Old 01-01-2010, 06:18 PM   #11
Bluebull2007
Bluebull2007's Avatar
Oddometer: 5,261
Originally Posted by RedHawk47
This is the key to alleviating your problem Bluebull2007. The right side bearing is intended to "float" in it's position in the hub. It looked like you used a socket to press the bearing in - that presses the outer race only. By using a solid tool the presses both the outer and inner races the bearing will stop at the sleeve and the outer race will be in the proper "float" position.
Guys (Redhawk & Joel) youre both quite right, something flat is better suited for the job. However I still think you might be able to load the inner race (of the problem bearing in this thread) with any kind of pressure from the floating side.
Dreaming of Dakar
Everyone has a max speed, 90% of that max speed is much safer and easier, and if that 90% speed isn't fast enough at Dakar, you enter the snowball. - neduro
Bluebull2007 is offline   Reply With Quote
Times are GMT -7.   It's 06:00 AM.
