Old 08-17-2009, 05:52 PM   #26791
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,454
Back in June I had a meltdown in the wiring harness on my DR650. VFR870 sent me a new wiring harness from a parts bike (thanks Steve). Saturday night I got around to installing that harness. The original "fire" was in the area of the starter relay, it burned away about 9" of insulation. It also melted lots of wires togther. Well everything went fine till I got into the harness behind the headlight. I found several wires melted together there also. Turns out that it was the pigtail from the starter button. Can't quite figure what happened that a fuse didn't pop, but that's water over the dam.
I was Googling for answers because Suzuki wants about $65 for the Killbutton/starterbutton, and found on TT that Moose Racing sells a starter button for a DRZ 250/400 that plugs right into the DR650 for $23. It should be in this week (I ordered it this morn). I'll post here whether it is as promoted on TT.
anyone have any thoughts as to what happened in my start system that burned my bike to a stop?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 08-17-2009, 05:56 PM   #26792
Rusty Rocket
Life behind "Bars"
Oddometer: 9,454
Originally Posted by DRDude
What do I need to do to further clean the clutch? Should I get new clutch plates?
You could take the plates out and try soaking them in something that will get the oil off them. (for a short time)
Most likely new plates are your surest route.
2009 DR650
Old 08-17-2009, 06:18 PM   #26793
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
Originally Posted by Capnhowdy
I've got some high speed stumbling issues hopefully someone can enlighten me on.
Here is the low down; '07 with air box mod, screen removed, TwinAir filter, Dynojet kit with 160, needle 4th notch, fuel screw 2 1/2 out, and slide drilled. Stock exhaust, and I also removed the OEM fuel filter and replaced with an in-line as I am using an IMS tank.
Low to mid range runs awesome, get up to 65-70 starts to stumble a little like it's starving for fuel, and after a high speed run the other day (got up to about 85), it stumbled, and died on me. I pulled over, could see I still had fuel in the filter, and then it started right back up.
Any suggestions? Thanks
I have about the same setup as you here in Seattle. I found that the 160 MJ was too big. I went to the 155 from the DJ kit and the bike is very noticeably happier.
What kind of fuel filter are you using? If it's a sintered metal type it may not flow enoguh gas.
What are you using for a vent hose on the cap? When it starts choking, open the cap and see if it picks back up.
What petcock are you using?
If you're not using the stock Suzuki petcock, Is the vacuum port on top of the carb capped off?
Is the fuel hose kinked or pinched at all between the tank and carb? Look for a tight bend in the fuel line.
When checking for fuel flow, check the flow from the drain on the carb float bowl. When you yank the line and just check for flow from the hose you don't know how it flows into and through the carb. I use a length of clear 1/4" hose off the bottom of the carb and see how it flows into a jar or container over a few minutes. If it flow good at first then slows down you might have a tank venting issue.
itsforrest is offline   Reply With Quote
Old 08-17-2009, 06:25 PM   #26794
PsychoSayWhat
PsychoSayWhat's Avatar
Oddometer: 437
Update on my issue, I am pretty sure the oil is the problem. I did an oil change and it felt better but when I heated the bike up and got it to highway speeds, problem came back. What do I need to do to further clean the clutch? Should I get new clutch plates?
Give it a couple days with the new oil - I had the same problem with my old GS500 after using car oil and it got better after a little time with the new oil and then another oil change a month or so after.
Tiger 1050, Bonneville, Brutale
PsychoSayWhat is offline   Reply With Quote
Old 08-17-2009, 07:02 PM   #26795
BlackBeast
BlackBeast's Avatar
Oddometer: 936
Originally Posted by Shadowsong
Hi everyone
What do you think about my dr650? :)
Nice bike. You should seriously consider adding a skid plate next!
BlackBeast is offline   Reply With Quote
Old 08-17-2009, 07:07 PM   #26796
Eduardo
Eduardo
Eduardo's Avatar
Oddometer: 685
Hey Shadowsong
Hola, Welcome to ADV! I can see your'e getting the full treatment right away. Dez juz funnin'.
I like your bike, it's really tricked out nice. However, it wouldn't be that clean if I had it for a while, that's why I painted mine grey. Those are mirrors, and the gold gaters look cool. Variation makes life interesting.
Saludos, Eduardo
Four Wheels move the body, but two wheels move the soul
Escape the Tundra: Tenth winter in Mexico and Guatemala 2009/2010
http://www.advrider.com/forums/showthread.php?t=531184
Minnesota to Guatemala 2008/2009 http://www.advrider.com/forums/showthread.php?t=423949
Eduardo is offline   Reply With Quote
Old 08-17-2009, 07:54 PM   #26797
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,023
It's strange that the main 30A fuse on the starter relay didnt pop but allowed the wires to melt the insulation.
If the starter button contacts shorted against each other, it would have been cranking away until something gave, so I guess I'm just blabbing here without an answer for you.
If for whatever reason that button doesnt work out go to Radio Shack and get a large momentary push button, it can be fitted to the original switch housing with very little difficulty. http://www.advrider.com/forums/showp...ostcount=25501
http://www.radioshack.com/product/in...ductId=2062496
Glad that harness worked out for you.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 08-17-2009, 08:54 PM   #26798
sandwash
sandwash's Avatar
Oddometer: 1,363
Not a great shot,but here it is.Radio Shack button.
97dr650
sandwash is offline   Reply With Quote
Old 08-17-2009, 09:09 PM   #26799
riderskate
riderskate's Avatar
Oddometer: 250
Your Dr is sweet, where did you get the white seat cover?
Any more pics?
1997 Suzuki DR 650
1985 Nighthawk 700s
2003 Yamaha FZ1
riderskate is offline   Reply With Quote
Old 08-17-2009, 09:12 PM   #26800
Capnhowdy
Orgasmatron
Capnhowdy's Avatar
Oddometer: 7
Thanks for the replies. I'm using the petcock that came with the IMS tank, and I do have a metal type fuel filter. I'm gonna ride it to work tonight so I'll check the venting and if thats not it I'll do the other checks tomorrow. Thanks again guys.
Capnhowdy is offline   Reply With Quote
Old 08-17-2009, 11:25 PM   #26801
2laneblacktop
Tarmac
2laneblacktop's Avatar
Oddometer: 3,121
Originally Posted by plodalong
Just checked the ones I took out and they are 5mm by 15mm long standard metric thread (looks like .8mm pitch or 12.5 threads /cm) Have fun, you need to take the clutch out or it will be a lot harder if not impossible.
You don't have to remove the clutch assy, I just did it today, takes a little patience to unscrew the back one, here's what I did:
With the bike laying down,
Sharpened a punch and bump it into the screw head in the loosening direction, it came loose pretty easy, once it was loose I used a magnetized screwdriver to continue to unscrew it until it was out
I kept the front screw in because there seems to be a spring under the unit,... I changed it to the allen after the back one was in
Put the allen screw in with long nose pliers and use a ball tip allen wrench 1 size small for the extra play to easily screw it down into place then tightened it with the correct size
The factory screws are 5mm x 15mm x .8 pitch, but I replaced them with 5mm x 20mm x .8 Allens so I could shim up the head, If you look close you can see two 5mm washers under each allen head.
This is so the holes used to run the wire through clear the top of the NSU unit itself otherwise it sits below and it would be a hassle to get the wire around
You need long nose pliers to do the wire work,...
Stuff a paper towel in the hole below the work so nothing falls into the motor (not shown)
I was ready to take the clutch assy out until I saw someone a few pages back do it this way...
2laneblacktop screwed with this post 02-15-2011 at 08:43 PM
2laneblacktop is offline   Reply With Quote
Old 08-18-2009, 01:07 AM   #26802
kuyaoli
kuyaoli's Avatar
Oddometer: 320
thanks for this information, I have to do this very soon. Once I find the right time I will do it.
What I am hesitating so is, I hear so many have layed down the bike to do so, wouldn't the bike get scratched when you remove all the bolts from the side cover? I mean the bike might move a round a bit? Even if you put some kartons under it?
Also will the big sidecover gasket not get destroyed once you remove the side cover?
I guess I have to drill the holes into the Allen bolts first and get some wire to do the job.
If it is really possible I will try not to remove the clutch.
Thanks for any answer.
Sharpened a punch and bump it into the screw head in a loosening direction, it came loose pretty easy, once it was loose I used a magnetized screwdriver to continue to unscrew it until it was out
I kept the front screw in because there seems to be a spring under the unit I changed it to the allen after the back one was in
You're correct about the screws though they're a 5mm x 15mm x .8 pitch, but that's not what I used. I used 5mm x 20mm so I could shim up the head, If you look close you can see two 5mm washers under each allen head.
2012 Kawasaki KLX250S
kuyaoli is offline   Reply With Quote
Old 08-18-2009, 02:47 AM   #26803
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
I did it on the side stand with a piece of wood under each wheel to lift the bike a few inches.
You could also do it at the next oil change after the oil is drained.
I know a lot don't but the clutch was easy to remove and refit,I used Loctite cleaning agent on the stock retainers and case threads then blue Loctite.
I guess at the end of the day its what works whatever way you do it.
Got back Sunday from a 8000 km + trip to Cape York and back,go the DR.
http://www.youtube.com/watch?v=PfEQmzLt2zM
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 screwed with this post 08-18-2009 at 03:10 AM
ADV8 is offline   Reply With Quote
Old 08-18-2009, 02:47 AM   #26804
mynamewasmud
Hillbilly Adventurer
mynamewasmud's Avatar
Oddometer: 1,306
Ok, so all the info I got about glowing pipe while very informative was about 60/40 with more for the glowing pipe. Info from suzuki obtained yesterday was they run lean from the factory and they will glow, so do not give it a second thought and ride.
mynamewasmud is offline   Reply With Quote
Old 08-18-2009, 06:06 AM   #26805
Mezo
Oddometer: 2,129
2laneblacktop
Nice shots mate, thats the way to do it
And Les (ADV8) did you take some pics (silly question i suppose) and whats with the road tyre ? just saving the knobbys ?
Mezo.
Mezo is offline   Reply With Quote
Times are GMT -7.   It's 03:28 AM.
