Old 04-08-2014, 09:19 AM   #1
drjason OP
awesome
drjason's Avatar
Oddometer: 6
Lighter oilhead wrist pins in an airhead
I googled this and searched the forum and I couldn't find anyone having discussed this yet, but it seems like it is worth considering:
Success: Soaking piston in carb cleaner removes carbon very well.
Failure: Soaking wrist pin (gudgeon pin) in carb cleaner removes chrome very well.
Solution: Call re-psycle for a good used wrist pin. 11 25 1 335 474 GUDGEON PIN - 22mmOD X 13mmID X 74.31mmL
What arrived happened to be what I figure is an oilhead wrist pin. 11 25 1 341 365 GUDGEON PIN - 22mmOD x 17.5mmID x 74.31mmL.
It looks like it would fit just perfectly. The original wrist pin is 147grams, the oilhead wristpin is 83grams. Weight savings of 64g of reciprocating mass per piston.
Now I need to decide whether to send this back and order a proper airhead wrist pin, or keep it and ask for another for the other side.
Question#1: Is there a heat/stress reason that the oilhead wrist pin shouldn't be used in an airhead?
Question #2: Why hasn't this been discussed before (or is my Google-Fu just not up to snuff)?
drjason is offline   Reply With Quote
Old 04-08-2014, 02:07 PM   #2
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,461
I think the airhead pistons are quite a bit heavier than the oilhead pistons, no ? There would be more stress on the thinner wrist pin.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 04-08-2014, 08:25 PM   #3
BOETJE
Oddometer: 159
That weight difference would be worthwhile I think ! .
According to some info I dug up, the weight of a piston for a R100 airhead is
570 gr (http://www.zeebulon.de/Mot/bmw_allg.htm#Kolbenbolzen) , and the one for an 1150 GS is 585 gr....(http://www.advrider.com/forums/showthread.php?t=836329)
Mind you I did not measure myself.
But that would be not too big a difference in stress if you are not constantly bouncing of the rev-limiter.....
BOETJE is offline   Reply With Quote
Old 04-08-2014, 09:23 PM   #4
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,760
seems like a good enough idea. :hmmm
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-09-2014, 04:43 AM   #5
bmwrench
Oddometer: 2,131
That looks to me to be an aftermarket lightweight pin for an Airhead. It's been a while since I had an Oilhead apart, but my memory is their pins are heavier than the one in the picture.
As far as I know BMW wristpins are not chromed. Are you sure yours is unusable?
bmwrench is offline   Reply With Quote
Old 04-09-2014, 05:06 AM   #6
chasbmw
Oddometer: 2,253
Carb cleaner may be aggressive, but I don't think that it can remove chrome.
There was a craze for fitting lighter wrist pins some years ago and many claims were made about the results, however some of the wrist pins had a habit of breaking.
Nowadays you can get the same result by fitting lightweight pistons, but without the breakages!
I would suggest that you review what you have got
Charles
1971 Commando Fastback
Times are GMT -7.   It's 06:00 AM.
