Old 12-27-2009, 10:01 AM   #2671
dodge
Gigem
Oddometer: 17
Thumb
Yah, Howard is a gnarley beast. So ugly, he's sorta cute.
dodge is offline   Reply With Quote
Old 12-27-2009, 08:56 PM   #2672
pdxthmper
pdxthmper's Avatar
Oddometer: 427
Air box, jetting, and fork questions
I finally got to tear the shock out and get started on the SV swap, but now that I have that out I have some questions about the airbox and all the feaking bits in there.
1. Whats the deal with the big rubber 90 degree elbow inlet snorkel?
2. The metal screeen?
3. The sheet metal tin baffel?
Should I keep any of this stuff in there or remove it?
4. What Jetting are people running at sea level?
5. What fork oil weights with stock springs?
Thanks.
pdxthmper is online now   Reply With Quote
Old 12-28-2009, 12:33 AM   #2673
drexNX
Oddometer: 81
1. Whats the deal with the big rubber 90 degree elbow inlet snorkel? tuned runner length for low end torque
2. The metal screeen? backfire protection
3. The sheet metal tin baffel? no effing clue, but I know what you mean. mine ran fine without it
Should I keep any of this stuff in there or remove it? remove the sheetmetal plate
4. What Jetting are people running at sea level? 148 main, 4th needle clip
5. What fork oil weights with stock springs? 10w should be good. I ran 15 but its a little harsh
Thanks.
np.
drexNX is offline   Reply With Quote
Old 12-28-2009, 06:33 AM   #2674
dhw1179
Oddometer: 47
Originally Posted by drexNX
np.
Great, that answered some questions I had. My GSXR shock showed up on Xmas eve. Now just need free time to get it installed. Where is everyone getting their main jets at? BikeBandit only goes up to 142.
DHW1179
Floyds Knobs, IN
dhw1179 is offline   Reply With Quote
Old 12-28-2009, 02:26 PM   #2675
wyowillys46
Hau Ruck!
wyowillys46's Avatar
Oddometer: 2,115
Pretty sure the plate is there to make the air turn at least 90 deg before entering the filter. This is an easy way to make particulates drop out the air stream by lowering it's velocity before reaching the filter. Common design addition on air cleaners.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 12-28-2009, 03:58 PM   #2676
pdxthmper
pdxthmper's Avatar
Oddometer: 427
They (honda) went through a lot of effort on the NX compared to my 2000 xr650L which has a filter around the outlet for the airbox. It is a regular obstacle course in there for the air just to get to the filter.
Old 12-29-2009, 02:22 PM   #2677
pdxthmper
pdxthmper's Avatar
Oddometer: 427
SV vs NX shock info
Originally Posted by IheartmyNx
SV shock
Here are some lengths of different SV shocks:
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 450# *corrected by TWF...thanks!
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
Via, http://www.mnsportbikeriders.com/for...howtopic=24967
(not claiming credit)
Ok so I am using a 1st gen SV shock (yellow spring/ black body)
The measured spring rate for the SV shock 488 lb/in, versusthe NX at
438 lb/in. I measured both springs. The NX spring would not fit on the SV shock body, the spring ID is to small, and taking the NX shock apart is a PIA.
After cutting down the spacer in the upper mount, the shock body is the same width as the NX shock at the mount.
The lower mounting hole can be moved up the clevis to match the stock nx250 lenght of 320mm, and you cut off the old mounting hole.
When I checked the force required to move the damper 10mm per the manual I read around 50lbs, the NX manual gives a stock value of 61 lbs, mine was 8.5lbs, no wonder it was like riding a pogo stick.
So if you are still with me, I think based on this data the GEN 1 SV is one of the best options to replace the stock NX shock with, IF your looking for a stock replacement with added preload adjustment, for under $50.
Old 01-01-2010, 03:45 PM   #2678
ravenranger
rave
ravenranger's Avatar
Oddometer: 1,556
Happy New Year!
So, what did your NX do today?
1989 NX250
2006 ST1300A
2006 Aprilia Caponord
ravenranger screwed with this post 01-01-2010 at 04:22 PM
ravenranger is offline   Reply With Quote
Old 01-01-2010, 05:58 PM   #2679
ravenranger
rave
Oddometer: 1,556
The recent EXCELLENT fork swap write up by captdirt has got me thinking (dangerous, I know).....
So, out of curiosity, I did a little search of 37mm fork tubes and found this list over on the XS11 forum:
37 Honda CR-80R (99-02)
37 Honda CR-85R (03-04)
37 Honda CR-125R "Elsinore" (79)
37 Honda CR-125R "Elsinore" (80)
37 Honda CR-250R "Elsinore" (78-80)
37 Honda NX-250 (88-90)
37 Honda XR-250R (81-82)
37 Honda CMX-450C (86-87)
37 Honda CX-500TC (82)
37 Honda FT-500 "Ascot" (82-83)
37 Honda VF-500C "Magna" (84-85)
37 Honda VT-500C "Shadow" (83-84)
37 Honda VT-500C "Shadow" (85-86)
37 Honda XL-500R (82)
37 Honda CB-550SC (83)
37 Honda CBR-600F "Hurricane" (87-90)
37 Honda CB-650SC "Nighthawk 650" (82)
37 Honda CX-650T "Turbo" (83)
37 Honda VF-700C "Magna" (84)
37 Honda VFR-700F "Interceptor" (86)
37 Honda CB-750F (81-82)
37 Honda VF-750C "V45 Magna" (82-83)
37 Honda VF-750S "Sabre" (82-83)
37 Honda VFR-750F "Interceptor 750" (86)
37 Honda CB-900C "Custom" (80-82)
37 Honda GL-1000/K "Goldwing" (75-79)
37 Kawasaki EX-500D1-D11 "Ninja 500R" (94-04)
37 Kawasaki ZL-600A1/A2 (86-87)
37 Kawasaki ZX-600A1-A3 "Ninja" (85-87)
37 Kawasaki ZX-750A1-A3 "GPz" (83-85) 37 Kawasaki ZX-750E1/E2 "Turbo" (84-85)
37 Kawasaki ZX-1100A1 "GPz" (83)
37 Kawasaki ZX-1100A2 "GPz" (84)
37 Suzuki RM-85 K2-K4 (02-04)
37 Suzuki XN-85 D "Turbo" (83)
37 Suzuki GS-500 EK/EL/EM/EN/EP/ER/ES/ET (89-96)
37 Suzuki GS-500 EV/EW/EX/EY (97-00)
37 Suzuki GS-550 LD/LF (83, 85)
37 Suzuki GS-550 ED/ESD/ES3/ ESE/ EF/ESF/ESG (83-86)
37 Suzuki GS-650 MD "Katana" (83)
37 Suzuki GS-700 EF/ESF (85)
37 Suzuki VS-700 GLPG/GLEPG/ GLPH/GLEPH "Intruder" (85-87)
37 Suzuki GS-750 ED/ESD (83)
37 Suzuki GS-750 LN (79)
37 Suzuki GS-750 SD "Katana" (83)
37 Suzuki GS-850 GN/GT/GX/GZ (79-82)
37 Suzuki GS-850 GD (83)
37 Suzuki GS-1000 C/EC/N/EN/ET (78-80)
37 Suzuki GS-1000GT/GLT/GX/GLX (80-81)
37 Suzuki GS-1100 ET/EX/EZ (80-82)
37 Suzuki GS-1100 ED/ESD (83)
37 Suzuki GS-1100 GZ/GLZ (82)
37 Suzuki GS-1100 LT (80)
37 Suzuki GS-1150 ES3/ESE/EF/ESF/EF2/EG/ESG (83-86)
37 Yamaha XJ-650 LK "Seca Turbo" (83)
37 Yamaha XJ-900 RK "Seca" (83)
37 Yamaha XV-920 RH/RJ "Virago" (81-82)
37 Yamaha XJ-1100 J "Maxim" (82)
37 Yamaha XS-1100 E/F/G/H (78-81)
37 Yamaha XS-1100 LG/LH (80-81)
37 Yamaha XS-1100 LG/LH "Midnight Special" (80-81)
37 Yamaha XS-1100 SF (79)
Don't know if that will help anyone out doing a fork change but thought I'd add it to the archive of wisdom just in case.....
Now, if I could find info that includes the length of the various fork tubes, that'd be cooking with gas!
1989 NX250
2006 ST1300A
ravenranger screwed with this post 01-01-2010 at 09:13 PM
Old 01-02-2010, 11:52 AM   #2680
RogerThat
Old Guy Adventure Videos
RogerThat's Avatar
Oddometer: 159
Great Pic
Originally Posted by ravenranger
Happy New Year!
RavenRanger
A warm day with sunshine and dry to boot. What a novel concept this time of year.
I love AZ.
Roger
Simple solutions to complex problems will not be allowed.
RogerThat is offline   Reply With Quote
Old 01-02-2010, 01:27 PM   #2681
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,044
You Sir are a lucky man.
Today in -16C mine has had its battery and plastics removed.
Gearing up for the over-winter modifications.
Happy New Year!
my mini ride reports
"parts made of unobtanium"
ArthDuro is offline   Reply With Quote
Old 01-03-2010, 05:30 AM   #2682
mito-nx
Dutch Humor
Oddometer: 58
Happy New Year!
Not mutch, it's snowing outside.
I am doing some winter maintenance on the engine so when the snow clears I can ride again.
mito-nx is offline   Reply With Quote
Old 01-04-2010, 04:04 PM   #2683
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 538
Oh, wait, you said NX, not the L'il Red Piglet. It rested while I had the 223 cc bike out.
John
2009 Honda CRF230L (L'il Red Piglet)
2014 Honda CB500XA (Daily Rider)
jsonder is offline   Reply With Quote
Old 01-04-2010, 04:06 PM   #2684
ravenranger
rave
Oddometer: 1,556
Wow John, where did you go today?
1989 NX250
2006 ST1300A
Old 01-04-2010, 08:48 PM   #2685
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 538
Santa Rita range.
John
Times are GMT -7.   It's 02:20 PM.
