Old 01-31-2014, 01:05 AM   #1
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,668
It's the Offseason....Let's talk about Advanced Topics like Trail Braking
A recent post here reminded me of an interesting discussion I have had with riding buddies who are die hard Keith Code proponents...Trail Braking.
Here is Keith's recommendations for racers: http://www.youtube.com/watch?v=LrbZJbXwgrY
I'm not saying I'm right here, I'm only arguing that my approach will keep me on the pavement yet not necessarily give me the fastest lap time.
I like Keith Code a lot and buy into the smooth is fast argument (IMHO, that's just basic physics). What I don't buy into is the argument his followers espouse of staying off the rear brake no matter the situation.
I can see how Keith's explanation would work for track riders working for the best lap time. "If you're entering a corner too hot, slip the front brake and downshift to engine brake and slow the rear so you stay in a gear appropriate to your speed and can exit that corner safely, but with the most speed possible."
My problem with that in the EXTREMES OF TRACTION is I have less control engine braking than I do using my actual brakes.
My REAL WORLD application of this differs for on road riders (not track riders). If presented with this situation (as this flat-road midwestern rider was last year riding in NC and Kentucky) I would/did use the front AND rear to slow the bike and worry about the correct gear later. My theory being that the application of both keeps the bike stable on it's suspension but allows for more braking forces applied before that sharper than expected corner.
I would still downshift so I was in a very ROUGHLY appropriate gear, but I would not engage the clutch as to avoid additional traction loss to the rear tire.
My question for you is: "Why am I wrong?"
EDIT: And hit me with it! I've been an idiot for almost 40 years so I'm used to the abuse!
2013 V-Strom
Thanantos screwed with this post 01-31-2014 at 01:27 AM
Thanantos is offline   Reply With Quote
Old 01-31-2014, 09:06 AM   #2
car94
What's this Box for?
car94's Avatar
Oddometer: 3,704
Question
Just bought the new KTM 1190R my MSC takes care of that for me!
Next topic, Does MSC really stabilize the Motorcycle in a lean well enough to prevent a low side or does the traction control work well enough to prevent a High side?
Ride Your Own Ride
car94 is offline   Reply With Quote
Old 01-31-2014, 11:03 AM   #3
randyo
randyo's Avatar
Oddometer: 1,686
Off season ?
full throttle
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is online now   Reply With Quote
Old 01-31-2014, 11:01 PM   #4
Wraith Rider
Wraith Rider's Avatar
Oddometer: 1,407
I always use both brakes - one exception: When the brake pads of one are used up and I need some more miles to the nnext service.
I fully agree with you that one has better control with the brake than the engine/clutch (and it's no problem to shift down without using engine braking).
But maybe I should mention: I'm not riding a race bike but a sport tourer. So it's NECESSARY for to use both brakes for maximum braking. Therefore there's no discussion to me if I should use both brakes.
"Why not stay in disguise all the time? You know, look like everyone else."
"Because we shouldn't have to."
Wraith Rider is offline   Reply With Quote
Old 02-01-2014, 04:29 AM   #5
JohnCW
Oddometer: 1,311
I couldn't actually understand the what the video was actually getting at. Like what is the recommendation (a) have smooth correct downshifts approaching a corner, and (b) be comfortable carrying some speed under brakes into the corner?
I watched it twice and that's all I was able to get from it, which to me is pretty basic stuff. Perhaps I'm missing something important so if someone would enlighten me it'd be appreciated.
JohnCW is offline   Reply With Quote
Old 02-02-2014, 02:14 PM   #6
JohnCW
Oddometer: 1,311
I'll answer my own question. After I wrote the above I had a chance to watch Keith Code's a Twist of the Wrist video. Every YouTube video I've seen is just a piece edited from this video.
I've never liked the YouTube cuts because they seem so out of context or something. But if you watch the whole video, which is about three times as long as it needs to be, totally cheesy, and a whole lot of self promotion, at least each of the individual ideas make more sense.
Now that I know what the term "trail braking" means, about my only thoughts are who doesn't ease of but still carry some braking going into a high speed corner?
JohnCW screwed with this post 02-02-2014 at 02:24 PM
Old 02-03-2014, 04:33 AM   #7
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,668
Well, I don't know. That's why I asked.
I'm trying to find a safe, comfortable medium between MSF's "Never Touch The Brakes In A Corner Or God Will Kill Puppies!" and Keith's "Never Touch The Rear Brake Ever, Use The Engine!"
MSF's approach is the right one for n00b's and Keith's is probably right for track racers. I'm neither. I'm just a guy who likes to ride hard as safely as possible.
Sent from my Nexus 7 using Tapatalk
2013 V-Strom
Old 02-03-2014, 05:19 AM   #8
JohnCW
Oddometer: 1,311
Never touch the brakes in a corner may be an ok ideal in a world comprising straights and hard right angle corners. But what about a steep fast snaking downhill twistie with hardly a straight bit of road in it. The only way to not have the brakes on going into a corner under these conditions would be to ride quite slowly.
I must admit I haven't given any conscious though to the back brake which I'm not heavy on at anytime. I'm assuming not touching the back brake is because of the combined effect of weight transfer forward and engine braking which could cause the back to loose traction. But I've never experienced this problem myself.
Old 02-03-2014, 10:32 AM   #9
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,098
I think I can splain this.
The biggest problem I read here is that Keith is talking about track riding and we're talking about road. (duh, right). The big difference here is that Keith assumes you know the track after having been around it 20 times, and therefore know what gear you should be down shifting into in order to set yourself up for the exit. Out on the road, especially unfamiliar roads, one can't really know which gear would be right for the exit drive. Best slow it down a notch.
fastdadio is offline   Reply With Quote
Old 02-01-2014, 10:31 AM   #10
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,989
What's an offseason?
I find trail braking works really well for my Harley and use it to settle the bike since it has a mushy front end. Done correctly (I have my days) I can carry a lot higher corner speed without much drama than I can by just slowing some. Being in the bikes powerband seems a given to maintain the suspension load and prevent wallowing, as well as being able to fine tune speed and line corrections in the corner.
I've tuned in some overrun on the HD and the R90 is carbed so it has it naturally which let's me be a bit smoother when doing making throttle adjustments mid-corner. On the big BMW and Duc, they have no overrun and the throttle is much more sensitive to accidental closures. Luckily both of those bikes can corner faster than I can, so I just hang on if I'm in too hot but can lightly modulate with the rear brake.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 02-02-2014, 12:31 PM   #11
Aj Mick
Aj Mick's Avatar
Oddometer: 628
Intercourse champions.
Been riding since the mid '60s, without any education beyond the School of Hard Knocks (graduating in Common Sense in fairly short order)
I'm pretty new to these forums. I keep on coming across these new terms like "encounter steering" and now "trail biking", along with a whole Alphabet Soup of courses and such ATGATT, MSF, CBT, ABS, and so on. Ya'll must be intercourse champions.
there are old motorcyclists and bold motorcyclists
but you seldom meet an old, bold motorcyclist
Aj Mick is offline   Reply With Quote
Old 02-02-2014, 12:37 PM   #12
Colorado_Rider
Oddometer: 1,193
I don't like keith code at all. His philosophy of getting on the gas long before the apex spoiles all the fun.
Colorado_Rider is offline   Reply With Quote
Old 02-02-2014, 12:39 PM   #13
Colorado_Rider
Oddometer: 1,193
You said "harley" and "corner speed" in the same paragraph
Old 02-02-2014, 01:22 PM   #14
joexr
Oddometer: 3,773
Thumb
Old 02-02-2014, 02:33 PM   #15
trc.rhubarb
Oddometer: 1,989
Meh, let's not turn this into another Harley bashing thread. There are enough already.
Follow me here
Times are GMT -7.   It's 12:09 AM.
