Old 04-21-2010, 09:55 AM   #1
no5s OP
Terror at 2 mph
no5s's Avatar
Oddometer: 342
Welding on an airhead
My good friend was recently in an accident on his pristine 88 R100GS. The force of the fall sheared the steering stop on the frame off. I can weld it back on, but I'm concerned about the electronics. What do I disconnect, remove, etc. Thanks for your help.
12 Super Tenere
84 R80 ST
64 R50/2
65 Triumph TR6 Desert Sled
65 Triumph T100SC TT Bike
no5s is offline   Reply With Quote
Old 04-21-2010, 10:14 AM   #2
mykill
odd
mykill's Avatar
Oddometer: 1,166
I was always told the diode board was susceptible to damage from welding current.
better safe than sorry.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 04-21-2010, 10:27 AM   #3
rkatapt
Indo-Kraut
Oddometer: 261
I'd go slow doing maybe 1/4 at a time then let it aircool. Don't want anything warping up there or heating up the steering bearing grease.
rkatapt is offline   Reply With Quote
Old 04-21-2010, 10:27 AM   #4
The Raven
The Raven's Avatar
Oddometer: 4,811
I agree, the two things I welded on my g/s was the rear muffler mount, and the kick stand plate, the ground clamp was within 6" of the welding surface though.
I did disconnect the negative the the battery and ICU.
The Raven is offline   Reply With Quote
Old 04-21-2010, 01:32 PM   #5
Phreaky Phil
Oddometer: 1,813
Ive welded on mine before and only ever disconnected the battery. Keep the welder earth as close as possible to where your welding. As you will be so close to the steering head bearings, are you pulling the triple clamps out ?
Phreaky Phil is offline   Reply With Quote
Old 04-21-2010, 01:55 PM   #6
no5s OP
Terror at 2 mph
no5s's Avatar
Oddometer: 342
Welding
I hope to keep it together. Just tack and let it cool. If grease starts running out, I'll take it apart. Thanks all for your help.
12 Super Tenere
84 R80 ST
64 R50/2
Old 04-21-2010, 06:36 PM   #7
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,682
I've done this a couple of times and removed the front end to gain access and make a neat job.
Of course with the front end off and a welder handy it's pretty easy to throw in a set of bearings.
Disconnecting the battery should be enough but with the front end off why not disconnect the diode board as well.
Usually I discover little things along the way like chaffing in wiring looms , grunge that can't usually be got at or a better way to put it all back together so that cables don't rub frame paint.
Excessive maintainance is what keeps these things pristine even if it does take all weekend to do a 30min job
Rucksta is offline   Reply With Quote
Times are GMT -7.   It's 12:34 PM.
