Old 05-09-2013, 03:26 PM   #1
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
950 tank venting issue, need help asap
Flapendectomy is done. There were 4" tubes attached to the front tank vents which I replaced with a big loop over the head light to the other side and down over the forks, for each tank separately.
Now I have fuel coming out of the vents when tanks are above half and when hot. Not too much, just dripping a bit.
Leaving to North Carolina tomorrow from Ontario. I dont really dont know what. else to do!!!
Would a T, connecting two vents, help?
04 ADV 950
keener is offline   Reply With Quote
Old 05-09-2013, 04:23 PM   #2
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
didja pinch anything?
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 05-09-2013, 05:01 PM   #3
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
Checked that this afternoon, not pinched.
Where is the bast place for the vents to end up?
04 ADV 950
Old 05-09-2013, 05:35 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,922
The best place is to end up in the protective bellypan.
They come out upwards and then turn downwards inside the side panels, pass between the petcocks and the aluminum panel that bolts to the tanks and end in the belly pan.
Cheers.
Old 05-09-2013, 06:34 PM   #5
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
I've had mine dead end inside the top fairings and are only 12" long or so.
Never had any issues with them other than once when I pinched them by mistake.
Also check your vents on the sides of the tanks as they will create issues if pinched as well.
If you're stuck come by the batcave and I will sort you out
Old 05-09-2013, 08:03 PM   #6
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
Ill check the side vents for pinching too. I thought those are for over flow only.
Departing tomorrow morning.
04 ADV 950
Old 05-09-2013, 09:09 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
run the vents to the skid pan, I can tell you that gasoline soaked riding gear in the middle of a ride in the middle of no where is no fun.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-10-2013, 10:00 AM   #8
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
Thx. On the road now,... Last night i noticed the side tank vent was pinched all right. Im not sure if that has any effect, we will see.
If the problem persists i will take the vents off around the head light and send it down. Not sure how much gas im losing!
04 ADV 950
Old 05-10-2013, 11:29 AM   #9
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
that's most likely it
good luck man
Old 05-11-2013, 10:13 PM   #10
keener OP
Speed changes you.
keener's Avatar
Oddometer: 928
It was! No issue so far. Thx Alex
04 ADV 950
Times are GMT -7.   It's 02:14 AM.
