06-13-2010, 03:15 PM
#36196 | |
Oddometer: 268
Raised bevel faces inwards
06-13-2010, 03:42 PM
#36197 | |
Oddometer: 268
Good to hear that you decided for a Sargent seat, your butt will be forever grateful.
![]() I am sure the DR will be your faithful companion and consistent performer. Do not ride if you are overly tired. Take brakes. Ride Safely, take pictures, and above all that >>>>>>>>> Have a great time!!!!! Can't wait to go through your RR. All the best, Northyork Quote:
06-13-2010, 04:56 PM
#36198 |
Oddometer: 53
Moab May 2010
[IMG]
[/IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
06-13-2010, 05:27 PM
#36199 |
Oddometer: 920
Moab - great shots Cemory! Still haven't made it there. I'd like to do 5 MOH....not on the DR tho.
I've done areas close but never Moab proper. Outstanding!
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
06-13-2010, 05:48 PM
#36200 |
Gorilla Adventurer
Oddometer: 1,951
Awesome pics!!!
bikes |
06-13-2010, 05:51 PM
#36201 | |
Oddometer: 2,070
On the other hand if you want to paint yours you can use a rattlecan paint specifically made for plastic. I think Duplicolor makes a good one but be sure if you do, there's no turning back once you paint plastic. Good Luck
My Blogs: Higher Resolution Photo Album Motorcycle Photo of the Day 2-Stroke-Biker-Blog |
06-13-2010, 05:55 PM
#36202 |
Gorilla Adventurer
Oddometer: 1,951
I just went and looked at the cap of my IMS tank and it's the tophat design and it's lost some pieces.
If I call IMS will they send me a new cap? Thanks!
bikes |
06-13-2010, 06:00 PM
#36203 |
Oddometer: 2,070
About the degraded IMS gas cap gaskets. Mine went to crap like most of them tend to do and during the time I was using my IMS tank I replaced it with a nice (made for modern gas) O-ring gasket that is made for an Kawasaki and fit the cap and sealed it perfectly.
Go HERE for the Kawasaki Triple Fuel Cap Gasket that they show. It's $12 and I'll vouch for the vendor as I've done a LOT of business with him. The gasket works great and did not leak a drop. Make sure you have a good vent tube hose routed down the triple tree collar and you're all set. hope this helps someone out. Full link to their page. http://www.hvccycle.com/vintagekaw.htm Sorry links fixed now
06-13-2010, 07:11 PM
#36204 | |||
lifelong reject fixer
Oddometer: 1,217
RE, the OEM 15-t counter-sprocket --
'08 DR650SE; '91 GL1500SE; USMC 1972-76; NRA Life Member ------------ "The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius |
06-13-2010, 09:28 PM
#36205 | |
on the road o'dreams
Oddometer: 5,393
I've had a few minor get offs (on dirt) and the bags actually stayed put. ![]() You just have to sit there and figure the best way to keep them secure. But very few bags really are 100% secure in a crash. I wouldn't even try. In Baja I had those same bags on my XR250 (now sold) and the Cortechs got into the rear tire. (bad Mickey Mouse mounting system I set up) Tore them up pretty good. Took them to a shoe repair guy in La Paz and for about $5 he totally rebuilt the torn up sections. I have two other sets of soft bags, to me they are all expendable. On rough trips they don't last ... except perhaps the new Wolfman ones. I find bags cheap all the time on Craig's list, like $50 or less. |
06-13-2010, 09:37 PM
#36206 |
Oddometer: 920
Race Tech Emulators
This thread is invaluable when tackling a project.
Distech's install worked perfectly. Thx for that! http://www.advrider.com/forums/showt...+dr650+rebuild Read his thread first as mine is just some personalized additions to Distech's outstanding post. Definitely follow his advice on the homebuilt tool measuring 30mm. I took a caliper and wandered to several stores and came home with the 28.?mm and it turned in the tube. Find a good hardware store and get the right one to start. I tightened the bundle but it turned during heavy hammering (to get the allen head loose). I ended up drilling at a 45 degree into the nut, thru the bolt & inserting a screw in the hole to "pin" the two together. Here's the stock spacer, spring & bottom washer with inside tube dropped down. ![]() Frontless DR ![]() Measuring the compression relief holes, 20mm center to center. ![]() Build a fluid measuring device that suits you. I'm pretty sure I'm a decendent from the Murphy clan so I built one that wouldn't allow me to drop it in while measuring. It also hung in the center of the tube and was easy to see when it contacted the fluid. ![]() ![]() After pouring the recommended 14 ounces of fluid in and cycling the fork to get air out of it (easier with the emulator out), I tried dropping the unit in the tube. It got crossed up so I hung it from a magnetic tool and lowered it into the drink. ![]() Use the spring to hold the emulator in place and pull the magnet off of it. ![]() If you have a mechanical tool grabber, it's probably easier. I didn't. Get the emulator to seat in the tube, remove the spring and complete the fluid pour. In cutting my new spacer, the instructions said to draw a line all the way around to keep the cut even. This was my way of doing that. Set the caliper and work your way around the tube. ![]() Cut, debur & final surface on my $2 Home Depot glass with 320 grit. ![]() Got this cool (at least I think it is) tool from Motion Pro http://www.motionpro.com/motorcycle/partno/08-0412 It's blue, anodized aluminum & I need it. ![]() ![]() It worked as advertised and made the fork alignment "bounceless" for a no-binding result. Got the forkskins installed, lubed everything and torqued everything according to the manual. Black fork boots on the way to Yokomo. ![]() It was sure nice getting the "solution kit" from Procycle as everything I needed was included. Keep in mind I got heavier springs which are shorter than the stock ones so I set the (now too short) stock spacers aside & used the provided (kit) spacer material. My son-in-law did emulators also but with the stock springs. He cut the stock spacer (I'd recommend just getting some PVC ) which was time consuming.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... TrophyHunter screwed with this post 06-13-2010 at 10:19 PM |
06-13-2010, 09:46 PM
#36207 |
Oddometer: 5,393
[quote=D-Fuzz] The trip will be 2 weeks
Man, you guys will have NO time to explore. IMO, too many miles stuffed into to short a time. Mostly camping. We plan to stay in the dorms in Fairbanks and one of the motels in Deadhorse, other than that it will be camping. Cool. Setting up and tearing down always take time, but since its mid Summer up there you'll have daylight till Midnight. ![]() I was going to bring a set of front & rear tires to swap, but am maybe re-thinking that a bit. Maybe a rear tire will be sufficient. This is what I would do: Run a TKC80 up front. It will make the whole trip and be a God send on gravel, mud and any dirt roads. Better than the Kenda. I've used all kinds of 50/50's, the TKC or T63 Michelin are better and L A S T. DO bring a spare rear or send one ahead, just to cover yourself or one of your buddies. You can always mail it back if not needed. I have tubes (front & rear), patch kit, tools, tire irons, etc. to be able to make repairs along the road. Get together with your riding buddies and plan to use common tools, this saves weight. I have Kenda 270s which are supposed to be a 50/50 tire. I normally ride gravel with Michelin Anakees and am comfortable with them. Living in the prairies, you have no choice but to ride lots of gravel. This is good. 270's are OK but can be a bit squirreling on highway for some riders. But many swear by them, mostly KLR guys. I'd use a Knobbie. More drive getting through mud,sand or deep gravel patches, which will keep you upright and going straight. 50/50 tires don't bite well. More bite in deep gravel, and much better stopping ability on anything steep. Suerte Amigos Adv Grifter screwed with this post 06-13-2010 at 09:53 PM |
06-13-2010, 09:59 PM
#36208 | |
Oddometer: 175
06-13-2010, 10:30 PM
#36209 | |
Butler Maps
Oddometer: 14,443
i understand the concept of that fork aligner, but please explain some more how you adjust on the dr forks that are not aligned.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
06-13-2010, 10:49 PM
#36210 | |
Armature speller
Oddometer: 6,777
