Old 05-22-2010, 07:49 PM   #61
eddyturn
Wannabe
Oddometer: 2,069
Maddaddy... which MAP did you do? I see there are a couple of them out there and I am due soon.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 05-22-2010, 09:42 PM   #62
Maddaddy
Greg
Maddaddy's Avatar
Oddometer: 1,742
I have no idea. I do know that it was a new version of software from BMW. I had to wait a few days before I could come in and get my re-map because they were having trouble installing it on their computer.
PSSOR - Dualsport Training & Adventure Camps.
Off-Road Destructor Extraordinaire
Maddaddy is offline   Reply With Quote
Old 05-25-2010, 07:19 AM   #63
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Hmm... I have an appointment in a few weeks to get some things done in preparation for a week-long trip; should I call first to make sure they have the remapping stuff already? I wanted to get the new version of the low-octane map, and with my time crunch (I leave a few days after the appointment), I really don't want to have to wait.
dendrophobe is offline   Reply With Quote
Old 05-25-2010, 07:49 PM   #64
Maddaddy
Greg
Maddaddy's Avatar
Oddometer: 1,742
I'd call. just to see. They should have it. When I called to make my appointment it was the day they were installing the new software on the computer.
Takes about 30 min to install if all goes well.
Old 05-28-2010, 10:54 AM   #65
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,092
Has anybody tried this? How did it work?
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 05-28-2010, 08:37 PM   #66
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 694
It is awesome. Oh wait, maybe I'm biased as those are my pictures but the mod is easy, reversible, and makes a noticeable difference with throttle modulation. No peeling of heating elements either!
Thank you inmate drrags for the idea.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 05-29-2010, 01:08 PM   #67
Grafspee
one bike is never enough
Oddometer: 208
Just one question?
How long is the piece of 14 gauge wire in the throttle cam?
Grafspee is offline   Reply With Quote
Old 05-29-2010, 01:25 PM   #68
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 694
I'm trying to remember as it was a while ago I did this. I think it was about 1" to 1.25". I left room for a half loop and I also marked it with a indelible marker so I could keep track of it if it were slipping out. So far no problems. I would have put bigger/more in there but the throttle cable is only so long and this is all I could get away with at the time with the stock throttle cable IIRC.
Since we're on the topic, I also slipped some Renthal grips OVER the stock grips to give the grips a bigger diameter making them easier and grippier to hold and to increase the outside diameter of the grip to reduce throttle sensitivity. If that's confusing, just think of turning a volume knob on your stereo. If it's a small knob, you don't need to move it much at all. Now if you were to swap it for a huge knob, even though the degrees moved would be the same, it would take much more 'spin' at the outer circumference to achieve the same degrees of rotation.
Ride on.
Old 05-29-2010, 05:36 PM   #69
kelsow
kelsow's Avatar
Oddometer: 1,118
That's actually a great idea. Thanks.
I took just enough slack out of the throttle cable and it seems to have made a difference.
I haven't been able to try it offroad yet.
"Kelsow's helmet is so tight, it cuts off the circulation to his personality."
Ride: 2010 BMW F800GS
Site: dualsport.ca and rideatlantic.ca
kelsow is offline   Reply With Quote
Old 05-29-2010, 05:52 PM   #70
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,732
Hi Kelso!
I visited you fellas (NSDSC) a few years back. I think I may have been on my 1200GS at the time or maybe my 950. You guys sent me a few of your club decals too, the very one you have as your avatar. I have one on my pannier. which I still use today on my 800, and on my toobox in my garage!
"Nova Scotoa Dual Sport Club"
I also have the NBDSC (New Brunswick), but that decal is on my nieces tri cycle
Cool.
Sorry, back on topic now.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 05-29-2010, 06:52 PM   #71
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 694
Hey Kelsow, whaddaya'at b'y!
I got the idea from this thread about grips and put two and two together. If I were to do it again, I would use the Renthal Kevlar tapered grips for better longevity and more anatomical shape. I slipped them over the stock grips using compressed air and secured them with safety wire. The heated grips still put out a reasonable amount of heat - just not as much as before, given the layer of rubber insulation you end up adding.
EDIT: Just wanted to give Gangplank the credit for coming up with the grip idea in case nobody follows the link to his thread.
Ride on.
Bartron screwed with this post 06-01-2010 at 05:03 AM
Old 05-30-2010, 05:13 AM   #72
David_S
David_S's Avatar
Oddometer: 1,130
I'm confused Wouldn't this mod make the throttle even more sensitive since it make the drum larger so the cable is actually pulled farther with less turn of the throttle?
bikeless
David_S is offline   Reply With Quote
Old 05-30-2010, 09:02 AM   #73
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 694
If this is the only mod done, then there is relatively LESS throttle input for the same twist of the throttle.
I can try to explain. Let's assume that your throttle hand twists the throttle enough to pull 1cm of throttle cable. That means that 1cm of throttle cable will move off the throttle cam which for the sake of discussion will move the throttle 20 degrees. If you make the throttle cam larger by increasing its diameter with a piece of 14 guage wire/epoxy/tin foil you increase its circumference. Thus, 1cm of movement of the throttle cable on the now bigger cam will result in less than 20 degrees of throttle movement because the 1cm of throttle pull is being effected on a larger effective circumference.
Therefore the same amount of throttle input engages LESS throttle at the throttle pin by twisting it less than it would with the previous smaller cam.
Ride on.
Old 05-30-2010, 06:32 PM   #74
Spinalcracker
former redriderofma
Oddometer: 1,092
If you put the Renthal grips over the stock do you still get heat from the heated grips?
TET MA to NC
Old 05-30-2010, 06:37 PM   #75
Spinalcracker
former redriderofma
Oddometer: 1,092
never mind just saw the above post
TET MA to NC
Times are GMT -7.   It's 01:19 AM.
