Old 08-13-2013, 03:53 PM   #1
meijer's trails OP
meijer's trails's Avatar
Oddometer: 481
what size are suzuki dr400 almunimum gascap threads
I have 3 thread peaks. Across 5mm exactly. Like first peak at 0, second 2.5,3rd at 5 mm.
Is that a 2.5mm pitch?
I think its a 50mm dia
meijer's trails is offline   Reply With Quote
Old 08-13-2013, 04:53 PM   #2
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
correct. metric pitch is measured distance between peaks in mm. also, if you have a thread that is metric, but too fine to measure easily peak to peak, measure how many peaks in 10mm, and divide by that amount. i.e. your threads 10mm = 4 peaks, 10/4=2.5
current bikes
stainlesscycle is offline   Reply With Quote
Old 08-13-2013, 07:43 PM   #3
meijer's trails OP
Oddometer: 481
Thanks stainless!!
Any ideas about thread diameter its either 49 50 or 51 on the 1980 Suzuki dr400
I don't have appropriate wires for thread measurement
Old 08-15-2013, 03:20 AM   #4
stainlesscycle
Oddometer: 2,261
Originally Posted by meijer's trails View Post
Thanks stainless!!
i have no idea as to the diameter. i could only guess 50, as 49 and 51 would be strange numbers for metric stuff - usually goes by even numbers in thread diameter (except the dreaded 7mm)
current bikes
Old 08-18-2013, 08:25 AM   #5
meijer's trails OP
Oddometer: 481
Stainless, did you see that puch mx175 on eBay in Lansing mi? Its right b me.if you need me pick that up for you.
Anyway, Is there any chance that the dr400 could have an s.a.e. gascap thread?
Old 08-18-2013, 09:39 AM   #6
Twin-shocker
Oddometer: 1,673
Threads in tanks are often buttress type. This is pretty much always the case if a plastic fuel cap is used on alloy tank.
Old 08-18-2013, 12:08 PM   #7
stainlesscycle
Oddometer: 2,261
i saw it - i have enough of them at the moment
could be sae, could be national pipe thread. who knows.
current bikes
Old 08-14-2013, 04:13 AM   #8
ohgood
ohgood's Avatar
Oddometer: 2,726
http://mdmetric.com/tech/tic1e.htm#measproc
Good stuff
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 08-21-2013, 04:39 PM   #9
stainlesscycle
Oddometer: 2,261
is there a mc junk yard near ya? i'd be bringing my tank over there and checking caps. i'm assuming there are no dr400 caps anywhere to be found?
current bikes
Times are GMT -7.   It's 11:58 PM.
