Old 01-17-2014, 07:02 AM   #1
john_aero OP
john_aero's Avatar
Oddometer: 1,173
2004 950 Adventure Suspension stretch
ok been readint his section in the HOW
http://www.ktm950.info/how/Farkels/a...05_s_conv.html
and trying find the need for the spacer he lists from superplush
p/n 50180288
I was looking through parts manuals and from what i can see all i need is the hydro stop and inner tube for forks and the shim rebound for the shock
all cheap enough parts.
so my question is. i happily change oil, seals and spring in my forks including a set of 48mm wp forks for my last bike
so when i go to upgrade my springs if i get the heavier springs as required for my weight, the longer rear shock spring for my weight i should be able stretch my own sspension easily and on the cheep
fair enough it wont be re valved but i can live with that for the mean time
am i missing something hre as seems too easy
i cheked part manuals and from break down there are only 4 different parts for both bikes 1 of which is just the rear spring
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 01-17-2014, 07:06 AM   #2
kinta
Kinta
Oddometer: 155
you will need a nitrogen refill for the rear shock as the rebound shim requires the shock body to be taken apart.
kinta is offline   Reply With Quote
Old 01-17-2014, 07:21 AM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,457
http://www.advrider.com/forums/showp...5&postcount=23
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 01-17-2014, 07:41 AM   #4
john_aero OP
john_aero's Avatar
Oddometer: 1,173
ok so front should be fine as i reubild them before
rear never done so if gave it to a specalist they prob refill it cheap enough
Old 01-17-2014, 12:44 PM   #5
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Except for needing the correct setup to fill the shock with nitrogen, the shock is actually easier to work on in my opinion than the forks. See if you can get someone who knows how to show you.
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 01-17-2014, 12:54 PM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,457
I've re-valved my own forks but I'd love to know how to take the shock apart. All I really want to do is put a softer spring on it and change the oil...no special tools required (other than the nitrogen recharge)?
Times are GMT -7.   It's 01:15 AM.
