Old 12-05-2010, 09:03 AM   #61
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
The new arm is here. After some cleaning, it's looks great.
Pablo83 is offline   Reply With Quote
Old 12-05-2010, 09:09 AM   #62
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
So I decided to finish destroying the old one just because I'm curious. I drilled off the heads of the bolt holding the arm on. Then I smacked it with a hammer until the epoxy broke. This took a lot of force. Here's what it looks like underneath.
The round hole is the one I drilled, but as you can see, there was already a lightening hole molded into the inner part of the swingarm.
I took a wire wheel to the swingarm to remove all the epoxy. Once the epoxy is gone you can go through the aluminum fast so it's a touchy process. After I removed all the epoxy and placed the arm back to the center section, there was enough slop that the swingarm would need to be placed in a jig to re-weld it. Clearly, trying to weld the arms to the center section is a failure on many levels and I won't be trying it again.
I also learned that this bolt is not removable:
Old 12-05-2010, 11:55 AM   #63
DisTech
DisTech's Avatar
Oddometer: 616
Great info!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 01-16-2011, 02:44 PM   #64
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Great info, thanks for figuring all of this out for us. Im looking forward to what you find out to decide what to do to mine.
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 01-19-2011, 02:55 PM   #65
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
I finally had some time to get back to this project.
holes drilled in the new swingarm:
I finally got to use this fancy tool. I've had it for years and never used it.
I made the shape in cardboard first, then aluminum
And then I welded it all up. It was difficult welding the section around the brake bracket due to the difference in thickness of the pieces. The brake seems to mount just fine.
And here's the other side finished. I later had to grind down the welds around the two chain-stay hole to get it to mount.
I weighted the swingarm before and after. These modifications added 13oz.
Pablo83 screwed with this post 01-19-2011 at 03:09 PM
Old 01-19-2011, 03:18 PM   #66
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
Why did you do that?
a1fa is offline   Reply With Quote
Old 01-19-2011, 03:19 PM   #67
DisTech
DisTech's Avatar
Oddometer: 616
Nice work! Hard to believe how much more stout that looks.
Old 01-19-2011, 03:22 PM   #68
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
Start with post #2
Old 01-19-2011, 03:34 PM   #69
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,855
Start with post #2
Yes I am subscribed, but I am not seeing the point Pablo :(
Old 01-19-2011, 03:49 PM   #70
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
to reduce swingarm flex.
Old 01-19-2011, 04:04 PM   #71
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Years ago when people rode DR350s hard Scotts sold stiffer swingarms that were said to make a huge improvement. I think Thumper also sold plates to be welded in just like you've done that were also reputed to be quite an upgrade. The swingarm is very flexy, just grabing and twisting the ends with the wheel removed it is notably less stiff than my XR or CR. Not an issue for casual dual sporting, but it does make it difficult to keep the bike pointed straight when the pace quickens.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-20-2011, 09:14 AM   #72
yondering
yondering's Avatar
Oddometer: 1,100
How did you weld it without overheating/destroying the epoxy in the joints? Or do you know if you damaged it? The damage to the epoxy probably won't be visible.
yondering is offline   Reply With Quote
Old 01-20-2011, 09:48 AM   #73
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
After my failed initial attempt to weld up the swingarm I ground out the welds, drilled out the bolts, and broke the epoxy so I could see how the swingarm was assembled. Despite all the welding I did on that swingarm, the epoxy was still incredibly hard to break, so I'm assuming it's still strong on this one.
Old 01-20-2011, 09:49 AM   #74
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,814
I'm removing the manual decomp from this bike. Where do I find a plug to cover the hole in the valve cover?
Old 01-20-2011, 11:45 AM   #75
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 134
Three ways to go..
1: I did this om my -97 head with autodecomp that fore some reason had the manual decomp axle to. Since I had the cover loose I removed the seal, drilled the hole (with a stationary drill) to 10.5mm and tapped for M12 and loctited a M12 stop screw into it.
2: If you don´t have the stuff to do this, simply keep the seal and modify (cut of) the part of the shaft that engages with the cam shaft.
3: Remove the seal and plug the hole with a plug. Where to get it? Dunno. That´s why I did it my way.
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
