| Welcome, lurker! Even if you don't post, the system can help you find the good stuff faster if you register. |
Thread Tools | Search this Thread |
Rating:
Display Modes |
#946 |
so little time
Oddometer: 692
ktm wont start?has plenty of spark and fuel,was running fine then turned it off for 5 minutes started it again give it 1/4 throttle throttled back, it back fired once ,stopped hasnt started since ,wont even fire???any ideas,could it be carby problems??
nothing sweet about me |
#947 | |
Ignostic
Oddometer: 13,161
If you have no idea then the best place to start is Creeper's setup thread, and use Laramie's BST Bible for reference. Then check the usual suspects if you haven't already (start with the battery - even a low battery can be an issue if you don't disconnect/turn off the headlights).
Did you check the (bleep)ing LC4 640 Index Thread?!? Kronreif Trunkenpolz Mattighofen Its not so much staying alive; its staying human that counts. |
#948 | |
Ignostic
Oddometer: 13,161
Since there is one post to the contrary on some points: Creeper thought the modest slide drilling had merit. oops, wrong thingie Creeper thought clipping the spring had no merit. Creeper thought changing the jets (if necessary) for your altitude had merit. I am guessing that if the jets are wrong you won't get good results. Not sure what "fresh air in the exhaust" means... ![]() Last edited by meat popsicle : 11-13-2009 at 07:01 AM. |
#949 | |
Ignostic
Oddometer: 13,161
I think that is a completely different exhaust from KTM (sparkie vs no sparkie SXC can). Maybe someone makes a sparkie endcap? |
#950 | |
Ignostic
Oddometer: 13,161
OK, one more place to check is down in the "Ask Baldy, Blame _________" forum. Ask for Baldy to get back to you since you might not know who is a mod that has checked with him or not. |
#951 |
Oddometer: 457
For the sxc can,, pull the tailcap and check you should have a turbine type s/a in the center of the muffler and not the tailcap.. Mine was gutted by the previous owner.. If your was gutted get a universal round screen from JC whitney or like the bigdogs one and tac weld it into the tailcap. I was rushed for time and had a brand new sparky add-on s/a for a muffler sitting around. I removed the insert part and made a plate that slipped in behind the tailcap and the s/a screen is welded into that. I have to make a how to thread as it was easy and I took lots of pics.. but i'm better with a welder and wrenched then postin pics..
Steve C 03 KTM 625 sxc-its street legal,, really officer it is! 97 GG 250ec-still here,, but now with cobwebs.. 95 KTM RXC 400-gone 03 GG 250ec-gone 98 KTM 300EXC-"rib breaker" gone!! 91 KDX 200-gone 87 KDX 200/240-gone 79 IT 175 gone several more,, that are gone but not forgotten |
#952 | |
Registered Lurker
Thanks I will do just that. You can remove the end cap. Stay tuned!
Ride safe!!!! J There are 3 kinds of people in this world: Those that make it happen- Those that watch it happen- And those that stand around sayin---WHAT HAPPENED? 2007 BMW G650X Challenge 2008 BMW R1200GSA 1995 Suzuki RM 250 BMW MOA #137435 |
#953 |
Oops...
Well, I gave it a go... started with what i figured was the most useful thread in the list- creepers oil change. Heres a link to the .pdf I made. What do you all think? How about the format? Okay? font? what should I change? (yes, i know its a friday night, but I'm home with a sick kid while the wife is at New Moon... What else am I sposed to do!?)
http://www.sarahturnerphotography.co...l%20Change.pdf
"I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles DeMar '74 XL350, '75 XL350, '78 XL350, '76 XL250, '78 CR250, '75 MT250, '76 XL175, and thats just part of the Hondas I still have left... ![]() |
