Old 04-19-2013, 05:29 PM   #1
Half Fast OP
Gnarly lurker
Half Fast's Avatar
Oddometer: 293
Broken tap or drill bit
When drilling or tapping a hole, what are the options for removing a broken drill bit or broken tap that is stuck in the hole?
I just finished a project that involved lots of new threaded fasteners and each time I held my breath thinking "Man, if I break this tap/bit I'm screwed". All went well but what to do if the worst happens?
Half Fast is offline   Reply With Quote
Old 04-19-2013, 05:31 PM   #2
Motomedic
Motomedic's Avatar
Oddometer: 2,468
An EDM (electrical discharge machining) machine is usually the best tool for the job.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 04-19-2013, 07:50 PM   #3
Half Fast OP
Gnarly lurker
Half Fast's Avatar
Oddometer: 293
That's what I was thinking. I was curious to ask if there were any other options but EDM was all I could think of.
Thanks.
Old 04-19-2013, 07:55 PM   #4
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 785
It's a PITA for sure, EDM is ideal solution but generally out of the reach of backyard or home workshop types.
A former colleague always had reasonable success by tapping around radially with a punch if anything was sticking out, but the punch usually gets pretty chewed up.
Another guy that worked with me showed me a trick when we had a tap break off in a mold that was in for a rush job,
We put pins in between the flutes of the tap and kept wiggling it around until it came out, but it required a lot of expletives and angst to finally get it out. IIRC, it may have been old-school bobby pins, but for sure the tap wasn't jammed too bad, but nothing was sticking out either.
Also saw a guy weld a nut onto the protruding piece of broken stud or tap, combination of heat cycle and better leverage worked ok on my brothers diesel rig.
No one size fits all solution though for sure.
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 04-19-2013, 08:09 PM   #5
silverbandit1
silverbandit1's Avatar
Oddometer: 990
I have removed broken HSS Taps with a carbide end mill and I have used a acid product ( available at machine shop supply ) if the tap broke in an aluminum part - otherwise EDM
Save Lives - Spay & Neuter
Those who cannot remember the past are condemned to think "profiling" is worse than the slaughter of innocent people.... In memoriam, 9-11-01
-B.Tinsley-
silverbandit1 is offline   Reply With Quote
Old 04-19-2013, 08:50 PM   #6
Beezer
Oddometer: 5,659
only other one I can add is the cutting torch. if the tap is broken off in aluminum you can blow it out with the ol fire ax. aluminum transfers heat way better than steel so if you heat the steel really quick you can burn it out of the hole with not too much damage to the aluminum, though you will probably need a helicoil. and yes, I have actually done this.
best thing is to not need this kind of anguish in the first place. tap with a good lube, turn in a half, maybe 3/4 of a turn, and then out a quarter, keep the chips cleaned out of the flutes.
as for broken studs... first is a left handed drill, if that doesn't work I try to drill it down the center "on size" , if I screw that up I helicoil it. I really don't even bother with easy outs anymore. a broken ez can be drilled with a cobalt though
Beezer is offline   Reply With Quote
Old 04-19-2013, 09:56 PM   #7
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
I've successfully used a broken tap extractor tool once before. it looks kind of like a socket with teeth that engage the reliefs in the tap.
DaymienRules is offline   Reply With Quote
Old 04-19-2013, 10:15 PM   #8
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,686
Yes! True relief when it works. Patience is very important.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 04-21-2013, 10:11 PM   #9
ohgood
ohgood's Avatar
Oddometer: 2,645
drill the back side of the hole if possible, then whoop the drill bit of tap from there.
once its out, drill and tap next size (or two) up and chinese knurl the back side of the tapped hole.
then heat all thread and force it through, all the way with a little hanging out.
hack off the all thread, both ends.
center punch around the all thread, and the edge of the all thread. a lot.
peen the all thread flat.
file flat ( the edge cuts best and planes )
drill and tap the new hole, mo carefully.
most folks can't spot the repair. ;-)
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 04-22-2013, 07:16 AM   #10
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,342
The broken tap problem lead to the Tapmatic:
http://www.use-enco.com/CGI/INSRIT?PMAKA=317-0726&cm_mmc=Didit-_-SEM-_-GglProd-_-GglProd&003=18299132&010=317-0726&{copy:002}&{copy:004}&{copy:005}&10=317-0726&gclid=CK2G1Zis3rYCFYMWMgodNWAAjg
Which is a wonderful tool if you are tapping many holes (but a bit pricey for the HSM). I have always tapped holes by hand using a guide or adapting a mill for the purpose - with plenty of cutting fluid and judging by hand force taps don't bread - but it is slow.
I think the job would decide how to remove the broken tap. Generally, work is done for profit and time is money so the quicker the tap is removed and threads formed the better. Machine shop forums are a better place to ask this question if you are looking for experience and ideas. YMMV.
Stan_R80/7 is offline   Reply With Quote
Old 04-22-2013, 03:54 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 5,758
A few things about taps:
Always buy and use high speed steel taps. They're ground shiny all over and marked HSS. They're tough and strong. Carbon steel taps are cheaper, but they are hard as glass and brittle and break easily.
Taps do get dull after some use. When this occurs, don't use that tap to cut new threads, especially in aluminum or brass. You can use it to clean gasket sealer and dirt out of a threaded hole. Don't do this with a sharp tap if you want it to remain sharp.
Always use a tapping fluid. Kerosene works well for aluminum. I like Rapid-Tap for ferrous metals. Stainless steel needs a different lube. I've used Anchorlube for many years. It comes in a squeeze bottle and looks like green snot.
Always use a proper tap wrench so no side loading is placed on the tap. Back the tap up every rotation to break the chips off.
15 BMW RnineT
09 Kaw Versys
Old 04-22-2013, 10:16 PM   #12
Half Fast OP
Gnarly lurker
Half Fast's Avatar
Oddometer: 293
This is all great info, thanks. I don't have a specific issue at present. I just wanted a better understanding of what options are available.
This last project involved drilling and tapping in tight spots on a bronze plaque. Some areas there was barely enough room to start and turn the tap. Also lots of odd angles so the risk of breaking a tap or drill was higher than normal.
Here the fastener was under the brim of a hat. I could not access the back of the piece.
(That's a missing canteen strap being replaced on a military monument. Yes, I know it's a simple tig job but if pins were originally used I drill out the old pins and do it the same way.)
I forgot about those tap removal tools. I'm sure, just like screw extractors, they work "sometimes". Still, it's another option to have on hand.
Again, thanks for the ideas- I knew this was the place to ask!
Old 04-23-2013, 12:15 AM   #13
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,290
For that job illustrated I strongly recommend an "extended tap wrench". Not only does the extra length really help, the longer handle makes it a lot easier to keep it in line.
GreaseMonkey is offline   Reply With Quote
Old 04-23-2013, 03:47 PM   #14
Ironwood
Friday Harbor, WA
Oddometer: 747
Cordless drill
I sometimes chuck the tap in a cordless drill with just snugging the chuck. It allows you to get steady pressure and a good angle on the tap. If it gets too tight it will slip in the chuck. And it is much faster as well.
Ironwood is offline   Reply With Quote
Old 04-23-2013, 08:06 PM   #15
Ironwood
Friday Harbor, WA
Oddometer: 747
As long as you don't tighten the chuck, it works well. But I always use a
good cutting fluid.
Times are GMT -7.   It's 09:25 PM.
