Old 02-10-2014, 08:51 PM   #1
cwc OP
Oddometer: 931
Frozen pipe suggestions
Came home Sunday to no water. It looks like the service is frozen somewhere in the ~105 feet between the meter which is in the house and the shut-off valve at the curb. It's all underground about 5 feet or so.
The only local plumber that deals with such things estimated $400-1000 to thaw it with an electric welder. He wants to connect in the house and at a fire hydrant down the block. I'm not sure that's a good idea because I think most of the heat will be generated in the city's iron pipe instead of in my copper.
I don't think among all my friends put together we could come up with enough welding cable to do this job.
I read here https://www.ridgidforum.com/forum/t22013-2/#post202756 about inserting a smaller tube into the line and pumping in water to thaw the ice. Anybody have experience home brewing something like this? The main question is what kind of tubing to use.
My other option is to just wait a month or so for it to thaw. That's doable since I'm the only person here most of the time, but it wouldn't be much fun.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 02-10-2014, 09:07 PM   #2
morerpmfred
morerpmfred's Avatar
Oddometer: 139
Fire hydrant in some newer areas are on different lines. Old area they would be the same.
Dad had the same problem with frozen in the ground line. Welder hooked up to the shut of valve by the street and the copper pipe in the basement. Mainline on the street should not be frozen. Half on hour later using the welder and water was on. This was in northern alberta.
Cure was to let the toilet dribble so water was always moving.
morerpmfred is offline   Reply With Quote
Old 02-10-2014, 09:10 PM   #3
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,197
Doesn't sound like fun. Do you have a time frame before it splits and you find where the frozen section really is? Has it froze up before? Where are you? Heat tape on everything exposed in the house?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 02-11-2014, 07:06 AM   #4
cwc OP
Oddometer: 931
I've wondered about the hookup of the welder at the curbside valve. Do they just clamp onto the cover for the pipe that goes down to the valve??
In my youth I dug up a fair number of those valves and I don't remember if there was a connection between the "wrench" pipe and the copper pipe.
I've always been nervous about going away and leaving water running. Maybe I need to reconsider.
No time frame on splitting, but the plumbers didn't seem to think there was a problem with waiting.
It's never frozen up in the 14 years I've been here, but according to the DOT web site http://www.mrr.dot.state.mn.us/resea...haw_graphs.asp at a site south of Rochester ( about 20 miles from me) the frost depth is 55". In the time I've been in this house the previous low was about 52".
The pipe comes up through the basement floor. It goes across the house under the floor and across the yard, under the driveway and on out to the street. IF it travels near the sewer line the first ~65 ft. is ~9 ft. below grade. Under the driveway for ~15 ft. it is 5 ft. deep and stays at that depth out to the street. The yard on the far side of the Drive has ~2 ft. of snow. The basement is at 60 now.
It seems to me the problem is under the driveway or in the street.
Charlie
Old 02-11-2014, 07:38 AM   #5
troidus
Oddometer: 14,751
My wife and I lived for a year in a craptastic house that had numerous poorly-thought-out additions over the years. The kitchen feed lines froze on us once. I learned from a plumber from a previous visit that the feed and drain lines ran together in an open shallow trench in the crawl space under the kitchen, so I got a big pot of hot water from the tub, heated it to boiling on the stove, and poured it down the kitchen drain. That put enough heat in the water lines to thaw them.
troidus is offline   Reply With Quote
Old 02-11-2014, 08:06 AM   #6
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 5,019
As a retired plumber-----I spent much time unthawing water lines underground.
We had a machine specific for the job and it worked well. We hooked on the pipe in the meter well always---not a fire hydrant and also to the pipe in the house--hopefully in a basement.
Good thing you have a metal water service---------nobody around here has metal pipe for a water service anymore-----everybody went to plastic.
Sometimes we just couldn't get one unthawed and found out somebody had made a repair to the line and spliced in a piece of plastic----------no worky.
God I hated doing that. Cold--cold--cold. Then the pipe would freeze up the next day again and the customer wouldn't pay the bill------said I didn't to a very good job.
BigDog
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 02-11-2014, 08:14 AM   #7
Beezer
Oddometer: 5,796
fwiw,,, the frozen part will be where there is no snow cover. I've seen a welder work for thawing.
Beezer is offline   Reply With Quote
Old 02-11-2014, 08:58 AM   #8
cwc OP
Oddometer: 931
BigDog
Thanks Mark.
So is the access pipe down to the curbside valve physically connected to the valve or did you have to put something down to the valve to make a good contact?
It was only -20 today, so not that bad.
Charlie
Old 02-10-2014, 09:19 PM   #9
_cy_
Oddometer: 6,274
don't be using a welder unless you've done it before, know which welder and what settings to use. they make specific AC low voltage pipe thawers for this job. just loaned mine out to thaw out a tenant's mom.
got another one stashed somewhere .. have no idea how I ended up with two pipe thawer machines
_cy_ is online now   Reply With Quote
Old 02-11-2014, 06:12 AM   #10
Badjuju
Badjuju's Avatar
Oddometer: 318
Damn! Where the hell do you live that the freeze-thaw depth is at 5 ft? I want to stay away from there if at all possible. As for thawing, I've helped a friend thaw his cistern line by disconnecting the pipe and threading a small tube into the pipe to where the blockage is and then pumping a stream of hot water into the tube until the line opens. Definitely was a much shorter run, tho. I have no idea if you could thread the small-bore tube into the water pipe far enough to find the blockage.
EDIT/ADD: Sorry. Didn't see that you were looking for tubing suggestions. We used 1/4" PP (or maybe PE) tubing similar to this. Doesn't like to go around 90* bends, tho, so you'll have to make sure you've got a fairly straight run from where you start to thread it into the system. Good luck!
http://www.toolking.com/dial-manufac...FQvxOgodmHUAmg
Some people will tell you that slow is good, and it may be on some days, but I am here to tell you that fast is better... Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S Thompson, Song of the Sausage Creature
Badjuju screwed with this post 02-11-2014 at 06:20 AM
Badjuju is offline   Reply With Quote
Times are GMT -7.   It's 09:36 PM.
