Old 06-30-2013, 02:41 PM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
Wilbers-BMW: 0-1
My Wilbers failed real bad today. No luggage, no warning: Suddenly my GS was a low-rider.
Fortunately the speed was low.
A friend went to my house, found the old shock on the attic, and brought it out in Chianti were I was stranded.
I carry enough tools to replace it on the side of the road.
I am happy to tell you we had a outstanding lunch prior to this failure, so it was still a good day.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 06-30-2013, 04:14 PM   #2
Joeboxer82is
Oddometer: 26
Thank god u're ok. Lucky u were not riding fast. It's weird how a shock like Wilbers can break just like that. My Ohlins is 4hrs away from it's 1st servicing/rebuild as e seals are gone. Anyway i think u should show Wilbers e broken rear shock of theirs!
Joeboxer82is is offline   Reply With Quote
Old 06-30-2013, 04:17 PM   #3
Swinefahrt
RooteR
Swinefahrt's Avatar
Oddometer: 579
Tagesk, I remember you having rear drive issues and now this!
'07 GS
If its got tits or wheels, it'll give you problems!
Swinefahrt is offline   Reply With Quote
Old 07-01-2013, 04:52 AM   #4
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
This was the situation as we came to a halt. The steel rod broke, it seems, and the spring then slid off the stud.
Here, the swing-arm is pointing down as the wheel has been removed. When we were on the bike, the spring was resting on the swing arm.
We were riding on normal tarmac when it happened at abotu 50 km/h; no luggage!
I think the damping went first; we passed over a bump and I really felt like in an American car (no offense!). We went up and down two or three times.
Then the crack of something breaking, and the rear and fell at least 10 cm and the wheel banged up underneath the seat.
I'll see if I can find info about Wilbers and ask if they want the remains.
Now - a new shock is 850 euro. A 2008-9 BMW R1200GS Adventure is 10.000 euro. Look at those numbers and think about it.
Speaking of FD-failure: I have had four so far.
[TaSK]
IBA: 33616
Old 07-01-2013, 05:26 AM   #5
kinkster
kinkster's Avatar
Oddometer: 117
wilbers
[TaSK]
It will be interesting to see if Wilbers will come to the party!
Glad you are OK though.
What did you think of the wilbers before the failure?
www.galwayhouse.com.au
kinkster is offline   Reply With Quote
Old 07-01-2013, 05:57 AM   #6
fred flintstone
fred flintstone's Avatar
Oddometer: 525
WoW! Does the lower mount (still attached to the swing arm in the pic) still swivel or is it frozen? Some Ohlins failures were attributed to that seizing up.
Glad you are OK this could have ended badly.
fred flintstone is offline   Reply With Quote
Old 07-01-2013, 12:37 PM   #7
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
[FONT=Verdana]
Wilbers say in an email today:
Of course, a shock must not break. I would ask you to send us the defective shock. You have written that your shocks got a regular service.
Please send us copies of the service work.
When the shock arrived, we check it directly.
We'll see.
The shock has worked very well, and after rebuild it has been like new every time.
[TaSk]
IBA: 33616
Old 06-30-2013, 04:16 PM   #8
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Whoa, glad you're ok. Were you riding offroad at the time?
Hopefully you were able to have a nice chianti while you waited
EJ_92606 is offline   Reply With Quote
Old 07-01-2013, 09:53 AM   #9
Okie Preacher
Okie Preacher's Avatar
Oddometer: 864
The man has his priorities straight!
Okie Preacher is offline   Reply With Quote
Old 07-02-2013, 08:45 AM   #10
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
The Wilbers is a few millimeters narrower. This means that over the years the bushing inside the swing arm has moved
to the right (making the gap narrower.
To get the original shock back on I needed to push it back; the question is: How to do so road-side?
Use the upper bolt from the shock, add one of the cones from the wheel bolts, and press it back.
Works well!
[TaSK]
IBA: 33616
Old 07-03-2013, 03:30 AM   #11
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
nice work!
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 07-04-2013, 12:12 PM   #12
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,063
Thank you VERY much for pointing this out. I was pulling my Wilbers for a rebuild and putting the stock parts back and couldn't get the BMW shock back in. I remembered that you just posted this and voila, by using your suggestion the problem was solved!
By the way.... www.motorglobe-wilbers.it will rebuild both shocks for 205.00 Euro including shipping.
Works well!
[TaSK]
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
walrond is offline   Reply With Quote
Old 07-11-2013, 11:30 AM   #13
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 250
Seen this?
The difference between theory and practice practically is larger than the difference between theory and practice theoretically.
BMW Airhead -> www.zeebulon.de/bmw
BMW R1100GS -> www.zeebulon.de/R1100GS
XT 500 -> www.zeebulon.de/xt
Basic_Gerd is offline   Reply With Quote
Old 07-22-2013, 02:57 AM   #14
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
Thumb
Ladies and Gentlemen,
May I be so bold as to decleare Wilbers, by their representative Triple Tuning, to this years winner of Customer Service.
The paperwork simply says "Guarantee" (in German, obviously).
I shipped the broken shock to them, attaching a letter describing what had happened, and the service history.
As the shock had 200.000 km on it after six years of service, I did not make any demands. Not for a new shock, not for a free repair, nothing.
Still, Wilbers stepped up to their product, and I have in my hand a new shock.
I am humbled by Wilbers.
[TaSK]
IBA: 33616
Old 07-22-2013, 07:46 AM   #15
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,763
[TaSK]
So the days of manufacturers standing behind their products are not entirely behind us? Fantastic!
I can't help but wonder though, if the fact that the problem was posted on this forum, affected BMW's decision to send you a new shock.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Times are GMT -7.   It's 09:28 AM.
