Old 11-12-2013, 01:13 PM   #1
Sniperx OP
Oddometer: 504
Signs you need a new clutch slave cylinder 1150GS
I've got a 2002 1150GS with about 47,000 on the clock. I had to bleed the clutch after the banjo on the master came loose and sucked in some air. While bleeding I noticed the fluid was an interesting color in the master reservoir. Usually old fluid is black or clear. Black is water contamination. This was a brown color. Huh. Odd. I found a thread, http://www.advrider.com/forums/showthread.php?t=491635, about bleeding the clutch and his fluid has a similar look to it.
OK. I'm guessing this is a no-brainer and the fluid tells the story. But, before I put down some money for parts or give it to the stealer who quoted me over 300 for the job/diagnosis....I want to be sure.
Other possible symptoms:
Tractor like shifting. Its very "CLUNKY". Meaning each change is a very solid CLUNK when gears are changed. This seams inconsistent and I can smooth it out a bit, but I don't know. I am told the GS has a very "industrial" feel to the shifting mechanism.
Shifting. Sometimes it won't find second naturally or will go into neutral instead of first. This may be user error on the latter, but I very deliberately upshift to try and alleviate the issue.
POssible "skittering" sound. When hold the clutch in, sometimes I can hear a skittering sound while the bike slows to a hault. I'm new to bike so this may be normal....or it may be the dogs slipping over their holes because the clutch isn't operating correctly. You tell me.
I'm not afraid to turn wrenches here...just need to know what direction I'm headed.
Thanks.
Motorcycles are like chlorine for the gene pool. 8/31/2013
Sniperx is offline   Reply With Quote
Old 11-12-2013, 02:49 PM   #2
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,618
I just replaced the slave on my 1200..the engagement point was the giveaway for me..I had no engagement until lever was nearly fully out..
AFTER I replaced it..I notice the shifting is MUCH smoother..apparently, getting clutch fully disengaged, makes a difference..
My fluid had not been changed in 6 years and 80K miles..it was brownish..I think..I just used suspension fluid to do the new one..10 wt, cause it's what I had..but 5 would have been better..and I may change it..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 11-12-2013, 03:10 PM   #3
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,312
Muddy brown fluid -> bad slave. Replace it.
Old 11-12-2013, 03:15 PM   #4
1reddawg
1reddawg's Avatar
Oddometer: 2,291
What Anton Said!!!
Current ride
2012 BMW Triple Black GSA
1reddawg is online now   Reply With Quote
Old 11-13-2013, 12:14 AM   #5
vintagerider
vintagerider's Avatar
Oddometer: 1,975
Don't forget to replace the input shaft rear seal. It is an updated seal. Drill a small hole. Start a sheet metal screw. Yank the sucker out with a slide hammer. Job was easy once I pulled the wheel, muffler and shock. I disconnected the hydraulic line at the master, freed the bleed line from the frame rather than remove the lines from the slave while it was still mated to the gear box. Suggest you order a 2" over from Spiegler. When you attach the new hose to the slave kick it out some to prevent interference with the gearbox. I flushed w/ DOT 3 before mounting slave to box which cleaned out the master and also saved on the cost of Dot 4 for the final fill. I added a blob of clear syn grease to the throw-out bearing.
edit: As others explain below the input shaft rear seal is accessed from the cavity once the slave is removed. This keeps gear oil from entering the cavity and fowling the slave and eventually the master. When the slave begins to leak DOT 4 the seal is contaminated and must be replaced. Some have used picks to pry out the seal but I feel that it will be far easier for most to drill (one 3/16"? hole) the seal and use a slide hammer. If I recall correctly the updated seal is brown instead of grey. Steptoe had previously advised to seat the new seal all the way up against the bearing. I never removed the push-rod for fear of damaging it.
The slave needed to be tipped up as it was withdrawn from the cavity (reinserted the same way). The paralever needed to be raised a bit then the slave, with hoses still attached, rotated to withdraw it past the round gear box cross member. edit: I probably disconnected the hoses once the slave was free of the gear box then worked it out past the crossmember.
I heated the factory bleeder/fill valve to melt the thread lock and remove it from the end of the bleeder but I could see how some might mangle the bleed hose doing that.
I reattached the oem hose to the master after disconnecting it from the slave so I could give the master a good flush with DOT 3 to clear it of gear oil contamination. I installed the new hose then bled prior to mounting up the slave. Aside from initially having interference at the gear case owing to the slightly different bend that Spiegler uses on its slave side banjo this job went smoothly with no special tools required. Use caution on torquing the tiny banjo bolts as they are special and expensive. The mount bolts are also low torque.
for sale: 1968 R 69 S-us original condition
vintagerider screwed with this post 11-13-2013 at 09:21 PM
vintagerider is offline   Reply With Quote
Old 11-13-2013, 12:51 AM   #6
liviob
liviob's Avatar
Oddometer: 702
Are you describing the the transmission input shaft that the clutch disc rides on when you say "input shaft"? The transmission input shaft seal in my 01 R GS bike has 61k miles on it and is not leaking. Was there a problem with this seal design? I ask because mine is still exposed due to unfinished clutch service. What is the benefit of the short bleed hose besides maybe a less cluttered look.
liviob is offline   Reply With Quote
Old 11-13-2013, 05:09 AM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,498
And the hose as well.
Jim
Old 11-13-2013, 05:37 AM   #8
flatland964
Oddometer: 185
Jim
I just did my slave and input seal earlier this year. I had also just upgraded to Spiegler brake lines, and so thought I'd do the same with the clutch line, and ordered the part through my local dealer in preparation for the job. However, the line that they sent wouldn't properly mount to the clutch slave because the fitting on their line was wider than on the stock line, and didn't leave enough threads left to torque the bolt. Spiegler's response was that they didn't know why I had a problem (even though I sent pictures) so I sent it back. I ended up re-installing the stock line, rather than ordering a new OEM line, because it was in fine shape. They are made out of a sturdier material than the brake lines and didn't appear to degrade internally like my brake lines.
___________
2001 BMW R1150GS, 2007 Yamaha FJR1300A
2009 BMW F650GS, 2012 Ducati Monster 796
flatland964 is offline   Reply With Quote
Old 11-13-2013, 05:47 AM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 54,498
The problem is contamination. Those who do not change the hose, and do not get it thoroughly cleaned out, often end up with Master Cylinder and/or slave cylinder failures.
Jim
Old 11-13-2013, 09:13 PM   #10
vintagerider
Oddometer: 1,975
... I also (attempted to upgrade) the clutch line (to Spiegler). However, the line that they sent wouldn't properly mount to the clutch slave because the fitting on their line was wider than on the stock line, and didn't leave enough threads left to torque the bolt.
I wonder if they shipped yours with the wrong fitting. Many have used the Spiegler clutch hose with no issue other than the one noted by me... the bend requires that you kick it out some so that the banjo does not contact the gear case.
You are correct, the Spiegler clutch hose (unlike the oem rubber brake hoses) is no better than oem, just considerably less $$. Reasons to replace the oem clutch hose are: i) lower banjo has rusted ii) hose has been contaminated internally from gear oil leaking past the input shaft rear seal iii) 2" over fits better
Old 11-13-2013, 03:47 AM   #11
sarelp
sarelp's Avatar
Oddometer: 136
On mine the engagement point has been like this for a long time. Almost all the way out, Sometimes when I take off at a stop I wonder if I have any clutch or did it quit on me. I wish I can get an answer for where the engagement point should be ??
" CARPE DIEM ! "
sarelp is offline   Reply With Quote
Times are GMT -7.   It's 09:09 PM.
