Old 07-04-2014, 02:34 PM   #1
rickescazu OP
Oddometer: 19
Question cold fueling issue/stalling
hi i have been reading about others issue with loss of power but mine is a bit different. started a few weeks about like 5. while warming up (7-10min) it died so i restarted and it ran 10 sec and died again. tried to keep it running with the throttle and it dies as soon as i crack it open. had a 1/2 tank too. next day all fine no issues. 2 weeks later while warming up again same exact thing, tied to open the tank cap made no difference. but finally after 30 min of restarting it seems to clear up and no problem. until today, when it died 2 min after i left my house. acted like out of fuel but has 3/4 tank. same gas that worked fine the prior two days to commute.
reading here sounds like could be a fuel filter or pump issue but i get no lights or warning nothing. bike is a 2013 with 10,000 kms now and had been flawless until this. what is a bad fuel dongle? the truth is here the gas sucks we all use premium and my cars do fine but maybe that is part of it. dealer claims no one else reported this problem but mine was one of the first in the country too.
it has a wings exhaust and the UNI air filter kit from down under to stop the water intake issue and that has all been fine. only other mods are a big foot, a rear custom rack, a KTM tank pack and engine bars and LED lights.
any ideas or similar experience. climate here is mild a bit humid but bot hot or cold.
thanks
Rick
rickescazu is offline   Reply With Quote
Old 07-04-2014, 11:55 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,175
Sounds like a fuel filter. "crap fuel" = sounds like a fuel filter. You get erratic running. Can be dangerous when you are trying to pass a car and it stalls.
Contact inmate GEFR for a filter kit.
"Son, you can't do both"
Old 07-05-2014, 05:45 AM   #3
keener
Speed changes you.
keener's Avatar
Oddometer: 1,011
could be the side stand switch too. It will cut off the circuit randomly when it starts to go.
if this also happens when bike is resting on side stand with engine running,then its not the side stand switch.
04 ADV 950
keener is offline   Reply With Quote
Old 07-05-2014, 10:21 AM   #4
990
Krap To Maintain
990's Avatar
Oddometer: 192
Some of them had the lining of the tank come off and block the fuel filter looks like white bits floating in the fuel.
Smith & Wesson the original point and click interface
14 BMW GS 1200 LC
13 KTM 1190 Adv
08 KTM 990 Adv
990 is offline   Reply With Quote
Old 07-05-2014, 11:33 AM   #5
rickescazu OP
Oddometer: 19
Thumb investigating
ok thanks all for the insight.
1. looking in the tank can see anything floating but really can't see anything period.
2. fuel filter sounds like best option, have to deal with dealer as i have no source here in CR, and no clue where it is to change. My tuono was pretty easy to work on but much less wires.
3. it happened with the stand up or down running and also on the center stand. sometimes it runs until fully warmed up then dies other times its under a min. no longer ridable. seems like fuel starvation or the ECU cutting spark.
4. seems like no way for me to fix it even temporarily so have to wait 4 days to have them come pick it up....
appreciate the time and effort guys
rick
Old 07-05-2014, 12:37 PM   #6
990
Krap To Maintain
990's Avatar
Oddometer: 192
Check this out might help.
http://www.wilddog.za.net/forum/inde...topic=148422.0
14 BMW GS 1200 LC
13 KTM 1190 Adv
08 KTM 990 Adv
Old 07-05-2014, 05:49 PM   #7
rickescazu OP
Oddometer: 19
Originally Posted by 990 View Post
We'll that is another link about power loss at higher rpm or fuel starvation when pushing the bike above a certain speed,load or rpm.
Mine won't last out the driveway dies while warming up but always restarts only to die again. The overheating fuel pump theory sounds feasible but guess can only be confirmed by dealer checking ECU computer. Bike does not run long enough to warm up past one bar.
Drag I'm down to one none functioning bike. Tried to buy the new duke 1290 but dealer never got one....missing my tiger 800 now...
Thanks all
Times are GMT -7.   It's 02:01 AM.
