Old 05-14-2013, 01:49 PM   #1
BadTA OP
BadTA's Avatar
Oddometer: 66
Clutch hard to turn
I am rebuilding my KTM 625 LC4 and am at the point where I am re-installing the clutch. I have put the clutch basket in and then the inner hub. At this point the inner hub turns freely. Now, when I tighten down the hex nut to the specified torque (60 ft.lbs.) the inner hub is now hard to turn.
Any thoughts?
BadTA screwed with this post 05-18-2013 at 12:44 PM
BadTA is offline   Reply With Quote
Old 05-14-2013, 04:42 PM   #2
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,218
Perhaps you're missing some sort of thrust washer behind the clutch hub/basket?
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 05-14-2013, 05:52 PM   #3
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,087
assuming the clutch parts list is the same as the 640, #28 seems to the thrust washer. or lack of. if that is the case, you have tighten the basket on to the thrust brg #32 and now that would be damaged...
or not
shipwrek12001 is offline   Reply With Quote
Old 05-14-2013, 09:30 PM   #4
BadTA OP
BadTA's Avatar
Oddometer: 66
I can confirm that there is indeed a washer (#28) and it does exist in my installation.
Any other thoughts?
Old 05-15-2013, 01:27 AM   #5
Captain115
Captain115's Avatar
Oddometer: 282
Any other thoughts?
Just to double check: you don't have any of the plates in right, its just the inner and outer baskets?
Captain115 is offline   Reply With Quote
Old 05-15-2013, 08:41 AM   #6
BadTA OP
BadTA's Avatar
Oddometer: 66
That's correct.
Old 05-18-2013, 07:38 AM   #7
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
No washer after roller bearing?
Seikkailu_R is offline   Reply With Quote
Old 05-18-2013, 08:49 AM   #8
BadTA OP
BadTA's Avatar
Oddometer: 66
I don't see one either in the manual or in my bucket of parts.
Old 05-18-2013, 08:55 AM   #9
Seikkailu_R
Oddometer: 839
Its part of that roller bearing, not a part with its own number.
Here is some pictures...
Old 05-18-2013, 10:14 AM   #10
BadTA OP
BadTA's Avatar
Oddometer: 66
If you will send me your address I will gladly send you a case of your favorite beer!
Old 05-18-2013, 03:21 PM   #11
Seikkailu_R
Oddometer: 839
No need for that, advices on internet are free...
Times are GMT -7.   It's 02:06 PM.
