Old 05-18-2013, 09:09 AM   #1
ciukes OP
ciukes
Oddometer: 25
KTM 640 LC4 - Loud clicking noise when idle
Hi guys,
Can you help me to identify source of loud clicking noise I can hear when idle?
It goes away if I rev a bit and comes back when engine is back to idle.
It comes from exhaust valves area. Can it be automatic decompression ?
http://www.youtube.com/watch?v=yqmnOkkR4iE
Any idea? Is this something to worry about?
UPDATE:
This is story has a happy ending.
Jump straight to the final chapter if you are in hurry.
http://advrider.com/forums/showpost....7&postcount=21
To Asia and beyond. Low-budget travels on two wheels
mototraveler.eu
ciukes screwed with this post 06-04-2013 at 01:27 PM
ciukes is offline   Reply With Quote
Old 05-18-2013, 10:24 AM   #2
Idle
Oddometer: 719
Is there any metal on the oil screen or the magnet?
It sounds like the valve clearances are too large. If that's the case, the cam follower bearings (CFB's = rocker arm bearings) are suspect.
If you find either intake or exhaust clearances way too big, the valve cover needs to come off to check the CFB's.
When you pull the inspection caps, find TDC and wiggle the rockers up and down. Note how much if any movement there is, then kick the engine over 6-8 times or use the starter to turn it over.
Then find TDC again and do the wiggle test again. If it's different, even a tiny bit tighter or looser than before, the bearings are likely toast.
Idle is offline   Reply With Quote
Old 05-18-2013, 10:33 AM   #3
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Too slow idle and automatic decompressor working?
Seikkailu_R is offline   Reply With Quote
Old 05-18-2013, 11:02 AM   #4
Droptarotter
Oddometer: 1,288
It sounds like it is idling high enough to stop the auto decompressor noise.
Better check your valves and go from there!
If valves too loose.......you might have a rocker bearing going.
Idle nailed it!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 05-18-2013, 02:17 PM   #5
ciukes OP
ciukes
Oddometer: 25
Thanks you all for the advice!
Yes, I found some small bits of metal on the magnet.
I adjusted valves to the expected values.
Damn... looks like this is the case.
I know I should fix it ASAP but... how many more miles I can put on the bike before the engine will give up?
Considering I can do the fix, is it the part #12 on the diagram we're talking about (rocker bearing) ?
mototraveler.eu
ciukes screwed with this post 05-18-2013 at 02:40 PM
Old 05-18-2013, 05:10 PM   #6
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
depends, how much you like your bike?
get it fixed, don't ride it until you do.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-18-2013, 09:22 PM   #7
bmwktmbill
Traveler
Oddometer: 5,205
Don't try to ride it, you can do very expensive damage.
You will have to rebuild the waterpump at the same time most likely if it hasn't been done so prepare yourself for that too....
Think about what will happen if the bearing fails completely, think about metal in your oil and about your roller bearing crank.
Just saying.
You are paying, this is, the price of KTM 640 ownership.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 05-19-2013, 04:14 AM   #8
ciukes OP
ciukes
Oddometer: 25
The story continues...
I removed the cylinder head top. Disassembled the rockers for inspection and found nothing alarming to my eye.
Rollers are tight, surface is even. Visual inspection proves they're not oval.
What do you guys think? Have I done all the checks to make sure rockers are in tip-top shape?
All things together before disassembly
Exhaust valves rocker
Intake valves rocker
mototraveler.eu
ciukes screwed with this post 05-19-2013 at 05:24 AM
Times are GMT -7.   It's 10:11 PM.
