in the truck.
Old 03-31-2013, 07:27 PM   #5
Schlug OP
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
Okay, GS Addict asked me to switch the load relief relay with the horn relay and see what happened.
Guess what?
I have turn signals, headlamp, and all lights back. No horn, but I suspect that's because the bad relay is now in the horn relay slot and the good relay is in charge of load relief, what ever that is.
I'm electrically challenged. I'm a steamfitter by trade, not an electical engineer.
The only question is whether I can ride like this? I shouldn't see why not. Aside from having no horn, I should be in better shape than I was riding home at dusk with no headlamp, tail light and turn signals.
I see there is a spot for spare relays, I think I'll get one. Or two.
I would like to thank GS Addict for the time he took from his busy schedule to proffer a solution.
Old 03-31-2013, 08:26 PM   #6
k1w1t1m
Kiwi
Oddometer: 912
Be careful. That spare spot you see may be where the CCP goes when fitted. Putting a relay there could affect the way your bike runs.
It's all for Jesus, CMA Faith Riders, Chapter 732
'01 BMW R1150GS
k1w1t1m is offline   Reply With Quote
Times are GMT -7.   It's 09:46 PM.
