Old 03-10-2014, 06:07 PM   #1
indio OP
Oddometer: 143
Highway dirt bikes handguards for F560GS
Anybody have them setup on a 2009 F650GS? I am having tough time getting them setup due to the all the cables that are in the way.
I played with handle bar positioning as well as clutch & hand brake but there isn't whole lot of room to play with.
indio is offline   Reply With Quote
Old 03-10-2014, 08:08 PM   #2
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 997
FWIW-
Pretty straight forward on the 800.
Shooby is offline   Reply With Quote
Old 03-10-2014, 08:54 PM   #3
indio OP
Oddometer: 143
Shooby, thank you sharing pics. Could you please share a close up of the handlebar clamps that allow the handguard to be attached with the handlebar.
Is your handguard attached to the top clamp or to the handlebar? I don't have the top clamp & trying to attach the handguard to handlebars.
Old 03-11-2014, 08:47 AM   #4
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 997
Here's a dedicated HDB thread to peruse. http://advrider.com/forums/showthread.php?t=544037
These are designed with the top clamp as an integrated part to the system so not sure if a "no top clamp" solution is available without creating your own.
Is this the view your looking for?
Shooby screwed with this post 03-11-2014 at 08:54 AM
Old 03-11-2014, 12:19 PM   #5
indio OP
Oddometer: 143
Yes, that is the view & is very helpful. I don't have the top clamp at the same time Derek at HDB didn't specifically mention that these will work with top clamp only.Derek has been of great help while I fiddle around !
Old 03-11-2014, 03:39 PM   #6
Vandal 62
Mouth Breather
Vandal 62's Avatar
Oddometer: 624
I just installed hdb handguards on my 800 yesterday. I also have the 2" rox risers. I played around with clutch cable position for a while but to no avail, it was too tight. I loosened off the clutch lever perch, assembly whatever, and moved it slightly inboard and down. Voila. C'est perfection. No dramas. Hope this helps.
Vandal 62 is offline   Reply With Quote
Old 03-12-2014, 01:12 PM   #7
indio OP
Oddometer: 143
Was able to fit the L side handguard however ran into another issue & that is handguard & windshield come into contact with each other while turning handle. Don't know if I can work around that one without having to play around with windshield
Old 03-13-2014, 05:14 AM   #8
Vandal 62
Mouth Breather
Vandal 62's Avatar
Oddometer: 624
Same problem I have. I installed a Mirage 2 the same day as the HDB guards. I can turn to full lock to the right, when I turn to the left the guard hits the Mirage, looking down at the lock there is only a few mm's to room so it's almost locked out. I guess that's the nature of the beast. I'm fine with it.
Times are GMT -7.   It's 03:14 AM.
