Old 11-22-2010, 01:09 PM   #1
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
New Owners - Stupid Questions Thread
Here's a place for new owners to ask those "stupid" questions. The kind you're embarrassed to ask for fear of being laughed at, or lectured for being such a noob. Questions like: Where's the fusebox? or What does OBC stand for?
Then hopefully some wise BMW sage who, feeling ambivalent or simply bored, cruises by might share said wisdom with grace and style.
Since I seem to be a frequent violator, I'll start this Thread by asking my next stupid question:
"Is something wrong with my fuel range calculator on the display? It never reads higher than about 110 miles, after I refill the tank. It seems to wait until the fuel level falls below a certain level, then it begins a countdown from 100 toward zero. Is that the way all the OBC's work?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is online now   Reply With Quote
Old 11-22-2010, 01:19 PM   #2
itsatdm
itsatdm's Avatar
Oddometer: 4,873
See the little arrow next to the mileage est? When on it means greater than. What mileage the instrument shows seems to vary among bikes and even on the same bike at times. It is not accurate because of the shape of the tank, except for the grossest measurement. Mine usually starts in the ^12? range than slowly increases. Once the arrow disappears it is supposedly measuring true mileage estimate. Mine still varies, being pessimistic until it gets down to about 80 miles.
Old 11-22-2010, 01:53 PM   #3
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
This symbol ">" displayed on the fuel range means greater than.
The crux is that most BMW bikes including the F800 have strange shaped fuel tanks. The fuel level sensor is not in a place to be able to tell just how full the tank is, but simply that there is more then 2.4 us gallons.
So if your tank is fullish, all the computer knows is that there is somewhere between 2.4 and 4.2 us gallons.
As such, the computer assumes worst case (2.4) and displays the ">" symbol to let you know that your range is likely at least X miles, but may be much more.
Once fuel gets down to a level the sensor can read, the ">" symbol will disappear and live computations will commence.
As far as I know, the only thing changed on newer models is that the range does not count to zero but rather changes to display "--" when range is very low. I do not know if software updates will change this functionality on older models.
Note: the OBC estimates range bassed on averages of past performance, current rate of usage, and other factors.
The OBC's estimate of your range is just a guess. The computer has pretty good information of what has happened in the past, but no idea what will occur in the future. Changes in terrain, elevation, wind, fuel energy content, riding style, payload ect are beyond it's capabilities to control for.
Take the range as a potentially helpful estimate at best.
When the low fuel light kicks on, at best, you really need gas soon!
Actually since BMW is not known for sourcing the best fuel level sensors, there is no reliable substitution for an awareness of how many miles ago the tank was filled versus what demands have been placed on the fuel since.
I strongly encourage use of a trip meter :)
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 11-22-2010, 01:59 PM   #4
YamWOW!
YamWOW!'s Avatar
Oddometer: 460
HF
Subscribed!
YamWOW. It's made in Japan, you know the Japanese make good stuff!
Check out the WR250R/X forum: CLICK HERE
Check out the Pacific NW DualSport Forum: CLICK HERE
KTM 530 EXC-R
BMW F800GS
YamWOW! screwed with this post 11-22-2010 at 02:07 PM
YamWOW! is offline   Reply With Quote
Old 11-22-2010, 02:59 PM   #5
Emperor Norton
Kilroy was here
Emperor Norton's Avatar
Oddometer: 1,203
HF
Get your bikes software updated and you wont have that issue with the OBC. It'll give no distance and then after you hit reserve show you miles ridden on reserve.
Here's a dumb question: Is it bad to use heated grips in the rain?
Emperor Norton is offline   Reply With Quote
Old 11-22-2010, 03:40 PM   #6
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,225
Only if you hate warm hands.
MCMXCIVRS is offline   Reply With Quote
Old 11-22-2010, 04:04 PM   #7
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
.....and then after you hit reserve show you miles ridden on reserve.
And on that note; what is meant by 'reserve' on this bike?
F800GS Grin Machine
KTM690E Grrr Machine
XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA
www.hoofrehab.com
SlowRide13 is offline   Reply With Quote
Old 11-22-2010, 04:16 PM   #8
Emperor Norton
Kilroy was here
Oddometer: 1,203
I don't have the manual infront of me, but IIRC its ~1.1 gallons remaining.
Old 11-22-2010, 05:40 PM   #9
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Excellent input....thanks for that info Itsatdm & Wiseman. I had not noticed the Greater Than symbol, and certainly didn't understand the inner workings. Does BMW not know how to measure volume progressively in the tanks they build? Seriously....not being sarcastic. Seems they would use the same mold to make the tanks the same way, and then be able to measure volume (by sensor height incrementally, very accurately. But what do I know?
Regarding Heated Grips in the rain....definitely no problemo! You will not create a short circuit or an dangerous condition by doing so. You're not very likely to be electricuted by the 10 amp draw (just guessing on amperage) under any condition. Well....er...a...unless you put your feet down and become "grounded". Another fine reason to keep your feet on the pegs!
HF
p.s. What does reserve actually mean on this bike? Would that be when the fuel range counter begins decrementing or when the fuel light comes on? So, would that mean 2.4 gal or 1.1 gal or what?
Old 11-22-2010, 09:35 PM   #10
itsatdm
itsatdm's Avatar
Oddometer: 4,873
It varies between bikes. I have run mine close to 0 miles a few times and I had .8 gal left. Fuel light usually comes on around 40 miles to empty, so guessing at that point 1.5 gal. Something you are better determining yourself.
Old 11-23-2010, 06:57 AM   #11
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Very interesting, Itsatdm. I'll have to pack some fuel and go run her dry to test this. Seems to be an odd configuration of communication. Countdown to zero, but still have 35 - 40 miles of range remaining. I'd think (or hope) the fuel light and the fuel range counter were sync'd together closer than that. Of course, I understand the fuel range is a computation based on running average for mpg. But still, it ought to be dialed in closer than that.
Nevertheless, it is what it is. So, good advice I think....to go find out for myself. There's that "Knowing" issue again.
Now, come on new owners, I know you have some more stupid questions you want to ask. See what great info came out of the last question? I need your help, as I'm too stupid to even think of all the stupid questions. But here's another:
"If I perform my own oil changes, does that violate my warranty?"
Does all service really have to be done by a certified BMW mechanic to maintain warranty rights? Seems they have a loophole (or more likely "loop-out" at every turn). So, I just want to know....for sure. Is there a real policy rule regarding this issue. Because I'm surely not going to take my bike into the shop for basic service maintenance....like re-adjusting chain tension, bleeding hydraulics in the brake lines, etc. Where's the line drawn?
HF
Old 11-23-2010, 07:39 AM   #12
KnuckC
F8er
Oddometer: 199
Here in Canada, I believe that owners are permitted to service their vehicles wherever they want and are not limited to the dealer. Of course if the dealer can establish that the service was performed improperly and problems arose directly from that improper service then warranty may not cover the issue.
KnuckC is offline   Reply With Quote
Old 11-23-2010, 07:46 AM   #13
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,545
Does removal of the charcoal canister void any of the warranty?
soyanarchisto is offline   Reply With Quote
Old 11-23-2010, 10:20 AM   #14
itsatdm
itsatdm's Avatar
Oddometer: 4,873
There is a Federal Statute that gives consumers protection and many/most states have there own consumer protection laws. It is a voluminous law written and probably only understood by lawyers, here is a short version.
http://www.dummies.com/how-to/conten...ty-intact.html
I have done the typical oil and filter changes, but left the first valve check to BMW. Mainly I did so that so there was no question about the warranty back when I was having issues and because the BMW manual had no info on the shim measurements in case I needed one.
I fully documented what I did with photo's, showing mileage, parts and different stages of the service.
Re: adding and removing parts. If BMW can show a direct connection between what mods you have made and the subsequent damage as to a result to a specific componant, they can void that componant from warranty coverage.
I think I have mentioned, BMW has a lot of Lawyers, use your own descretion.
itsatdm screwed with this post 11-23-2010 at 11:22 AM
Old 11-23-2010, 01:00 PM   #15
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
I document my oil/filter changes and other fluids with pix, but have decided to keep paying BMW to do the torque check of all the fasteners (and the rest of the service). I figure if a part failed or fell off I would be 'holding the bag' if I had torqued the fasteners myself.
F800GS Grin Machine
www.hoofrehab.com
Times are GMT -7.   It's 06:35 AM.
