Old 11-03-2010, 08:20 PM   #1
Motorfiets OP
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Cycra Handgaurds fit on a f800gs
Details tmrw...
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 11-04-2010, 09:39 AM   #2
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
You want parts?! Call this guy!! Finally a shop that I like to deal with!!
the goodies!
Problem A
- The stock bolt (part 5) has almost no shoulder that doesn't have thread. The inner thread is flush with the end of the bar. I also think the bar weight is shorter than the R1200
Pictures of the two bolts and sizes...
A shorter bolt will not work. took 3/4" off. Still no go!
Throttle lock works wonder however!
and so do the risers! 1-1/8" 2" rise. Work well. No Snagging the front brake cable. Might need to be longer gonna test it and see.
handgaurds mount right up though!
http://www.adventurersworkshop.com/
Tell Andrew that Ben sent you.
Ben
My Photo's
Old 11-04-2010, 11:51 AM   #3
digdesign
Hack
digdesign's Avatar
Oddometer: 151
Originally Posted by Motorfiets
Dude. You have some ugly feet.
2010 F800GS
2009 Buell XB12Scg FOR SALE
1990 E30M3 track rat
digdesign is offline   Reply With Quote
Old 11-04-2010, 12:37 PM   #4
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
That's funny.
Sick hardguards though.
Old 11-04-2010, 04:14 PM   #5
pretoria44
Oddometer: 22
so I had to tap the rest of the shoulder...
eyes on the prize!
she's ready!!!
throttle lock and all
rise and all
pretoria44 is offline   Reply With Quote
Old 11-04-2010, 04:16 PM   #6
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
oops!! uploaded on the wrong account...
Ben
My Photo's
Old 11-04-2010, 06:52 PM   #7
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,574
Are my eyes correct and you are using two sets of bar risers at the same time? I'm no engineer but that looks sketch to me!
soyanarchisto is online now   Reply With Quote
Old 11-04-2010, 07:37 PM   #8
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
They will twist. This I know.
johngil is offline   Reply With Quote
Old 11-04-2010, 09:20 PM   #9
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
He's not using two bar risers. He's only using the Rox risers clamped into the stock bar clamps. That's how the Rox risers work. Many are using the Rox risers with good luck and no twisting.
Old 11-04-2010, 09:25 PM   #10
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
They will twist. The independent rubber mounts and the extra height of the Rox risers aren't a very sturdy combo. That said, they are very easy to twist back.
Old 11-05-2010, 05:24 AM   #11
TowPro
Lets ride
Oddometer: 3,217
Does the 2" rox risers work with Bikes that have ABS (and not needing to replace brake lines)? I need something. Would love to go 2", but I thought I read 3/4" was the max if you have ABS?
I know my brake cables seem so long stock that they hit the HID headlight wires that I brought out straight through the back of the headlight access cover. A bar riser would fix this problem as well :)
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 11-05-2010, 06:20 AM   #12
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,737
Yes, the 1 3/4" Rox Riser appears to be special made for the F8. I have a brand new set (one week old) that I will sell you at a discount. They are too tall for me.
Fit just fine on my ABS model, with stock cables (close to limit, but ok). I did have to move my levers inward a bit. Being able to move the bars a bit closer to me (with the pivot) was very nice. I'm 5' 9", and this seem better suited to a 6'+ rider.
I switched to the TT 20mm riser posts. Came in last night. That's better for me.
Send me a PM if you're interested in purchasing my Rox (at a discount). Story of my life....buy high, sell low.
Installing the Rox appears tricky, until you figure it out. You have to put your original top clamps on loosly. Then, slide the Rox in from the side, and cinch it down strategically. Not hard, when the light bulb goes on.
HF
p.s. Cycras look great! I love my Cycras on my WRR....and was wishing I could put some on my F8. Currently have the plastic TT's. This will stay on my Bucket List. Thanks!
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 11-05-2010, 07:40 AM   #13
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
I went with 2" because I knew I'd be sliding them more forward. (less cable pull) the TT rises just pick them up straight back at you... with the rox I can pick them vertically straight up
Ben
My Photo's
Times are GMT -7.   It's 07:15 AM.
