Old 06-20-2013, 12:43 PM   #1
Antigravity OP
Oddometer: 161
Mega Cool New Product-Antigravity Batteries
I am so stoked to introduce Antigravity Batteries latest product. 2 years in development and finally done...
So without further ado I introduce the Antigravity Batteries MICRO-START/PPS (Personal Power Supply)...at a introductory $129.99 price. And yes you can use the "adventure" coupon code as always for a 10% discount.
WHAT IS THE MICRO-START?
The Micro-Start PPS (Personal Power Supply) is the world's smallest Jump Starter and Personal Power Supply (only 6” x 2-7/8” x 1”). The built-in Extreme Power Lithium battery can hold a charge for up to a year and not only will it jump-start any car, truck, motorcycle or powersports vehicle UP TO 20 times in a row, but it can also power or charge ANY and ALL of your Electronic Devices even if your 100's of miles from any power source. Just charge it once throw it in your pocket, purse or backback and your set. It's your personal power supply to take where ever you ride, drive, hike, or whatever...
Weighing less than a pound (14 oz.) and small enough to fit in your pocket, you can take it with you anywhere and remain confident that you will be able to start your vehicle, make that important call, or power your child's PSP on that long trip in the car. It even has a built in flashlight with S.O.S patterns built in! We feel this is one of the most important safety/security devices you will ever buy. In today's world we rely so heavily upon our Cell Phones, iPads, GPS, Blue Tooth Devices, MP3 player and more...the Micro-Start with it's ability to charge all these devices is a device you shouldn't be without.
THE MICRO-START---- WHAT'S ON IT, AND WHAT CAN IT DO?
1.It's the smallest, lightest Jump Starter/Portable Power Supply available:------- only 6” x 2-7/8” x 1”, 14 oz.
2.It can Jump start Cars, Trucks, Motorcycles, ATVs, UTVs, Snowmobiles and Watercraft--- and YES it will jump start your V8 trucks many times in a row!!!
3.It Charges and Powers all electronic devices such as--- Laptops, all Cell Phones, iPads, iPhones, Kindles, PSPs, PDAs, GPS, MP3s, Blue Tooth Devices, Cameras and more
4.It has 3 on-board Power Ports: a 19v for laptops,---------- a 12v standard output for all 12v Accessories,----- - and a USB 5v output for charging or powering ANY 5v USB charded device.
5.It has a HI-POWER LED flashlight with 2 built-in flash patterns including an S.O.S. flashing beacon pattern.
6.It has a lighted battery capacity indicator- Press a button to see the battery capacity left in the Micro-Start
7.It has built-in over-charge and over-discharge protections for long battery life
8.It has an automatic power-off when not in use
The MICRO START XP-1..l WHAT DOES IT COME WITH?
1.Sim-Leather Carry Case
2.Micro-Start XP-1 Unit
3.Detachable Mini Jumper Clamps
4.1 Black Universal Cable with 8-different detachable tips to fit all the different brands of Laptop charging ports (Apple, Acer, Dell, HP, Asus, and more)
5.1 black Universal Cable for all 12v Accessories such as Mobile DVD players, or other 12v Accessories
6.1 White Univerasal USB Cable with 8 different detachable tips to fit all 5v USB chargeable electronics such as all Cell Phones, iPads, iReaders(Kindles), PSPs, GPS, tablet computers, and anything else using the 5V USB standard
7.1 Home Charger
8.1 Mobile Chager for plugging into cigarette lighter socket
SPECS
1.200 Amp- 400 Peak Amp Jump Starting ability
2.14 ounces
3.6" long x 2.8" wide x 1"tall
IF you are not blown away by the product we will refund you without a question.That is how cool we think it is...
Thanks for reading...If you have questions you can also email us at info@antigravitybatteries.com
http://antigravitybatteries.com
The smallest, lightest and most POWERFUL batteries
Antigravity screwed with this post 07-29-2013 at 08:49 PM
Antigravity is offline   Reply With Quote
Old 06-20-2013, 01:30 PM   #2
jphii
OK, now what?
jphii's Avatar
Oddometer: 1,979
That is unreal. Nice!!
jphii is offline   Reply With Quote
Old 06-20-2013, 04:20 PM   #3
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,478
Sweet. How many amps on the 5 and 19v output?
All we need now is an 100W inverter built in and we're set.
Which Acer port do you supply? There are a few and with the popularity of the tables like the Iconia W510 (12v though) and no DC adapter, there is a demand for something like this.
tmotten screwed with this post 06-22-2013 at 05:34 PM
tmotten is offline   Reply With Quote
Old 06-20-2013, 05:59 PM   #4
Antigravity OP
Oddometer: 161
All we need now is an 100W inverter built in and a 12v out and we're set.
19v Port is a 3.5 amp Output-It will give about 2-3 hours of extra run time on a lap top, or will charge it about 1/2 way... but it does depend on the laptop model and screen brightness and so on...
12v Port is a 2 amp Output- Power most electronic accessories well that are 12v. Mobile DVD players and that sort of stuff.
The USB 5v is a 2 amp output. It chargers the iphone fairly quickly, it will charge an iphone 4 about 7 times if used just for that.
In one pic I saw the Iconia using the typical Acer with yellow tip... if its that tip it works because I use it on my laptop. But I'm not sure about the but basically if you buy a universal laptop charger kit these are the same tips...
For the USB 5 volt is 8 tips which basically cover literally about 500 phones and electronics.
Old 06-22-2013, 05:34 PM   #5
tmotten
tmotten's Avatar
Oddometer: 2,478
Note to self, need to read better even hungover re. 12v.
This is what the tablet (12v @ 1.5A) uses which apparently the same as the EeePad TF101 TF201 SL201.
There is a USB cable that has this tip. Trick is to feed the 12v power through a USB connector.
http://www.amazon.com/Asus-Charger-C.../dp/B007GJR7GS
tmotten screwed with this post 06-22-2013 at 05:59 PM
Old 06-23-2013, 08:17 AM   #6
Antigravity OP
Oddometer: 161
Hey Tmotten,
I understand you are saying the Eeepad needs a 12v output ... but the fact is that they sell a USB charge cord (as you linked to on amazon) for the EeePAD would tend to disagree with your assessment...
Here is the reason... you cannot have 12v going out of a USB port. It is industry standardized at 5v for the specifications. There is no such thing as a 12v output USB port. Asus would not do anything contrary to industry standards nor would any electronics maker. So, IF the EeePad even has a USB cord that is made for it which is does... (http://www.amazon.com/Asus-Charger-Cable-EeePad-TF101/dp/B007GJR7GS)... I would then jump the conclusion that it can be charged by the USB standard of 5v. Furthermore it would be horrible if Asus made the only tablet that could not be charged by a USB cable which is also the standardized method of charging tablets and cell phones....
I think it can be charged by the 5 volt standard USB... if it was only able to be charged by a 12V it would have that proprietary tip going into a ROUND tip because that is a standard for 12v outputs too, though they have different sizes...I would suggest you buy that cable they sell on amazon and test this out... you would need that cable regardless for ease of charging on the road eitherway... I just has to be as I said because it just wouldn't make sense for Asus to get contrary to the entire industry.
Old 06-23-2013, 10:03 AM   #7
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Sweet!
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 07-28-2013, 01:13 PM   #8
Captdan
Oddometer: 196
Originally Posted by Antigravity View Post
I am so stoked to introduce Antigravity Batteries latest product. 2 years in development and finally done... We are accepting pre-orders now and expect to ship on or before July 1, 2013. You will not find the new "Micro-Start" on our main Antigravity website (site being updated for the official release), but we did put it on the Shopping Cart website for pre-orders.
http://shop.antigravitybatteries.com/micro-start-xp-1/
The Micro-Start PPS (Personal Power Supply) is the world's smallest Jump Starter and Personal Power Supply (only 6” x 2-7/8” x 1”). The built-in Extreme Power Lithium battery can hold a charge for up to a year and not only will it jump-start any car, truck, motorcycle or powersports vehicle OVER 20 times in a row, but it can also power or charge ANY and ALL of your Electronic Devices even if your 100's of miles from any power source. It's your personal power supply to take where ever you ride, drive, hike, or whatever...
2.It can Jump start Cars, Trucks, Motorcycles, ATVs, UTVs, Snowmobiles and Watercraft--- and YES it will jump start your V8 truck EASILY and many times in a row!!!
7.1 Home Charger
SPECS
2.14 ounces
Does anyone have one of these? Any reports?
1965 Cushman super silver eagle, 1968 BMW R-60/2, 1974 R-90/6 cafe, 2008 R-1200 GSA.
Captdan is offline   Reply With Quote
Old 11-05-2013, 04:48 PM   #9
garandman
Wandering Minstrel
Oddometer: 6,253
I bought one and thought it so cool I ordered another one to donate at a charity fundraiser.
But the case blows. When you open it the zippers get jammed to the stops. The adapters for laptops don't fit the elastics and fall out. I think I'm just going to buy a plastic bin and put all the loose piece adapters in a ziplock.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman screwed with this post 11-08-2013 at 12:47 AM
garandman is offline   Reply With Quote
Old 11-08-2013, 03:14 PM   #10
garandman
Wandering Minstrel
Oddometer: 6,253
Please comment.
Originally Posted by RandyO View Post
those jumper clamp wires don't look up to the task of handling the amperage they claim is available for jump start, I've seen heavier gauge melt
Old 11-11-2013, 01:19 PM   #11
garandman
Wandering Minstrel
Oddometer: 6,253
Bump.
Old 11-16-2013, 08:14 PM   #12
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
As soon as the HD SAE connectors are available will be getting a Micro-start. Keep us posted!
Sent from my Nexus 7 using Tapatalk 4
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is online now   Reply With Quote
Old 11-18-2013, 10:16 AM   #13
dallasdrz
Oddometer: 52
Wink iPad
I want to get one for my wife's ipad .
How long would it take to charge an iPad and what about continuos
Use while plugged in?
2001 Drz400e (sold)
2008 Beta450rr (rfs)
dallasdrz is offline   Reply With Quote
Old 11-19-2013, 06:19 PM   #14
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 4,701
Brought the micro start to an event this weekend. Got to use it twice. Both times it worked like a charm. First was a cold blooded 950SE (not mine ). Fired right up. The second was for a Husky. Tried several times but something was up with the electrical system and the Husky just wouldn't stay running. Not the fault of the micro start.
The only issue I had was the clamps. They are surrounded by plastic and were next to impossible to clamp on to the terminals. Ended up just pressing the clamp to the negative terminal on the Husky. I think they are designed that way to prevent accidental shorting but perhaps different length leads would be better with a bit less clamp thickness.
Otherwise it worked as advertised!
[ this space for rent ]
loph917 is offline   Reply With Quote
Old 11-20-2013, 06:14 AM   #15
mefly2
mefly2's Avatar
Oddometer: 1,228
Longer leads would generate more resistance / heat upon use.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Times are GMT -7.   It's 06:58 AM.
