Old 11-10-2010, 04:37 PM   #31
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,464
'07 R1200GS that shakes and shudders on braking...???
Originally Posted by bik3r1
I just purchased a used 07 GSA with 18k miles and it also has wheel and brake issues. Checked the front wheel and found it to be .065" out in the worst place, probably the weld from what I've read here. Also the left rotor is .0035" out! The bike seems to roll along fairly well with some vibration in the handlebars and then really gets shakey with a light touch on the front brake and not so much when applying more pressure. Before I start buying new parts thought I would check in here to see what the opinion of the group is considering the numbers.
I also have an 05 GS, it has 35k on it and none of the issues that the 07 has. Are the wheels and brake rotors interchangable between these two bikes? I know that the ABS sensor ring is different, anything else?
Thanks for any help you can offer!
welcome to X-laced wheel ville,,,you are not the first to note those anomallies...
FYI,you happen to be rather lucky because you can quickly swap out your two front wheels and check the shake and shudder issues your '05 front wheel ..your problems should reverse...
FYI ,,,alot of the shake ing comes from your rear wheel transferring its out of roundness to the handlebars via the frame ,especially in sweepers..all correctible
don't worry about the ABS rings for the sake of the test,,,i believe they will simply show an error code....
holler if ya need more help
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Times are GMT -7.   It's 10:33 AM.
