Old 04-13-2013, 05:16 PM   #1
Boxer Metal OP
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
Engine Knock Under Load
So I have a motor that once it is warmed up there is an engine knock only under load and it goes away at higher RPM's No noise when cold or at revving the motor at idle. Sounds like a rod. Ideas?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-13-2013, 05:34 PM   #2
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,922
Could it be pinging (sounds like rocks rattling in a can) ...or is it a steady knock knock sound? If so, retard the timing a bit and see if that helps.
Big Bamboo is online now   Reply With Quote
Old 04-13-2013, 05:35 PM   #3
Plaka
Brevis illi vita est
Oddometer: 4,609
Change the oil. Put in strait 30 or 40wt. and see what happens. If it shuts up or it has to get a whole lot hotter before it starts I would suspect a rod. You can also put a pressure gauge on it (pull the idiot light sender, it's m12x1 thread IIRC) and see if the knock happens as the oil pressure drops under load.
Check with a mechanics stethoscope at the cylinder base at idle and reving in the driveway. It may be knocking then but not loud enough to get through years of hard rock and power tools hearing damage.
Also maybe drain the tank into your truck and run some of the highest test gas you can find in the motor. That is diagnostic for detonation type knocks. Or add a can of octane booster to what is in there.
Old 04-13-2013, 06:17 PM   #4
ME 109
ME 109's Avatar
Oddometer: 3,022
Sounds like a rod bearing.
I'd pull the oil filter and dissect it for more clues.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 04-13-2013, 07:04 PM   #5
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,572
Pull it apart for inspection before any further damage is done ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 04-13-2013, 07:29 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,145
I'll third the notion of a rod bearing. Quick check would be to read the oil filter. Is the maintenance/history of the bike known?
--Bill
'73 R60/5 Toaster
Old 04-13-2013, 10:17 PM   #7
Kai Ju
Kai Ju's Avatar
Oddometer: 1,889
What does it sound like in gear, stationary and starting to let the clutch out while you hold the rear brake on ?
If it knocks under those conditions it will likely be a rod versus detonation.
You know well enough how easy it is to verify and if I remember correctly it's usually the right side that let's go first.
If you catch it early enough you can clean the rod journal up with crocus cloth and just replace the bearing inserts.
Do you have any history on this engine ?
Kai Ju is online now   Reply With Quote
Old 04-13-2013, 11:04 PM   #8
supershaft
because I can
Oddometer: 9,116
Inspect the filter? You might find the problem before you pull the filter out. You know? A $2000 O-ring. BTDT a number of times.
supershaft screwed with this post 04-13-2013 at 11:30 PM
Old 04-14-2013, 12:38 AM   #9
ME 109
ME 109's Avatar
Oddometer: 3,022
Quite possibly so. Or not.
The filter may reveal dark secrets, or not.
We want to look in the filter for colours for big end wear, silver and copper iirc?
ME 109 screwed with this post 04-14-2013 at 05:26 AM
Old 04-14-2013, 03:47 AM   #10
pommie john
pommie john's Avatar
Oddometer: 1,477
My money's on a rod bearing being marginal. With cold oil there may be enough oil pressure to fill the gap but it gets noisy when the oil heats up.
As for going away at high RPM, again maybe enough oil pressure or maybe the knock "blurs" into a continuous noise that can't be distinguished as a knock.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 04-14-2013, 05:36 AM   #11
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,549
I have never had a rod knock under acceleration. If the knock happens under light load (i.e. constant speed), or it knocks after the engine warms up when stationary and letting the clutch out with the rear brake engaged - I would pull the cylinders and inspect the rod crank journals. The most daunting part of pulling the cylinders is removing the exhaust if it has not been off in a good while. Inspecting the journals is the only way to know for sure. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 04-14-2013, 06:06 AM   #12
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,700
Can the big ends be accessed by dropping the sump?
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 04-14-2013, 06:13 AM   #13
ME 109
ME 109's Avatar
Oddometer: 3,022
Absolutely.
Have you got a 9" grinder?
Old 04-14-2013, 07:01 AM   #14
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,700
Originally Posted by ME 109 View Post
Absolutely.
Absolutely.
If Santa brings me a plasma cutter the grinder will become my third favourite tool.
5lb sledge with the 4 foot handle is the number one tool in my shed.
Old 04-14-2013, 08:17 AM   #15
Plaka
Oddometer: 4,609
No. You got the cam and the bores for the cam followers in the way. And then the rod bolts face sideways, not down. You wanna get at the conrod big ends you have to go in through the cylinder bore cutouts in the block.
Times are GMT -7.   It's 12:53 PM.
