Old 08-24-2010, 11:23 AM   #1
Wirespokes OP
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
Airhead wheel spline repair
Have any of you ever riveted in new wheel splines?
I know it's possible to bolt them in, and I've gone that route before, but would prefer rivets. I've heard that rivets can be tricky - possibly loosening (or maybe not completely tight to begin with) doing some real damage.
And I know they're a soft metal, not hardened or anything like that. Do they need to be heated? Is a press necessary or preferable?
Old 08-24-2010, 02:10 PM   #2
nella
nella's Avatar
Oddometer: 403
I haven't done it, but there was a thread on the airhead list in the last week and the consensus was that using bolts is the way to go but I was only paying minimal attention to that thread.
Scott
Scott
nella is offline   Reply With Quote
Old 08-24-2010, 03:21 PM   #3
TimTowtdi
TimTowtdi's Avatar
Oddometer: 247
I always thought it would be cool if someone made a piece that would sit inside the wheel and was threaded that you could just run the bolts into and tighten the cup to the wheel. It would be shaped and drilled and threaded to fit around the spline cup and allow a good clamp. Anyone with the tools want to try making one? I'll buy a couple.
TT
TimTowtdi is offline   Reply With Quote
Old 08-24-2010, 03:27 PM   #4
Ron In Buffalo
Ron In Buffalo's Avatar
Oddometer: 67
I had a wheel "Stake" twice after six or seven yrs the pins becomes loose and eventually they start to fall out. The last time I used nuts and bolts this seems to be holding up just fine. Also it is cheaper to use nuts and bolts. Ron
1999 Triumph Tiger & 1998 K1200RS
Ron In Buffalo is offline   Reply With Quote
Old 08-24-2010, 03:59 PM   #5
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,285
I usually rivet them. No heat, no press. Just a BFH & punch, a solid base, and a few precautions.
Old 08-24-2010, 06:13 PM   #6
Wirespokes OP
Wirespokes's Avatar
Oddometer: 8,234
Got any instructions up on your website?
I've heard the rivets are fairly soft, but work harden rather quickly. I'd imagine the proper bucks would be needed to retain the mushroom shape of the head, and to not mush the squished side.
Do you have someone hold the wheel against the buck? It sure seems like a three-handed job (minimum) to me.
Old 08-24-2010, 07:26 PM   #7
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
So does Bruno in Canada, cold rivetting. He's doing that to earn a living so he most likely won't come up with instructions of how to do it, understandably.
I understand that 12.9 or higher class bolts are necessary, definitely not stainless but who am I telling!
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 08-24-2010, 08:33 PM   #8
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Terry, send the wheel over to Hansens in OREGON, talk to Craig, tell him Robert from San Jose BMW says howdi, and have it done right.
rv
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 08-24-2010, 08:44 PM   #9
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,198
Old 08-25-2010, 02:51 AM   #10
AntonLargiader
Oddometer: 4,285
Absolutely send them to Hansen's. They do this all the time.
Old 08-25-2010, 08:29 AM   #11
Wirespokes OP
Wirespokes's Avatar
Oddometer: 8,234
I know, Hansen's is THE place to send them. Their repair of the final drive splines is a thing of beauty!
And that's the thing - I really like knowing how to do these things myself rather than depending on others to take care of my bikes.
Rivetting, I'm afraid, is turning into a lost art. Maybe I should hang around the airport and get to know those guys. I think aircraft are all rivetted together. Anyway, I was hoping someone here understood the tech and could reproduce a product comparable to the factory. Or at least tell me the factory used a special 200-ton press in a particular way unduplicatable by mere mortals such as I.
Old 08-25-2010, 09:35 AM   #12
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,161
The few times I've replaced a wheel cup I've used 1/4-28 grade-8 bolts, tapped the wheel hub and loctited them in. However, when I get my rear drive splines rebuilt I plan to send the final drive and wheel to Hansen's and let them do the whole enchilada (wheel cup and splines, including final drive bearings and shimming).
Your call.
'73 R60/5 Toaster
Old 08-25-2010, 09:37 AM   #13
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,849
When we train guys to rivet shroud to turbine blades we have them do a bunch of test pieces - perhaps you can do some simple mock-ups to get the hand of things
cut them apart to check for swell in the hole - and try to pull a couple apart
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is online now   Reply With Quote
Old 08-25-2010, 11:34 AM   #14
batoutoflahonda
Oddometer: 1,386
Been working on planes for years. Riveting is like most things. Practice. If you really want to be proficient, pick up the tooling you need, some practice rivets and metal (maybe even a cheap rivet gun and bucking bar) and start practicing. Also practice drilling them out so you don't screw the hole up.
It doesn't take to long to get feel for forming the rivet. The more you hit it, the harder they get. Even to the point of cracking. You can even practice with hole's that arn't perfect, and different lengths to get a feel for filling the hole. Heck, if I lived closer I'd give you hand.
The rivet gun and bar REALLY help.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 08-25-2010, 04:24 PM   #15
M37cdn
Oddometer: 43
Rivets
Lots of info on riveting here
http://www.bigflatsrivet.com/index.html
M37cdn is offline   Reply With Quote
Times are GMT -7.   It's 05:23 AM.
