12-01-2010, 09:32 AM
#106 | |
I have little to say
The sounds of a vertical twin on song at 6000RPM and above gave me goosebumps! |
12-01-2010, 10:31 AM
#107 | |
Dan. |
12-01-2010, 01:21 PM
#108 | |
Mod-U-Later
Oddometer: 13,576
JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
12-01-2010, 06:07 PM
#109 |
The flywheel and any other moving parts powered by the engine creates parasitic loss. It takes energy to increase the RPM of the flywheel, energy that could be used to accelerate.
I also laced mag rims onto both front and rear wheels, further reducing loss. And while I never dinoed the engine, the bike was the fastest accelerating street motorcycle (pump gas) for several years in my neck of the woods. I estimate 65 hp at the crankshaft (1960 stock bore and stroke 650 CC Triumph with a splayed head, which I fabricated myself and twin Amal carbs). |
12-02-2010, 12:35 AM
#110 |
I agree that a flywheel takes power from the engine but I was thinking that since the most power would be directed to the rear wheel, the flywheel would not consume that much power.
And, why didn't they design a smaller diameter flywheel and a more powerfull starter engine ? That would have been a big plus in flywheel bottleneck ;) Dan. |
12-02-2010, 06:20 AM
#111 | |
Oddometer: 1,139
It's not a bottleneck of sorts but a basic design element/parameter that contributes to how the bike runs. And you can manipulate that by adding or reducing the weight of it.
youmoveyou |
12-02-2010, 07:18 AM
#112 | |
Oddometer: 867
So, for a BMW S1000RR, a lighter flywheel is going to help as you arn't loading it up for a transcontinental off-road journey. Put that same flywheel on a R1200GSA and you'll be cursing at it as you will have to rev your engine to 4000 rpm just to start moving - the GS is more of a tractor than you think!
David Marshall - Quesnel, BC, Canada 1997 BMW R1100 GS (4 Sale) / 2006 BMW F650 GS / 2009 Suzuki DRZ 400S and a bunch of 4WD Volkswagens! |
12-02-2010, 07:22 AM
#113 |
Thanks all for the enlightening posts ;)
Dan. |
12-02-2010, 07:50 AM
#114 | |
Somebody mentioned starter motor? Yes, your right leg! |
12-02-2010, 07:55 AM
#115 |
12-02-2010, 08:05 AM
#116 | |
Also, to improve acceleration, loose 20 lbs of body weight....those racers are usually little guys...loosing weight is the same as hotrodding...same net effect...more acceleration.
12-02-2010, 08:10 AM
#117 |
There's plenty acceleration for me on my RT. I rode a friend's GS after doing meintanance on the bike and it was weird... The GS seems so much lighter... It accelerates faster than the RT, way faster, maybe because of FD ratio and less weight on the GS.
Anyway... I can't wait for this product to be released on the market! When is that going to happen?? Dan. |
12-02-2010, 08:12 AM
#118 |
Dog Rancher
Oddometer: 4,188
This flywheel talk reminded me of the Stealthy flywheel weight I put on a YZ250 two stroke. Here is their explanation:
"About Steahly Offroad When we started making flywheel weights in 1987 very few riders understood the benefits of adding flywheel weights. Since then the popularity of adding flywheel weights has increased dramatically. More and more riders discover that they can go faster for longer with the smooth power delivery, better traction, and reduced stalling that Steahly Flywheel Weights provide. Adding a flywheel weight will increase the rotating mass, or inertia, of the motor. The result is an engine that is a little slower to rev, has more controllable power delivery and less hard hitting power, a more usable low to mid-range, and is less likely to stall at slow speeds or with the rear brake. What you will feel is better traction when it is slippery or hard pack, a torquier and broader powerband, and the top end power on many bikes will be improved with less tendency to lose RPM’s when climbing or hitting obstacles. The easier to control power will help you conserve your strength and energy, plus many bikes start easier with the added weight." http://www.steahlyoffroad.com/about-steahly-offroad
12-02-2010, 09:28 AM
#119 | |
FNG
Oddometer: 71
12-02-2010, 09:37 AM
#120 | |
Oddometer: 1,139
This is not a hijack - more like a conversation while we wait!
Some in action... too bad I don't have a close up of the motor for you. It is a period correct Geoff Monty Special frame and GoldStar engine. The bike is producing high 50's hp. All hand made and built - frame up by my friend Ken Rosevear. All polished alu and gobs of magnesium... very very nice bike for me to ride. Sorry for the photos they are a bit corny as they were used for sponsors... ![]()
youmoveyou |
