Old 12-10-2013, 07:40 AM   #1
geg OP
Canadian living in exile
geg's Avatar
Oddometer: 6,368
Thumb The OFFICIAL 2014 Formula 1 Thread
OK.... it's almost that time again
will it be
or
that takes the win in 2014?
Will Red Bull dominate?
Will Hamilton rise above the inner diva?
Will the iceman freeze out the Spaniard?
Will the new Aussie have the grit?
the clock ticks to Melbourne.....
Greg
Europe 2013 Europe 2012 Europe 2011 England 2010 Gaspe PQ 2008 Nova Scotia 2007
Try to see the world beyond your front door.
geg is offline   Reply With Quote
Old 12-10-2013, 07:44 AM   #2
papaduc
papaduc's Avatar
Oddometer: 377
Regardless of who wins in the end it will be an interesting season (I hope).
Thanks for starting the new thread.
PAPA duc
papaduc is offline   Reply With Quote
Old 12-10-2013, 07:55 AM   #3
geg OP
geg's Avatar
Oddometer: 6,368
the cars...
Greg
Old 12-10-2013, 09:06 AM   #4
geg OP
geg's Avatar
Oddometer: 6,368
nice piece from Matt Somerfield on the power-plants: LINK
Be still my beating heart
At the core of the power unit lies the 1.6 V6 engine (ICE) which differs significantly to it's outgoing brother the 2.4 V8. Needing to work in harmony with the attached components it's a floor up new design, complementing the turbocharger it will run at a much lower compression ratio. F1 also adopts direct injection with the new regulations allowing a more efficient delivery of the fuel a necessity when considering the engine manufacturers are still striving to produce the same if not more power than the larger capacity V8's did with 3,000 rpm more. That's right gone with the high compression is the need to rev the car so aggressively with the regulations capping it at 15,000rpm. It is however more likely that we see the drivers shifting around 12,000rpm as the fuel flow limits placed in the regulations mean peak power will produced much lower.
Give me a boost
Turbochargers haven't graced the sport since 1988 with the FIA reigning in the engine manufacturer's who by now had cars producing over 1000bhp in qualifying trim. The return to turbo cars helps the sport to leverage the additional power that can be generated by them and re-use it as electrical energy. The turbo's being used from 2014 however are a little more sophisticated than the one you find on your road going cars. Substantially sized they should produce lots of lag with the help of the MGU-H they'll be spooled up for action pretty much all the time.
It's getting hot in here
The MGU-H is a new unit located in the centre of the engine's V, working on the same base principles of the outgoing KERS but is instead connected to the turbo's turbine. This allows the MGU-H to extract power by slowing the turbo, which it will do under braking and by regulating the boost pressure like a wastegate would normally be used for. Energy being symbiotically harvested by the MGU-K or stored in the ES can be returned to the turbo via the MGU-H spooling the turbo and reducing lag. Energy harvested and dispensed by the MGU-H is unlimited, making it a fantastic tool for the turbo.
Filling in the gaps
The MGU-K is a redesigned KERS package, whereas KERS was tacked onto the side of the V8's back in 2009 the MGU-K has been designed alongside the rest of the powertrain. Doubling the maximum amount of energy that can be dispensed to 120KW and utilising both it's symbiotic relationship with the MGU-H and the 4MJ capacity of the ES it means roughly 160bhp is available for 33.33 seconds. As with KERS though the driver will be able to adjust the level of power it dispenses/harvests during a lap giving him 80bhp for 66.66 seconds or any other combination of time vs power between 1bhp and 160bhp.
Just like it's older sibling the MGU-K harvests energy under braking and redistributes it via the engines crankshaft. However unlike it's sibling the control of energy release will be done autonomously via the drivers input on the accelerator pedal. (Having 5 times the time component to spend around a lap would make busy work of a steering wheel button) Although it's widely accepted that a push to pass style override may still be able to be factored in.
Saving it for a rainy day
The ES (Energy Store) has a specified weight of 20-25kg's this is to discourage use of both exotic materials to save weight but also to prohibit teams from running a smaller ES to gain ballast that could be placed elsewhere. The ES must also be placed within the survival cell.
Running on fumes
To further enforce the limit on the teams ability to extrapolate performance from the engine, the FIA have mandated 100kg's as the amount of fuel that can be used by a driver during the race. Early race simulations completed by the engine manufacturer's conclude that at some tracks this is extremely marginal and in some cases downright not enough. This will of course lead to manipulation of strategy, fuel management and clever driving by the drivers.
Greg
Old 12-10-2013, 09:17 AM   #5
GSAragazzi
GSAragazzi's Avatar
Oddometer: 1,424
You know, I wish they would allow fueling up during the race again. It makes it way more interesting IMHO. I understand there are strategies based on fuel consumption/weight and tires plus the Q3 gives an idea of what to expect but I still miss that part.
On a diff note, as much as I like Vettel and RB I hope this next season works to be more interesting for the top comp.
Thanks for the schematics, pretty cool.
"The Only Easy Day Was Yesterday"
GSAragazzi is online now   Reply With Quote
Old 12-10-2013, 09:23 AM   #6
geg OP
geg's Avatar
Oddometer: 6,368
well, we had fueling.... and it had it's own issues
next year will be tougher still on fuel with the teams restricted to running even less on board.
it does seem all a bit contrived at times.... and it is one of the things we all "debate".
Here's a graphic of last year versus this year: LINK (large pic)
Greg
Old 12-10-2013, 11:22 AM   #7
Codewheeney
Hoopy Frood
Codewheeney's Avatar
Oddometer: 2,632
I don't mind the fuel limits, as pushing the designers to do more with less could have practical value for road-going cars. However, I think the rules should mandate a fixed energy (as equivalent gallons of gasoline) limit and NOT also specify the engine architecture (or at least leave it much less constrained). Then you might get some truly innovative ideas, rather than incremental improvements on existing technology. Oval pistoned V16s that rev to 25000 RPM? Sure!
Jim
Morgan Hill, CA - 2015 R1200GS, 2004 R1150GS.
Plays in traffic.
Codewheeney is offline   Reply With Quote
Old 12-10-2013, 01:15 PM   #8
PeteN95
PeteN95's Avatar
Oddometer: 2,628
I like the direct to the turbine shaft energy recovery!
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 12-16-2013, 11:21 AM   #9
Dilligaf0220
Miserablist
Dilligaf0220's Avatar
Oddometer: 4,531
I haven't seen you guys commenting on the amended 2014 rules yet?
Y'all are slipping!
Sent from my 'Droid using Boogerhook
Dilligaf0220 is offline   Reply With Quote
Old 12-16-2013, 11:44 AM   #10
geg OP
geg's Avatar
Oddometer: 6,368
Y'all are slipping!
these rules?
LINK
and yes... i think they should put them in along w/ double points for last race & a pole position trophy
Greg
Old 12-18-2013, 06:36 AM   #11
geg OP
geg's Avatar
Oddometer: 6,368
they'll need a legal team on the pit wall next...
Greg
Old 12-20-2013, 09:15 AM   #12
geg OP
geg's Avatar
Oddometer: 6,368
the new Ferrari "power unit"
go KIMI !!
Greg
Old 12-29-2013, 02:52 PM   #13
ClipDragon
Velocitas Eradico
ClipDragon's Avatar
Oddometer: 35
http://jalopnik.com/michael-schumach...ral-1491287759
Michael Schumacher, the seven-time Formula One World Champion and racing legend, is reportedly in coma and has been downgraded to critical condition after suffering from a cerebral hemorrhage following a skiing accident today, according to local French media reports and the hospital.
Schumacher suffered a head injury earlier while skiing in the French Alps. The injury was initially reported to be not that serious, and Schumacher was reportedly conscious and talking immediately after striking his head on a rock.
http://www.dailymail.co.uk/news/arti...#ixzz2otu45BiW
ClipDragon is offline   Reply With Quote
Old 12-29-2013, 03:23 PM   #14
fred flintstone
fred flintstone's Avatar
Oddometer: 525
This is awful. Hope he comes out OK.
fred flintstone is offline   Reply With Quote
Old 12-29-2013, 04:02 PM   #15
Jurgen
Trolljegeren
Jurgen's Avatar
Oddometer: 41,269
Horrible news.
They're nihilists, Donny, nothing to be afraid of.
Originally Posted by nskitts View Post
I'm sorry your dog died before you got to beat it with a dead chicken.
Moderator:CSM/JoMomma/ShinyThings/Sports
Jurgen is offline   Reply With Quote
Times are GMT -7.   It's 04:13 AM.
