Old 08-06-2013, 06:49 PM   #1
timbo45 OP
timbo45's Avatar
Oddometer: 174
Rottweiler air filter
Who has used the Rottweiler air cleaner on their 990 Pros and cons please
timbo45 screwed with this post 08-06-2013 at 09:40 PM
timbo45 is offline   Reply With Quote
Old 08-06-2013, 07:24 PM   #2
DuctTape
Oddometer: 351
Runs like a raped ape and the air filter can be removed and cleaned without removing the tank....................
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 08-06-2013, 07:30 PM   #3
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,042
20,000 mi. on mine.
Seams to be well made.
I've got the red filter cover, just clean and oil it.
Have not touched the main filter.
Much easier access to the TB's, etc.
Different sound than stock, it's OK.
I've got the remus 2 to 1 the bike has run great with
40 mpg two up, mas o menos.
Twist it, Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 08-06-2013, 09:38 PM   #4
timbo45 OP
timbo45's Avatar
Oddometer: 174
filter
will I have to remap at 5000 ft
Old 08-07-2013, 12:08 AM   #5
Ryno041
racer -> adventurer
Ryno041's Avatar
Oddometer: 71
Get it
Have it, love it. He can help with remapping too
2013 KTM990, 2014 KTM690R, 2004 XR650L
2003 XR650R, 2007 WR450, 1987 TT350, 2004 TTR225
Ryno041 is offline   Reply With Quote
Old 08-07-2013, 04:52 AM   #6
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
I've got one, I like it, seamed high to buy at first, but now worthe the monies.
I have an 07, what are you guys doing for maps for 07/08??
Rottwieler only list later model bikes....
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 08-11-2013, 08:47 PM   #7
turdfergeson
Oddometer: 40
Re-map
I've been running mine for 2500 miles and love it. I used the map that's downloadable from their site:
http://www.rottweilerperformance.com...Map_Infos_.hex
My normal riding is from sea level to 4000 ft. This weekend I rode up to Kennedy Meadows and was on trails up around 9000+ ft and the bike ran perfect.
I personally love the sound but I know there some that don't dig the "bark". Off road the engine/exhaust noise has a lot to do with how I ride so this air filter with exhaust baffles removed is great combo for me.
(FYI, the front block-off plate is a bitch to install.)
2013 990 Adv Baja
turdfergeson is offline   Reply With Quote
Old 08-12-2013, 05:07 AM   #8
alongat
alongat's Avatar
Oddometer: 1,206
Has anyone run this on a 990R (or any newer 990 with the "R power rating") with Akras and the Akra map from KTM?
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 08-11-2013, 07:06 PM   #9
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 776
two cents
My ran like a cheetah. Sounded like an industrial vacuum. Stock Hp isplenty. Ditched it.
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 08-12-2013, 12:47 PM   #10
boat.man
Chief bottle washer
boat.man's Avatar
Oddometer: 170
Runs like a stabbed rat!
07 990 with akra pipes and map no 02 sensors
Only getting low 30's MPG am looking into a custom map or something? CPR do you have any 07 maps coming?
When I read about the evils of drinking, I gave up reading.
07 KTM 990 Adventure
06 TE610 Sold
2 sleds
lets go play!!
boat.man screwed with this post 08-12-2013 at 07:43 PM
boat.man is offline   Reply With Quote
Old 08-12-2013, 04:27 PM   #11
spencergt66
Oddometer: 795
07 990 with akra pipes no 02 sensors
Seams to work better with the o2s on for me im still getting mid to high 30s from 39-41 stock and way more power
spencergt66 is online now   Reply With Quote
Old 08-12-2013, 05:46 PM   #12
renogeorge
Oddometer: 1,389
Spencer, what pipe setup and map are you running with the Rottweiller?
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 08-12-2013, 07:43 PM   #13
spencergt66
Oddometer: 795
2-1 exhaust wings NOS no Baffle. Using the Akro Ti slip on tune straight from the Tune ECU site Canistorectomy done SAI turned off o2 sensors on. CPR intake with filter skin and super duke trumpets. Fresh fuel filters and injectors haven't had an issue. Has a bit of a rpm transition around 3500 buy off road is usually doesn't go below 4 or 5 so I have to to and look for the issue to notice.
I have tried several other tunes but haven't had any success to any great extent. for me this seams to work the best everywhere i have taken the bike (sea level to 6000ft) no coughs studders or issues to speak of with a minimal loss of MPG. As mentioned before I was getting 39-41 I now get 37-39.
I will say with the stock mapp once I started the bike the exhaust almost instantly started glowing red I had been messing with the bike for other issues so I had tried 100 different mapps and adjustments in the midset I put the CPR on since the bike was down. Once all the issues were fixed (not related to intake) from the bad batch of fuel I got I put everything back to almost stock (no SAI or canistor). Once he bike fired as mentioned previously it went straight to Chernobyl mode, I had to switch to the Akro Ti slip on map left o2 sensors on (read that in a previous post on here some where) and with this set up the bike has never run better.
Use to be in 2nd gear roll on throttle the front end would loft slightly maybe carry it for a bit now roll on 2nd gear the bike will flip over if your no careful. I know its not a real scientific or perfect output comparison but the increase in HP is vary noticeable. Actually the bike runs smoother and crisper then before with the previous set up, 2-1 fmf Q stock intake and OE map or modified map o2 on or off SAI on or off akro map or tweaked never seamed right this does
Hope that helps
Old 08-12-2013, 08:15 PM   #14
timbo45 OP
timbo45's Avatar
Oddometer: 174
I need the resister plug for canostraphy
Im doing the filter and the canostraphy but I cant find the plug with the resister in it where can I get this plug
so the FI light wont come on.
Old 08-12-2013, 08:18 PM   #15
renogeorge
Oddometer: 1,389
Thanks man!! That is near my setup (2 into 1 FMF with SA) and I believe I will start with your map and settings and try some customization with the Tune ECU. If I come up with anything useful, I will share...
KTMs--300, 518, 990
Times are GMT -7.   It's 08:24 AM.
