Old 04-25-2010, 04:08 PM   #1
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Airhead Frame stand for painting
I'm sure someone elae has thought of this, but I had an inspiration today, and rather than make one I just grabbed and old R90S block that was kickin around.
PERFECT! for holding the frame while soda blasting, sanding and painting.
This is that 1976 /6 I showed here a few months back.
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 12-03-2010 at 10:17 PM
Old 04-25-2010, 04:10 PM   #2
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
nuther angle
No, it's not gonna be orange!
Red oxide primer
www.wirewerkes.com
Old 04-25-2010, 04:10 PM   #3
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
crazydrummerdude is offline   Reply With Quote
Old 04-25-2010, 07:17 PM   #4
bmwrench
Oddometer: 2,350
Well sure, everybody has a spare crankcase lying around (just tripped over one yesterday), but who has a convenient pickup truck?
Just kidding. It's an inspired idea.
bmwrench is offline   Reply With Quote
Old 01-16-2015, 06:29 PM   #5
Manymotos
Oddometer: 59
Frame blasting/painting fixture
Another option if you have light fabrication tools and skills is to make a simple rotisserie. The frame for it can even be made from 2 x 4s if you don't want to weld something together. Basically, you can build a frame with two vertical posts about 4' apart. Put a hole for the rotisserie tube or rod to go through in the top of each post. Take a piece of all thread long enough to go through a pair of the engine mounting holes in the frame. Use another piece of all thread through the steering head leaving about 18" extending out the bottom . Now find the balance point by running the rotisserie tube through the frame, with the frame on it's side. Weld the rotisserie tube to the two pieces of all thread. Now you can load the rotisserie tube with the frame on it between the two vertical posts. You now can rotate the frame 360 degrees and the only places you won't be able to blast or paint are where the nuts are on the piece of all thread through the pair of engine mount holes.
This fixture is extremely usefully for wet painting frames as frames are very difficult to paint all the way around without missing a place of two. Another benefit is that often when painting frames it is easy to apply too much paint trying to hit tube joints and tight places. If you rotate the frame slowly for a few minutes after spraying, the areas with heavy paint will flow out rather than turn into runs. For rotating the frame simply clamp a vise grip on the end of the rotisserie tube and use it to turn the tube.
My rotisserie is much more refined than what I have described above but I do quite a bit of painting and use mine for frames, gas tanks, fenders and a number of other things. You are only limited by your imagination. Painting fenders is very beneficial because you can get both the underside and the top side painted very nicely all at once. The same applies for gas tanks. Fixtured properly it takes much of the risk out of your paint jobs.
Manymotos is offline   Reply With Quote
Old 01-16-2015, 06:32 PM   #6
CafeDude
CafeDude's Avatar
Oddometer: 1,982
CafeDude is offline   Reply With Quote
Old 01-16-2015, 06:34 PM   #7
Manymotos
Oddometer: 59
Photos
I tend to agree with you. Currently I'm just sitting here at the house and the rotisserie is at the shop. Monday I'll get a picture for you.
Old 01-16-2015, 07:23 PM   #8
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,607
We miss you Robert....
Old 01-16-2015, 07:24 PM   #9
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,503
Sounds like a good idea. Paining small-ish parts by hanging them from a wire can be a pain-- if it's too high you can' paint the top, the bottomside needs a contortionist to get underneath it, you can get paint backfired into the face or find cricks in the back doing the lumbago to get all around.
I'll be Ron Popeil got his start doing this...
--Bill
'73 R60/5 Toaster
Old 01-16-2015, 07:34 PM   #10
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 885
Yeeeah.
Kt-88 is offline   Reply With Quote
Old 01-17-2015, 04:31 AM   #11
Jim K in PA
Jim K in PA's Avatar
Oddometer: 1,332
we miss you robert....
x2
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is online now   Reply With Quote
Old 01-17-2015, 04:38 AM   #12
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,326
x3
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 01-17-2015, 04:42 AM   #13
igormortis
igormortis's Avatar
Oddometer: 1,402
igormortis is offline   Reply With Quote
Old 01-17-2015, 05:55 AM   #14
bmwrench
Oddometer: 2,350
The older we get, the more people we miss. Robert was one in a million, though.
Times are GMT -7.   It's 06:33 AM.
