Old 08-31-2010, 11:02 AM   #1
fencermatt OP
Oddometer: 4
Airhead Mainseal Tool in the Seattle Area?
Howdy everyone,
I am in the process of tearing down and rebuilding an '85 R80 engine in order to transplant it into a Dnepr. I'm planning on replacing the main seal, while I am in there, and I was wondering if any of y'all in the Seattle area might have the special BMW main seal driver tool that I could borrow? If you do I certainly would appreciate it.
Thanks,
Matt Pearsall
'94 KLR 650
88' Dnepr MT-16 (under construction)
fencermatt is offline   Reply With Quote
Old 08-31-2010, 12:14 PM   #2
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,103
I don't have the tool, but I just tapped mine in with a drift, slowly and carefully. Worked fine and hasn't leaked a drop.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Old 08-31-2010, 12:20 PM   #3
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,786
or just make a seal installer. Take a piece of wood or steel and drill 5 holes in the middle of it to line up with the ones in the crank. I used a metal cover for an electrical box.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 08-31-2010, 12:34 PM   #4
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,207
+1. I can validate this approach ... worked well on my bike.
Thanks Brad!
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 08-31-2010, 05:41 PM   #5
fencermatt OP
Oddometer: 4
That's a darn good idea. Thanks!
Matt Pearsall
'94 KLR 650
'88 Dnepr/BMW (under construction)
Old 08-31-2010, 05:52 PM   #6
jackd
Oddometer: 2,369
Use the flywheel bolt washer - the big washer with five holes in it that goes between the bolts and the flywheel as a template when drilling your holes. I built my own tool out of 1/2" Birch plywood. Works great.
Times are GMT -7.   It's 06:29 AM.
