Old 03-02-2010, 06:53 AM   #1
CurlyMike OP
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 945
Airhead electrical Question. Circuit Board
This is for my latest resurrection. Its off of a 1975 R75/6. I spent a couple of minutes straightening all of the “pins” and even cleaned them all with my Dremel and a small wire brush. Sprayed contact cleaner on the front and back and am ready to start plugging. (Note: The picts are before the cleaning and the straightening). When it comes to electrical I just kind of shut down.
The contact pins that obviously have a strip in the back were somewhat loose, not overly, and not all of them. Is them being loose going to inhibit the boards functionality? Should I drop some solder on each to sure them up? Am I over thinking the function and the way these work? Can I test each with a voltmeter? How?
Giving the horses and the wife a break from riding...
CurlyMike screwed with this post 12-13-2010 at 06:15 AM
CurlyMike is offline   Reply With Quote
Old 03-02-2010, 07:35 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
they're supposed to be crooked, as in the first picture. That's what keeps them tight in the board. After you re-bend them make sure you test the diode so you don't get a neutral light when you pull in the clutch handle!
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-02-2010, 09:03 AM   #3
CurlyMike OP
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 945
Ok, got it. Do I need to do anything to re-sure the posts so that there is no wiggle room in them from the back side?
Old 03-02-2010, 09:14 AM   #4
bruno twip
On Island Time
bruno twip's Avatar
Oddometer: 403
wiggle is ok,
falling out is bad
just make sure the connecitons are clean and tight
Use a little no-ox (dialectric grease) on the connections
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.”
Mark Twain
bruno twip is offline   Reply With Quote
Old 03-02-2010, 12:33 PM   #5
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 4,430
MOST of those connections are just simple multiple-wires-coming-together... if you are concerned, use an ohm-meter and there should be continuity between every pin in the same color code.
The wiring diagram for that model will show the other connections that are made, using the board: the top two center ones are connected by the little ceramic fuse so dear to the germanic engineers, where you have the metal/glass ones: #15 is live, going through the fuse to feed #15U; #58 is live, going through the fuse to feed #58U. (by "live", I mean that they are fed from the ignition switch and are "live" when the switch is "on".. the only real "live all the time" wires in the bucket are the red ones coming to the ignition switch)
You can test the diode with your ohm-meter as well: it connects "LKK" to the brown/yellow right next to it (I can't read your board, am too lazy to go find my Haynes.....)... Reminder: a diode is an electrical check-valve, or one-way valve: electricity can only flow one way. So, put the leads on either side of the diode, and it should read continuous one way, and not continuous with the leads reversed (red is +, black is -).....
What looks like a hodge-podge is actually VERY simple and quite orderly.
I am vaguely remembering that I could not find the terminal "LKK" in the Haynes manual, but the color coding works, so no matter.
I actually LIKE electrical work and electrical sleuthing (twisted, huh....!), so let me know if I can help in any way.
bpeckm is offline   Reply With Quote
Old 03-02-2010, 05:08 PM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,361
As has already been mentioned - the terminals are supposed to be twisted, but not bent.
Check the diode - it's much more difficult to fix when installed.
No solder needed - just clean, bright and shiny connections.
Old 03-03-2010, 08:03 AM   #7
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 845
The board is really a holder and not a circuit board, per se. That is, there are no solder connections between terminals, so it doesn't matter if the terminals are loose. Of course there shouldn't be "crosstalk" between circuits, but that's not very likely if everything comes through it's proper hole.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 03-03-2010, 08:51 AM   #8
CurlyMike OP
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 945
OK, thanks all for all of the info. bpeckm might get a PM explaining how to test . Like amost times I am sure I over thinking the whole thing.
Old 03-03-2010, 10:45 AM   #9
Yarddog
Oddometer: 322
Yep...I think you ARE overthinkin' this thang!! It's a simple piece, crude but effective, and I think we'd have a lot less problems with our equipment if things were more like this connector board...Looks fine, just hook everything up and yer good to go, and don't forget to use dielectric grease
Yarddog is offline   Reply With Quote
Times are GMT -7.   It's 12:22 AM.
