Old 09-01-2009, 07:23 PM   #1
dsm_rally OP
The Lorax
dsm_rally's Avatar
Oddometer: 1,295
2010 Gas Gas EC450 Desert
I searched as best I could but couldn't find a thread on this. Supposed to be coming to the US in 2010. Discuss....
Model
EC 450 Desert
Engine
Cylinder size 449 cc
Type 4-stroke single cylinder with 4-valve cylinder head.
Cooling system Liquid
Bore x stroke 97x60.8mm
Ignition Integrated in the injection system
Fuel System Electronic injection (Battery less EFI)
Clutch Multidisc hydraulic operated AJP
Gearbox 6 gears.
Frame
Frame Deltabox build with Cromoly "B" tubes
Front suspension 48 mm upside-down Marzocchi fork, 290 mm travel
Rear suspension One-piece aluminium swing arm progressive system with
Sachs shock absorber, 320 mm travel
Front brake 260mm. disc, double-piston caliper Nissin.
Rear brake 220mm. disc, single-piston caliper Nissin.
Front tire 90x90 - 21" Michelin
Rear tire 140x80 - 18" Michelin
Kick starter Forged aluminium.
Size
Wheelbase 1465 mm
Seat Height 940 mm
Minimal ground clearance 370 mm
Fuel tank capacity 17 liters
Mass 133 Kg
dsm_rally is offline   Reply With Quote
Old 09-01-2009, 07:41 PM   #2
dakardad
Not waiting for anyone
dakardad's Avatar
Oddometer: 445
I like it, not allot of fairing, looks lean. Hell why not, seems like a good move for GASGAS.
Where am I going you ask.... I dunno really
just THATAWAY!!
dakardad is offline   Reply With Quote
Old 09-01-2009, 08:38 PM   #3
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I've never quite understood the point of dakar-like fairings (well, for use other than long distance ralleys) on dirt bikes, but it looks mighty cool! I'm afraid I'd have all that pretty stuff broken off in short order though
Nearly four and a half gallons of fuel is pretty sweet for a stock bike. I imagine the fairing and low fender would make it better on the road than most dirt bikes - why you'd wanna ride a dirt bike on the road though... Perhaps it'd be a great mostly-off-road touring bike, like something to ride from San Diego to Cabo and back:)
I do hope that weight figure is wet weight, ready to ride with full fuel, otherwise it may be a bit on the porky side.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 09-01-2009, 08:58 PM   #4
edgy
edgy's Avatar
Oddometer: 488
Looks really sweet!.....Now if it were something a bit more,well Yamahaish.....
www.astonesthrow.co.za
`08 KDX200
`08 SE950R
`11 KTM690
edgy is offline   Reply With Quote
Old 09-01-2009, 08:58 PM   #5
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
fugly!
That fairing from the side looks like it has a hard on.
Same too, cause I really like the GasGas in he past I've had a chance to ride.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 09-01-2009, 09:00 PM   #6
dsm_rally OP
The Lorax
dsm_rally's Avatar
Oddometer: 1,295
The smaller ones have Yamaha engines.
Old 09-01-2009, 09:19 PM   #7
Durden
Freak!
Durden's Avatar
Oddometer: 477
Looks good, but everything looks designed to be a light single tracker like the KTM 450 (huge clearance, narrow seat, knobbies etc..), if that is the case why have a huge front faring?
I like how it looks, but dont see it as a trail or touring ride...? Personally I prefer the Yammy, but I havent seen either in person.
Durden is offline   Reply With Quote
Old 09-01-2009, 09:21 PM   #8
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,497
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 09-01-2009, 09:23 PM   #9
Santa
Focused on the Future
Santa's Avatar
Oddometer: 1,402
4 1/2 gallons where? maybe 3 or 2.5
The little wings on the tank appear to be just wings.
I see something that looks like an inlet tract going to an airbox under the seat.
Gotta have a battery, likely under the seat.
Not much fuel there with the other stuff in the way.
It just looks like a mx bike with a rally fairing and low fender.
Must be for those small euro deserts?
Santa is offline   Reply With Quote
Old 09-01-2009, 09:30 PM   #10
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
The fairing is so that you can put the rollbook, gps, radio, etc... up front.
Duh...
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 09-01-2009, 09:51 PM   #11
cross-country
cross-country's Avatar
Oddometer: 1,677
I love it, can't wait to see one in person! It looks like the fairing may be made out of a more flexible plastic material, like a shroud rather than a fragile hard plastic like on the 640's fairing? very cool
Wait, that's weird, do you have to remove the front fender to pull the axle?
cross-country screwed with this post 09-01-2009 at 09:57 PM
cross-country is offline   Reply With Quote
Old 09-01-2009, 09:56 PM   #12
Mleaky
Mleaky's Avatar
Oddometer: 211
I like it. No e-start, but 6 speeds!
2007 KTM 990 ADV
Mleaky is offline   Reply With Quote
Old 09-01-2009, 09:57 PM   #13
Mo-Tarded
Mo-Tarded's Avatar
Oddometer: 177
Does the fairing roll back in angle ? Dang... I'd hate to be going into a 50 mph headwind. ...and with the guys I ride with throwing baseball size rocks at me it better be cheap because it isn't going to last a W/E.
Mo-Tarded is offline   Reply With Quote
Old 09-01-2009, 10:17 PM   #14
666
Agnostic and Orange
666's Avatar
Oddometer: 1,317
It says "Electronic injection (Battery less EFI)" , just like some kawi and suzuki in last few years.
Did you notice kickstart lever?
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 09-02-2009, 06:45 AM   #15
ALMONDOG
Oddometer: 59
i think the fairing is far away like that because when you ride off road and stand up, the windshield wont slam into your face on hard hits.
ALMONDOG is offline   Reply With Quote
Times are GMT -7.   It's 12:20 AM.
