Old 08-23-2013, 08:50 PM   #1
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Question KTM 990 Adventure Problem With Ralenti
Hi Everyone!
I am new in this page and I wanted to start posting with a different topic, but my anxiety grew stronger than my patience.
Last friday I left my KaTy M. in the garaje, aproximately 30 km before gas reserve signal. Wednesday I came back to ride it but the bike was very hard to start. If i gassed it, it ran, but she could not sustain the engine running at ralenti, at 1500 RPM.
I could make it to my job with her, turning off at every traffic light. I drove enough to need a gas fill . When I stopped to refill (only one tank) I moved the wires and connectors of the gas pump. I restarted it and she sustained ralenti at 1000 RPM. I filled the tank and ran away.
But the problem wasn´t that. The battery died because of the multiple start overs and traffic lights in the city. The electrician doesn´t know what the problem should be, and I think he is too lazy to discover. I want to do it myself.
Things you should know: In my country the best gas is 92 octane, and regular is 87. I fill it indistinctively with both and the performance is the same. The Injection mapping is disconnected to deal with that thrashy gas here.
Thanks for any hint.
Decepticon is offline   Reply With Quote
Old 08-23-2013, 09:37 PM   #2
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,780
Most likely you need new fuel filters. In the left tank. How many KM's on your bike?
I'm not lost for I know where I am. But however, where I am may be lost.
-- Winnie the Pooh
Deuce is offline   Reply With Quote
Old 08-23-2013, 09:50 PM   #3
jfink
Can't get there from here
Oddometer: 113
Fuel filters, exactly the problem. I had the same problem in Argentina and then again in Colombia in Cucuta. It gets expensive replacing these filters.
Joe
2014 KTM 500 Exc, 2011 KTM 990 Adventure Dakar, 2004 Goldwing
The End of the World at the End of the World
jfink is offline   Reply With Quote
Old 08-23-2013, 10:04 PM   #4
Decepticon OP
Decepticon's Avatar
Oddometer: 112
47000 km. But why Doesn´t the FI Sensor appears in the display? if the pump is clogged, the pressure is not the adequate and the fuel injection should not work properly
Decepticon screwed with this post 08-24-2013 at 05:43 AM
Old 08-24-2013, 10:14 AM   #5
Peanuts
Peanuts's Avatar
Oddometer: 1,571
There is no fuel pressure meter in the fuel line............. so the Fi system does not know the pressure is low....... so there is no code for low pressure.
Peanuts is offline   Reply With Quote
Old 08-24-2013, 01:24 PM   #6
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Bluhduh Another option?
I did a cleaning/checking operation on the fuel pump. Nothing seems to be clogged or damaged. There was dirt in the base, but nothing out of normal.
The engine now starts well, most of the times. But when riding, the bike looses the notion of ralenti and turns off. If I turn the switch or restart the system with the STOP ENGINE Button, the bike returns to normal, apparently.
I think I have to send her to a scan in a KTM autorized service.
Old 09-04-2013, 09:20 PM   #7
shawty950
shawty950's Avatar
Oddometer: 242
Using Tuneecu, ON my 07, when I stuff with the TPS, I have to do the "Adjust Throttle Cable" on the "Tests" tab, double click to reset the stepper motor otherwise it does as you have described. ie Idles OK, then when riding sits on 4000rpm...when you pul the clutch it takes about 10 - 20 seconds for the idle to come down again.
If you do not have TuneECU then the KTM diagnostic tool should have the same procedure.
shawty950 is offline   Reply With Quote
Old 09-05-2013, 07:43 AM   #8
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Thumb KTM Diagnostic tool
He´s using the second. I will ask him if he did that stepper motor reset. Thanks a lot
Old 09-05-2013, 08:37 AM   #9
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Question KTM Diagnostic tool apparently does not have that option
That says mech. It can´t be done
Old 09-05-2013, 08:45 AM   #10
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
They have to be able do it with the ktm tools because it's the correct procedure for throttle slack adjustments
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-05-2013, 09:02 AM   #11
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Puke KTM Diagnostic tool HOW TO
Does Anyone know how to do stepper motor reset with KTM software?
Old 09-07-2013, 01:00 PM   #12
Decepticon OP
Decepticon's Avatar
Oddometer: 112
Problem solved.
I´d like to thank Bikyto, Shawty950, Katoom72, and the rest who post in this thread. You taught me a lot, and in some way helped tp get to the problem
Steppermotor parameter down a bit (dunno if voltage or steps) and problem solved. I´d bet that tuneECU would solve the problem faster.
Thanks a lot.
Times are GMT -7.   It's 03:29 AM.
