Old 12-05-2010, 06:22 AM   #91
LukasM
Oddometer: 5,418
Originally Posted by ba_ View Post
I was looking at the VM2 with sprockets here:
http://www.sprocketcenter.com/p/1071...gs-09-10-.html
Like I said, the VM2 is also a good chain and will last much longer than stock - and most importantly it won't break! I just don't enjoy maintaining or changing wear parts so I would rather spend an extra $30 to get the best.
Old 12-05-2010, 06:24 AM   #92
ba_
ba_'s Avatar
Oddometer: 2,757
Since this is the stupid question thread, I'll now ask the stupid question. What's the difference between the two chains?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 12-05-2010, 12:12 PM   #93
ba_
ba_'s Avatar
Oddometer: 2,757
What is the easiest way to remove the chain (assume I will throw the OEM one away)?
Ok back to this question.
It is an endless chain, correct? Don't you have to either a) remove the swingarm or b) break the chain in order to remove it?
Old 12-05-2010, 12:20 PM   #94
LukasM
Oddometer: 5,418
The ZVM-X is heavier duty. Thicker outer plates, longer pins, thicker rollers. About 15% higher wear rating IIRC.
Buy a chain breaker/riveter. On big heavy bikes with a decent amount of power a clip type link is not a good idea.
LukasM screwed with this post 12-05-2010 at 12:45 PM
Old 12-05-2010, 01:39 PM   #95
ba_
ba_'s Avatar
Oddometer: 2,757
Thanks Lukas. I was planning on buying the Motion Pro breaker/riveter. I just couldn't get my head around that you could remove an endless chain without breaking and/or removing the swingarm.
Old 12-05-2010, 02:35 PM   #96
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,771
If you're not going to use the old one again just cut it off, that's what I do with my old ones. When installing a new chain I use my rivet tool, master links should only be for emergencies.
EnderTheX is offline   Reply With Quote
Old 12-08-2010, 05:52 AM   #97
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Guess we've run out of "Stupid" And so soon.....
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 12-08-2010, 09:08 AM   #98
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 795
I'll bite...
Why would BMW attach the left side controls with a THROUGH bolt?
Why did they extend the license plate light out 2"?
Simple fix...
Cheers,
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 12-11-2010, 10:56 PM   #99
nat_han
2 Wheelers By Choice.. =]
nat_han's Avatar
Oddometer: 200
anyone notice a 'female' socket/connector between the air intake pots behind the engine?
can be seen from the left side of the bike. look between the gaps in the frame, somewhere slightly above the clutch cable.
is the socket supposed to have any sort of cover? it is hanging exposed to whatever dirt/particles that might get into it...
what and why is it like that? NORMAL?
(will try to get a picture asap)...
nat_han is offline   Reply With Quote
Old 12-13-2010, 02:35 PM   #100
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
I guess nobody knows....RediRakaD & Nat_han. I don't either.
But, here's my next Stupid question:
Anybody running a "Case Saver" over their counter sprocket? If so, which brand from where?
The only one I've found is listed at TT, but it doesn't show a picture of the inside...the "case saving" part.
This past weekend, I swapped out my 16 cs for a 15 cs. When I pulled the plastic cover off, it was like........ No protection whatsoever. This appears to be an extremely vulnerable area needing a decent case saver (in the event of a broken chain). And, I didn't find a thread regarding this matter.
HF
Old 12-15-2010, 02:17 AM   #101
nat_han
nat_han's Avatar
Oddometer: 200
(the plug my index finger is pointing at)
this is the 'loose' or rather, a disconnected plug behind the engine that i was talking about. noticed it just recently after 2years...
viewed from the left side of the bike.
any ideas as to what this plug does?
my bike still fires up and moves...
Old 12-15-2010, 03:19 AM   #102
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,386
Eh? Grips
My stupid question is how does one change grips when they are heated? Mine are wearing out....and I would like to replace the stock grips with one's a little wider but how do I safely remove them when there are heated elements underneath?
soph9 is offline   Reply With Quote
Old 12-15-2010, 06:37 AM   #103
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Very carefully. I'm about to find out, as I have same problem. I'm going to slice the original hot-hand grips off with a razor blade and carefully peel it off the heating element. It should be doable, as the grips should not be glued to the heating element. And that has been confirmed in other Threads about this same issue....i.e. others have done this successfully.
Then, I'll probably tape each end of the heating grid with a little wrap of electrical tape...to help keep it secure when sliding on my new Progrips. I'll probably lube my new grips with some Windex to help it slide over....which will evaporate soon enough.
Gonna tackle it this weekend.
HF
Old 12-15-2010, 07:39 AM   #104
inmate-n00b
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
Have you heard of grip puppies?
http://www.casporttouring.com/cst/mo...s/GRIPPUP.html
They slide over your stock grips.
That may be a better/cheaper/faster solution.
inmate-n00b is offline   Reply With Quote
Old 12-15-2010, 07:50 AM   #105
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,886
Questions
What is
  1. FF
  2. Troll (motorcycle sense)
devo2002 is offline   Reply With Quote
Times are GMT -7.   It's 04:38 AM.
