Old 03-28-2010, 08:03 AM   #16
Toadride
Toadride's Avatar
Oddometer: 839
Yep. Get the CD from Sierra. Everything you ever wanted to know. I've just had mine in for her 30,000km service at the dealer where they checked valve clearance. Good as new, no adjustment necessary. And, FYI; the adjustment actually involves at least lifting or even removing one or both camshafts. So, make sure you know where you are going with this. Better still, pay the stealer.
Old 03-28-2010, 01:26 PM   #17
TheCowboy OP
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
Originally Posted by justplainray
it doesn't have sparkplugs are valves to adjust.
The dilithium crystals are housed in a sealed flux capacitor chamber. With dual teutonic phase coupling.
WTF plainray,? your sentence does not make any sense.
TheCowboy is offline   Reply With Quote
Old 03-28-2010, 01:31 PM   #18
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
Valve Clearance
I have been told by a guy who worked for BMW as an Instructor (maintenance) that to check to see if the valves need to be adjusted - they just put it on the computer and look at temperatures... If they are not in the proper perimeters then they will need adjusting...
TheCowboy
Old 03-28-2010, 02:53 PM   #19
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,732
TheCowboy
Thats a new one on me.
Are the cams directly or indirectly driven ? In other words, does the cam chain ride directly on the cam cog or a cog below it like on the LC8 motor ? It makes a big difference in ease of removal.
If anyone knows
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-28-2010, 02:57 PM   #20
DockingPilot
Oddometer: 9,732
If the shims need changing because the clearences are out of spec, then the respective cam must be removed to do so. If in spec, no need to remove the cam. This goes for either cylinder. The good thing I guess is its a 360' engine so both cylinders are TDC at the same time.
I believe.
Frank Reinbold
Old 03-28-2010, 04:32 PM   #21
TheCowboy OP
TheCowboy's Avatar
Oddometer: 606
It would be nice to see a "pictorial" of the valve clearance adjustment... anybody done that yet?
Also - a maintenance manual on CD from Sierra? Sierra what? or where? do they have a website?
TheCowboy
Old 03-28-2010, 05:01 PM   #22
justplainray
ucancallmeray
Oddometer: 260
fixed...
justplainray is offline   Reply With Quote
Old 03-29-2010, 11:10 AM   #23
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 625
TheCowboy
sierrabmw.com is where I got mine from. It's $100+ FYI! Nice to have. I got mine to dig inside to investigate my engine knock but haven't really done it yet. I did try to check the valves but the cam cover is obstructing the valves so you really need long feeler gauges to get at them IMHO.
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 10-31-2010, 10:56 AM   #24
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
Plug tool
E-mailed Marc and he didn't know for sure if that tool would work on the 800GS. Same cap but he wasn't sure about access. Have you tried it?
Originally Posted by sturgeon
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 10-31-2010, 10:58 AM   #25
Motoriley
Motoriley's Avatar
Oddometer: 2,685
Standard 5/8 spark plug socket?
Do you need a super thin wall or will a regular socket do? My 5/8" has a 21.35mm outside diameter and my 16mm has a 21.55 or so outside diameter if that helps. Both seem to fit my spare plug equally well.
Old 10-31-2010, 11:32 AM   #26
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Valve adjusting Step By Step.
http://www.advrider.com/forums/showthread.php?t=623587
will have to nominate this most useful thread to be in the index.... more than likely one of the most valuable assets Gspot has...
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider screwed with this post 10-31-2010 at 12:27 PM
Lost Rider is offline   Reply With Quote
Times are GMT -7.   It's 12:35 AM.
