Old 01-20-2014, 03:42 PM   #1
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,441
LED Headlight "Bulb" replacement Modules
We have been watching the development of the LED bulbs for some time. I make it a point to try out most everything that might make its way to the market. Up until now that has been a disappointing experience.
There are many LED bulbs that are designed with a cluster of LEDs that are bright to look at, yet do almost nothing to project the light down the road, These just do not provide enough light to use the halogen reflector in your bikes headlight.
The other thing we have seen are led bulbs that do not have a good way of reducing the heat build up, There is a reason that high end bulbs use a fan system and electronic thermal management, It is necessary. A bulb that only uses conductive heat management will not last on a motorcycle headlight, your bulb is not in the wind, the fan is required.
What we have here is a product that promises to provide the performance of HID with the advantages of LED lighting. Using epistar emitters these things do pack a punch.
What are the benefits of this LED Module?
No Ballast.. No need to find space for an HID ballast
Instant on.. Most HIDs require a warm up
True High and Low beam
Longevity, these should last 10X what a HID setup will.
Lower power draw, on high these are pulling 30 watts on low 20 watts
3600 lumen rating
What are the draw backs of LED over the HID?
None that I am aware of.
Note that an LED or HID bulb in a halogen reflector is not going to set the moon on fire like some of todays LED Aux lights. Your expectations should be for a better working headlight.
Rather than us pushing these on you riders, I would like to make an offer to a few to riders who will install,take good photos and report back about the product.
We are running these on a test bed right now 24/7 and will not offer any for sale until we see the bulb pass the 1000 hr mark with at least 500 cycles. That will hit about the middle of Feb.
What we need in testers
1. You ride alot, we want you to give these a good workout.
2. You can take good photos of your install and beam shots, up against a garage door or something like that will be good, also a before and after shot.
3. you have the ability to know what wires (terminals) are high low and ground on your bike. There will be no need to do any splicing, but right now you will need this info.
3. You will come back to this thread and report your findings.
Retail price on these will be around $60.00
The H4 bulbs will work in H4 H6M and BA20 with a slight mod.
We will offer a 18 month warranty.
Now available here
H4/HM6
http://www.cyclopsadventuresports.com/3000-Lumen-H4-H6-LED-Headlight-bulb-_p_83.html
H7
http://www.cyclopsadventuresports.com/H7-2400-lumen-LED-Headlight-bulb_p_86.html
Plug and play kits for the KTM, Husky, Husaburg dirt bikes as well as the CRFX
coming soon!
Fitment guide
These bikes are a proven fit. The bulbs may fit many more applications.
H4
BMW
· F650ST
· X-Challenge
· K-Series
· Air Heads
· R-100
· R-1100GS
· R Nine T
Harley Davidson
· 7” Headlight
· Sportster
· Fairing equipped bikes
Honda
· CRF 250L
· XR250L
· XR650L
· CB500x
· Trans Alp
· NC 700
· 919
· VFR
· Valkyrie
Husqvarna
· TR-650
· 310
KTM
· 690 Duke
· LC-4
· 950 SE/SMR
· 950 ADV
· 990 ADV
· 1290 SD Requires canbus adapter
· 2012-13 350/500 with rubber boot.
Kawasaki
· Gen 1 KLR
· KLX250
· KLX400
· ZRX
· Concours
Moto Guzzi
· GR150
· V7 Stone
Suzuki
· DR 200SE
· DR 350S
· DRZ 400
· DR 650
· DL 650-1100
· V-Storm
· SV 650
· Triumph
· Tiger 800
· GB 500
· Speed Triple
Yamaha
· FZ
· FZ1
· Raider
· WR250x
· TW200
· FJR
H7
BMW
· GS 1200 High/Low
· GS 650/700/800 twin High/low
· High beam cover requires removal or modification.
Buell
· Ulysses XB12X High/Low
Kawasaki
· Versys High/Low
Triumph
· Tiger 1050 Low beam
H6M
· All require rectifier and H4 plug mod.
· CRFX 250/450 all years
· WR 250/450
BA20D
· Any Carbureted KTM 2 or 4 Stroke dirt bike with BA20D requires rectifier.
H11
KTM
· 1190/1090 Requires KTM H11 kit
H7 Special Fit
Kawasaki
· KLR Gen2 2008-2015 requires kit available January 16th.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
1-800-624-0278
Off Road Ryder screwed with this post 12-19-2014 at 02:36 PM
Off Road Ryder is online now   Reply With Quote
Old 01-20-2014, 04:17 PM   #2
AleksanderTheGreat
AleksanderTheGreat's Avatar
Oddometer: 401
I use my bike to commute to work 5 days a week at 4am so its plenty dark out. I have a canon dslr and can take as many photos as youd like. Shoot me a PM and and we can talk!
AleksanderTheGreat is offline   Reply With Quote
Old 01-20-2014, 04:19 PM   #3
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,284
I can probably help you out on a 2008 KLR.
I will send you a PM shortly.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-20-2014, 04:25 PM   #4
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
im in. i ride my 990 everyday. each morning in the dark. happy to take pics and post back my findings. let me know what i need to do.
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 01-20-2014, 05:32 PM   #5
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,691
i don't ride enough to be a tester, but will be watching this space for sure. my sv's headlights are ok, and i have the clearance, but more is obviously better
clapped_r6 is offline   Reply With Quote
Old 01-20-2014, 06:00 PM   #6
XFanMan
XFanMan's Avatar
Oddometer: 331
Any chance of an H6M bulb? Or is it possible to use an H6 bulb.. I've never really been clear on that.
I'll be watching this thread too
SCOTT---BIG DREAMS - small wallet
KTM Superduke R, Honda XR650R, Triumph Trophy
XFanMan is offline   Reply With Quote
Old 01-20-2014, 08:07 PM   #7
OldF7Guy
Oddometer: 304
Looking forward to seeing the results here.
OldF7Guy is offline   Reply With Quote
Old 01-20-2014, 08:18 PM   #8
cba191
wanna buy a monkey?
cba191's Avatar
Oddometer: 699
this will be an interesting read. I'm in the process of installing my new long range lights and am curious to see how these work.
cba191 is online now   Reply With Quote
Old 01-20-2014, 08:24 PM   #9
Off Road Ryder OP
Oddometer: 2,441
Thank You. We wont be doing a whole lot here just yet, but its coming.
1-800-624-0278
Old 01-20-2014, 08:22 PM   #10
Off Road Ryder OP
Oddometer: 2,441
Not really, however I have been messing around with an adaptor to use this bulb in the H6m Housings, provided they are the style that has a plate and bulb holder. Another piece of the puzzle is the new Rectifier we have made to operate these on AC power. We are not overlooking out dirtbike roots.
1-800-624-0278
Old 01-20-2014, 08:27 PM   #11
Jnich77
Jnich77's Avatar
Oddometer: 669
I have a 2004 Honda 919 that I ride 6-7 days a week, and every morning it is dark when I head out.
I use my OEM headlight wires to control two relays to power my headlight (one for high and one for low beam). The result is much "whiter" and brighter light from a OEM bulb since it actuailly gets the right voltage. It would be interesting to see the difference it makes with your light.
Jnich77 is offline   Reply With Quote
Old 01-20-2014, 08:58 PM   #12
Fredii
Fredii's Avatar
Oddometer: 20
Any chance for an LED bulb to fit the H11 in the 1190 Adventure if these first bulbs work out well?
2014 KTM 1190 Adventure R
Fredii is offline   Reply With Quote
Old 01-21-2014, 04:55 AM   #13
XFanMan
XFanMan's Avatar
Oddometer: 331
Nice..thanks for the reply. 2 of my bikes are covered if these work but my XRR (With a CRF light) could really use some help
Old 01-21-2014, 06:35 AM   #14
spoon
Rubber's gone!
Oddometer: 208
I could give a H4 replacement a workout. This is on a Sportster that lives in the mountains. Send a PM.
spoon is offline   Reply With Quote
Old 02-16-2014, 11:07 AM   #15
scottbc
advanced lurker
Oddometer: 14
Another piece of the puzzle is the new Rectifier we have made to operate these on AC power. We are not overlooking out dirtbike roots.[/QUOTE]
This is what interests me the most. I ride an EXC 450 with AC headilght system. I've been scewing around with a full wave bridge, an old 12V headlight and my multimeter. Most of the LED light specs are for 9-36VDC. This simple system seems to fall within these specs.
I would really like to make a plug and play solution that keeps the stock harness and wiring and headlight controls in place.
I'm thinking something along the lines of converting my Trailtech X2 into a halogen low beam and LED high beam possibly with the Skene dimmer in high beam LED circuit. Possibly use one of your LED lamps in the X2 high beam reflector or maybe a 3" Optimus with a custom mount. This would keep the simple one plug remove all the lighting system without altering the factory harness.
I know that it's a little off topic but seemed like a good place to ask the question. Am I off base or could this work?
Scott
scottbc is offline   Reply With Quote
Times are GMT -7.   It's 02:03 PM.
