Old 07-11-2013, 10:33 PM   #1
baachor OP
Oddometer: 65
XR650R fires when cold
Hi,
I bought this bike recently and it starts having issues when starting. It fires in low RPM and engine even shots off when I rev it bit while warming up. It actually died on me on STOP sign today.
What could be the problem?Things I changed:
- I'm using 91 gas. (not sure what original owner used)
- There used to be this terrible "peace of nothing" instead of original backfire screen in air box,and original foam.
(so I put in backfire screen from XR's only and UNI) I have tried to put in back original peace of s*** with stock foam and still fires.
- Changed spark plug but it did it before anyway
Also I found there is this inline fuel filter instead of one in tank.
Or could it be higher humidity we have here in California now?
Or do I need to adjust needles? (haven't wholly cleaned carb yet,just cleaned it bit on bottom-no dirt)
Rest of RPMs are fine when I ride,it's mainly low RPM.
Stock carb
T4 pipe
Half choke
It doesn't start easy (even previous owner had trouble),maybe it's just me
baachor is offline   Reply With Quote
Old 07-11-2013, 10:47 PM   #2
cognugget
cognugget's Avatar
Oddometer: 243
Originally Posted by baachor View Post
Hi,
Stock carb
T4 pipe
Half choke
what jets. Mine takes 1 kick full choke then 1 kick half choke to fire when cold.
Plated XR650R
cognugget is offline   Reply With Quote
Old 07-12-2013, 12:13 AM   #3
sintax
Oddometer: 495
After having my XR for a few years I'll start this one off...
Any new XR should have the following done.
1) check and adjust valves
2) detail strip and clean the carb thoroughly. Ensure all jets are clean, ALL passages clear. Measure float level, adjust if necessary. Record all jet and needle settings.
Once the above had been done report back and we can talk. It's a big crap shoot until the above is done.
Best of luck
sintax is offline   Reply With Quote
Old 07-12-2013, 12:14 AM   #4
sintax
Oddometer: 495
Oh and also confirm if you are running the restricted carb manifold...
Old 07-12-2013, 02:53 PM   #5
baachor OP
Oddometer: 65
Hi Sintax,
I'm going to clean all right now. I did valves yesterday again and seems like one of exhaust valves were too tight with no free play.FIxed that.Going to check it again just in case.And will post all details you wanted.
Best of luck
I don't know what that means.Sorry I'm new at R.
Old 07-12-2013, 03:06 PM   #6
sintax
Oddometer: 495
Hi Sintax,
Good man! make sure its spotless.
For the XR there were 2 intake manifolds produced. One that was used on smog equipment bikes are "restricted" they have a smaller intake size where as the HRC part, is opened up and has much better flow. This is a normal upgrade done during the "uncorking" procedure.
Here is a pic of the restricted...
And here is the unrestricted....
BTW, where in SoCal are you? I'm in Riverside.
Old 07-12-2013, 03:34 PM   #7
kubiak
Oddometer: 4,829
If you still have the problem check your stator or excited coil thingy. My xr600 did the same thing and I put a new stator Assy in and back to one kick starting hot or cold.
Old 07-12-2013, 06:29 PM   #8
baachor OP
Oddometer: 65
Hi sintax,
it took me extra time as I couldn't unscrew the link arm screw,had to use Dremel (gotta need new screw in there)
So here we go:
1. manifold is unrestricted
2. jets are: pilot 68S, main 170,throttle needle in middle (3th) position,pilot screw in 7 full turns
3. spottles
I live in Costa Mesa. You are close
Thank You for helping,I appreciate it!
kubiak,
I'm actually in process of getting rewound one from BD as it is stock stator
So that would fix that if it is the issue.
Thanx
baachor screwed with this post 07-12-2013 at 06:52 PM Reason: fix
Old 07-12-2013, 08:33 PM   #9
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,057
Question? I got a new stator, no rewind.
If you send one in for a rewind do they check the windings for the ignition? Or do you get the same one back with new lighting coils and your old Ignition coils?
Sent from my DROID RAZR HD using Tapatalk 2
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr is offline   Reply With Quote
Old 07-12-2013, 08:39 PM   #10
baachor OP
Oddometer: 65
I'm not sure. Good question. Might call them up and find out. They are closed for weekend. BajaDesigns
Old 07-12-2013, 08:56 PM   #11
kubiak
Oddometer: 4,829
Im not sure on that one but i bought the new stator from ricky stator and it came ready to bolt on with new windings and two new exciter coils. the exciter coil is what went bad on my xr. my stock xr stator had one exciter coil and i got the new one in the mail and it had two on it. i called them and they said bolt it on its the updated one. so i did and it was perfect.
Old 07-12-2013, 08:57 PM   #12
kubiak
Oddometer: 4,829
my xr i did this on was a 89 xr600.
Old 07-12-2013, 11:22 PM   #13
baachor OP
Oddometer: 65
still researching .)
what it means "fuel screw out 1 1/2 to 1 3/4"?
also I remember I accidentally moved nut on needle jet holder while cleaning it first time few days ago,which could mess it up??? (reading it at the end of that link thread)
enough for today
any idea on what is that rusty tiny piece I found?
Old 07-15-2013, 09:49 PM   #14
sintax
Oddometer: 495
Just one more thing i'd like to add to this....
If the gas in the tank is older than 2 weeks, just drain it and put it into your car.
I just spent about 8 hrs troubleshooting a similar problem, bike just ran shitty. Did the same drill I sent you to do 2 times.
Ended up being 4 week old gas.... Bike would hardly run on it. Drained, put fresh fuel in and it ran great.
Life lessons folks.
Old 07-16-2013, 07:52 PM   #15
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,370
Yes better mpg less chance of overflow. There are oyher reasons im sure. All I know is the guru's say to set it at 18mm
Sent from my phone while swerving over the road in my car
Sean-0 is offline   Reply With Quote
Times are GMT -7.   It's 08:31 PM.
