Old 08-26-2013, 04:15 PM   #1
Nevada OP
Oddometer: 300
ABS off road??
Okay, so, I know that the juicy top notch ADV bikes have ABS that can be switched off (with varying degrees of ease) for when one heads out across the unpaved roads.
My question is this:
How important is it to be able to switch off the ABS for a rider that ISN'T imagining himself to be participating in the Dakar?
NOTE TO TROLLS: If you want to go on and on about how real riders don't need ABS, it's just marketing malarky, etc, etc. DON'T. Save it, stuff it, put it where the sun don't shine. I'm not interested in that at the moment, I'm interested in how much real world downside there may be to having ABS while poking around, not racing about, off pavement.
Nevada is offline   Reply With Quote
Old 08-26-2013, 04:20 PM   #2
tkent02
Oddometer: 2,601
I don't know about your bike, but on mine (F800GS) in certain rough areas, washboards, etc, when the tire is airborn part of the time, the ABS releases completely, so you have no brakes at all. Zero. This can happen at very slow speeds as well as faster, has nothing to do with Dakar. There is no bigger feeling of acceleration in all of motorsports as the moment you realize you have no brakes at all when you need them. If you are going down a steep hill at the time, you are well and truely fucked. If your buddy stops in front of you, he is well and truely fucked. I'd say go out in a safe place and try it and see what you think.
tkent02 screwed with this post 08-27-2013 at 10:25 AM
tkent02 is online now   Reply With Quote
Old 08-26-2013, 04:59 PM   #3
Nevada OP
Oddometer: 300
Originally Posted by tkent02 View Post
I don't know about your bike, but on mine in certain rough areas, washboards, etc, when the tire is airborn part of the time, the ABS releases completely, so you have no brakes at all. Zero. This can happen at very slow speeds as well as faster, has nothing to do with Dakar. There is no bigger feeling of acceleration in all of motorsports as the moment you realize you have no brakes at all when you need them. If you are going down a steep hill at the time, you are well and truely fucked. If your buddy stops in front of you, he is well and truely fucked. I'd say go out in a safe place and try it and see what you think.
Well, since my only ABS bike at the moment is an ST1300A, there is no such thing as a "safe place" to experiment, since once it gets up an unbraked head of steam, it probably won't stop this side of catastrophe. And I KNOW the ST1300's ABS doesn't have an easy means of disabling it.
So basically what happens is if you're braking, catch some wheel/ground separation due to the bumpitedy-bumpitties, the ABS gets all confused and let's the wheel roll free. By the time the ABS catches up to what's really happening at the wheel/ground interface, bad things may have happened. Got it, sounds like something to avoid.
Thanks for the info.
Old 08-26-2013, 04:23 PM   #4
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,723
Thumb half/half
I could live with full time ABS on the front, IF I could turn the rear completely off. Stopping on a down-hill grade with a bunch of gravel and rock, you have to be able to lock the rear and slide until drag overcomes gravity.
One of my friends has a driveway that is gravel, and steep, and T's into a busy two lane blacktop. I would hate to have ABS there.
You can call me TKO
tokyoklahoma is offline   Reply With Quote
Old 08-26-2013, 05:00 PM   #5
DAKEZ
DAKEZ's Avatar
Oddometer: 19,741
"Real riders don't need ABS"
It is only important if you have taken the time to learn how to ride. Outside of that it sucks but don't worry about it because you will be too ignorant to know.
ABS is for the tarmac.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 08-27-2013, 09:19 AM   #6
Nevada OP
Oddometer: 300
And I'm seeking an understanding as to WHY it's not for off the tarmac.
Old 08-27-2013, 09:39 AM   #7
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,882
its just as simple as when you want to stopoff road, the tires need to dig by locking up. Every time the tire starts to slow down or skid, the ABS kicks in a prevents the skid thereby making it nearly impossible to even slow down in the dirt or ice. just imagine applying the brakes and essentially nothing happening aside from the noise of your ABS cycling like crazy.
If you're going down hill, this can become extremely dangerous, very quickly..... especially with a 750 lb bike
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is offline   Reply With Quote
Old 08-27-2013, 10:23 AM   #8
DAKEZ
DAKEZ's Avatar
Oddometer: 19,741
http://advrider.com/forums/showpost....30&postcount=8
Bib
Old 08-26-2013, 05:13 PM   #9
tapdiggy
tapdiggy's Avatar
Oddometer: 192
Playing Ether's Advocate Here but...
Your point is valid, where dirt riding can mean your tires lose contact with the ground regularly. But the OP seems to be talking about trundling along on a fire road at a relaxed pace, as opposed to woods riding.
I also see your point about not wanting to ride into your buddy if he stops in the middle of a hill descent. However, a sensible protocol on group rides where such a steep hill descent presents itself, would be to take it in turn, each rider beginning the descent after the previous rider has reached and cleared the bottom. Failing that, if multiple riders are descending, the interval should leave enough time and space to recognize a stopped rider and maneuver accordingly to (at least attempt to) avoid bike to bike collision.
To this, as well as the other quoted post, I would remind that ABS is speed-sensitive. Or, put another way, speed is key data in the ABS computer's calculations to determine when and how hard (or how softly) to allow the brakes to work. In the hill descent scenarios, the speed at the crest of the hill would generally be quite slow.* If the amount of momentum you have when you initiate braking, which relates to how fast you are going, is minimal, the amount of intervention of ABS should be manageable to safely get to the bottom without crashing or getting T-boned by traffic.
* Rider aids like ABS don't compensate for lack of basic skillls like looking ahead and choosing your "line"
My riding shoes are Adidas. Boom
tapdiggy is offline   Reply With Quote
Old 08-26-2013, 08:11 PM   #10
Kootenai Rider
Displaced Adventurer
Kootenai Rider's Avatar
Oddometer: 2,271
I don't think anyone considered woods riding with ABS, I think he was just saying as a Dual Sport type ride (off pavement) that it would be a bad idea.
I do not own any ABS equipped bikes, though borrowed Ladybug's ABS equipped bike a few years back. My closest call with it was actually while trundling along. Road swerved to avoid a mudish hole, dry that time of year. I was through it and basically back on the gravel road. I went that way to pass a slower rider. Not riding much faster, but I took the more direct line. Well we came together actually at almost the same time, so I got on the brakes some and ended up sliding right past the other rider as the ABS engaged. I think ABS kicking in when you least want it to can happen at about any speed.
I have looked at a few bikes that I would want to D/S/Adventure ride on that come with ABS only and it cannot be disabled. I figured I would completely remove that system just so I could get the bike I want, with the brakes I want.
If I had to boil down my dislike of ABS to one thing...its that I am not truly the one controlling the bike. There is some measure of computer controlling it. I want complete control of every bit of the bike, so when I wind up in the ditch, I can blame myself, and figure out where to improve.
as with everything. YMMV.
Like most great inventions, it is fantastic when used for its intended purpose, but in the hands of a villain, or worse, an idiot, it wreaks havoc.... - A-bone
2012 KTM 250XC-W "Ginger"
Kootenai Rider is offline   Reply With Quote
Old 08-26-2013, 08:43 PM   #11
DAKEZ
DAKEZ's Avatar
Oddometer: 19,741
Stop with the logical posts... You will confuse them.
Bib
Old 08-26-2013, 05:28 PM   #12
viverrid
not dead yet
Oddometer: 30,482
I could live with full time ABS on the front, IF I could turn the rear completely off....
Nope, I want the front off too. And if I could only have one turned off, it would be the front. In loose conditions most braking power is still in the front. For best performance I want to be able to go in & out of lock in the front and pile up gravel ahead of the wheel, which is actually where significant stopping power comes from. Yup, in dirt it is routine to briefly lock up the front.
I won't repeat all the details of my ABS-caused excursions but it is the FRONT where the ABS lets me down. The rear, it's almost an afterthought. If the downhill is steep the rear won't have much braking power anyway. On my non-ABS DRZ, I seldom use the rear brake and don't "back it in" as much as I "slide it around" with power. When I had my (2-stroke) non-ABS GasGas it had less "engine braking" and I used the rear brake a lot more.
With my 990 Adventure, it is too heavy for me to want to slide it around much and I don't "back it in". Off pavement I do use the rear brake more than I do on the DRZ but most of the stopping power is still in the front. I want to be able to briefly lock the front on command. When the front ABS comes on in loose conditions, it feels like "no brakes". There is even the psychological illusion of acceleration since the expectation is to slow and the absence of the expectation is perceived as the opposite sensation.
In loose stuff (depending on what tires I was running) I could stop my earlier non-ABS V-Strom 1000 better than I can my ABS 990 (with ABS on) and those bikes are similar weight.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 08-26-2013, 05:53 PM   #13
IgoFar
IgoFar's Avatar
Oddometer: 673
There is a video out there that demonstrates stopping on gravel, once with ABS on and once with ABS off. With the ABS off, the rider could lock the rear brake. The dirt piling up in front of the tire helped slow the bike to a relatively quick stop. Then, he tried the same stop with the ABS on. He blew by the camera, brake lights glowing, like he had no brakes at all. That video pretty much put the issue to bed.
IgoFar is offline   Reply With Quote
Old 08-26-2013, 07:42 PM   #14
viverrid
not dead yet
Oddometer: 30,482
Originally Posted by IgoFar View Post
....With the ABS off, the rider could lock the rear brake. The dirt piling up in front of the tire helped slow the bike to a relatively quick stop.
I like to be able to do that with the front also. But not at the same time! There are a lot of loose descents where the bike won't be able to slow down enough with just the back brake, The steeper it is the less braking power the back has.
Old 08-26-2013, 05:05 PM   #15
Wraith Rider
Wraith Rider's Avatar
Oddometer: 1,546
Older ABS has a problem there, right. Modern ABS works very well on gravel or even wet gras. Most of the time one won't feel any difference while leisurely riding around. Even under bad circumstances most of the time you can do so much more with the front than with a locked rear... However, it IS nice to be able to lock the rear if you want to. Full time ABS front and deactivatable at the rear is the way to go, but if I had to decide all or nothing I'd take all ABS.
"Why not stay in disguise all the time? You know, look like everyone else."
"Because we shouldn't have to."
Wraith Rider is offline   Reply With Quote
Times are GMT -7.   It's 08:51 AM.
