05-22-2010, 10:02 AM
#35416 | |
Grandpa Adventurer
Oddometer: 1,175
DR on the highway
My DR lives at 350 ft altitude and runs fine at 7000 ft in the local mountains (Cascade range of Oregon). The carb etc is all stock. Dave
Smilin Jack Western Oregon USA 2006 DR650SE CB250 1991 Adventure bike "dual-sport" http://www.advrider.com/forums/showthread.php?t=441736 http://www.advrider.com/forums/showthread.php?t=469125 http://www.advrider.com/forums/showt...e#post11612867 http://www.facebook.com/album.php?ai...8&l=3d8dcb2743 |
05-22-2010, 10:04 AM
#35417 |
Grandpa Adventurer
Oddometer: 1,175
Long trips on DR
Here's the fuel can mounted on the DR out in the central Oregon desert. Went 450 miles that day to meet up with friends.
Yes, that center stand is from procycle and my best farkle so far. Dave
Smilin Jack Western Oregon USA 2006 DR650SE CB250 1991 Adventure bike "dual-sport" http://www.advrider.com/forums/showthread.php?t=441736 http://www.advrider.com/forums/showthread.php?t=469125 http://www.advrider.com/forums/showt...e#post11612867 http://www.facebook.com/album.php?ai...8&l=3d8dcb2743 smilin jack screwed with this post 05-22-2010 at 10:27 AM |
05-22-2010, 10:10 AM
#35418 |
Grandpa Adventurer
Oddometer: 1,175
Extra tail light on DR
Mounted an LED side marker on the back of the DR as an extra tail light. Commuting to work in the dark and wanting to be seen was the motivation.
The LED is much brighter than the stock tail light. Measured the amp draw and was 0.09 amps on the Fluke meter. Tapped into the license plate light wires under the seat and soldered in place and taped the heck out of the junctions. The light was bolted to the fender below the license plate using 8-32 stainless with nylock nuts. Dave
05-22-2010, 10:52 AM
#35419 | ||
Wee Stromming Now
Oddometer: 179
thanks guys
I'm curious about what distances I can expect. Smilin Jack said expect about 450 miles a day, Sounds right to me, what's the consensus with that? |
05-22-2010, 11:37 AM
#35420 |
on the road o'dreams
Oddometer: 5,397
The DR is pretty good on long, boring highway riding. You can cruise at 80 mph indicated (74 mph actual) all day. Carrying gas would be good if you can do it safely. If you can rig a BBQ rack on the back then you can probably carry a nice big duffel and wedge in a 2 gallon Fuel jug. Don't forget the GOOD EAR PLUGS. Use them! With the Two Gallon jug you should have about a 200 mile range. (mas o menos)
As a bicyclist your butt should handle the torture rack stock DR seat. Just get your head in the right space and keep on rolling. I did a 1000 mile day coming home from Baja (about 22 hours) and did 750 miles coming home from a rally in Colorado. (14 hours) The trick is taking nice long breaks, stretching, eating light and drinking plenty of water. (Camel Back a MUST!) But as a bike racer I'm sure I don't have to tell you all this. You'll do fine, you guys are tough as nails. I'm 61 and can still do it so should be a cake walk for you. Have FUN! I'm thinking your jetting should be OK. I'm running a 155, Jesse's cut air box, DJ needle 3rd position, and am at sea level. All good. Worst case would be to go richer on the needle clip (the needle covers cruising RPM from 1/2 to 3/4 throttle). Your 155 main jet should be OK but the needle clip may need to richen up a tad for safe sea level running at high speed in high heat. The Trail Wing rear will be finished by the end of the trip. Small price to pay. Clean and Oil chain once a day, run correct pressures in tires. For touring with T-Wings I'd run just slightly higher pressures. 24 front, 28 rear. No higher. Don't listen to the BMW guys on tire pressures ... The DR is 324 lbs. dry, not a 630 lbs. GS. (Suzuki recommends 22 front, 25 rear, perfect for day to day riding. But touring and carrying a load, you need to go up just a bit) |
05-22-2010, 12:02 PM
#35421 | |
Interloper
Oddometer: 3,270
" Never look a gift bike in the sprocket . " Road Trips . . . Alaska, Himalayas, Labrador and Oz |
05-22-2010, 12:10 PM
#35422 | |
Wee Stromming Now
Oddometer: 179
Nice
05-22-2010, 12:16 PM
#35423 | |
-Doc '02 CR250R '98 WR400f '08 Tiger 1050 |
05-22-2010, 01:16 PM
#35424 |
Oddometer: 268
fuel chart, sorted by average fuel consumption
It is raining around here, so I decided to update the chart with the latest info.
05-22-2010, 02:08 PM
#35425 | |
Engineering student
Oddometer: 266
. That having been said, I don't often feel like racing a bicycle at all so YMMV.
__________________ Across the country on the kindness of strangers and the strangeness of friends (and a DR650). My LinkedIn Profile |
05-22-2010, 02:23 PM
#35426 |
Slabbing it
Oddometer: 788
Quick question for those with RAD hubs on their Supermoto setups. Is there a specific spacer for the disc side of the front hub? When I went to install my second hand supermoto set with my stock spacer, the tire is rubbing the left fork leg pretty good. Making me think that a longer than stock spacer is need to push the wheel over to the right a bit, so as to center everything up.
Idears?
49 Hudson - 72 Yamaha - 74 Caravelle - 00 Honda - 03 Chevy - 07 KTM
05-22-2010, 02:48 PM
#35427 |
Oddometer: 1,626
Colorado Col Rider, You do know that you will have to write a report on both of the rides, DR 650 and the Road Bike, and post it here, and pictures are always nice.
05-22-2010, 03:11 PM
#35428 | |
Oddometer: 1,607
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
05-22-2010, 06:15 PM
#35429 |
Oddometer: 923
Northyork - thing of beauty! Thanks for doing that. When I finally get around to opening the carb, I'll get the set up.
I'm currently in the middle of ProCycle's Shock Solution Kit with a heavier spring. Evidently, I'm not tall enough for my weight. One tricky item but straight forward for a back yard mechanic. It's all a puzzle, just get the pieces in the right place.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
05-22-2010, 07:28 PM
#35430 |
Life behind "Bars"
Oddometer: 6,266
Bike just shut off today. Moved the wiring harness around a little and was able to get it to start. Drove 100 yards and it quit again. No headlite no starter. Nothing. The wires that seemed to get it going when I moved them were the ones coming outta the keyswitch.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
