Old 12-04-2010, 04:34 PM   #46
brucifer OP
brucifer's Avatar
Oddometer: 2,384
$3000.00 is what the PO wanted for my '05 650. I ended up trading him an excellent shape '01 XR650R and $500.00 cash.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
For sale--1996 Honda XR600R--
brucifer is online now   Reply With Quote
Old 12-04-2010, 10:37 PM   #47
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,834
Originally Posted by bobzilla View Post
$3K
I doubt I could get that for mine (well used but maintained) so I just keep riding it and smilling
Thanks....that's what I was afraid of. He's asking $3850 and doesn't want to come down.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 12-05-2010, 06:57 AM   #48
Hair
Outside the boxer
Oddometer: 13,807
I'm seeing a few 550s for sale. Not to many 650s. My 650 only reved to less than 9000 rpm. While my 525 hit 14000 rpm. The 650 made strong torque everwhere. The 525 not so much.
So my question is: where does the 550 fall in on this curve? Is it a low rever like the 650? Or a high rever like the 525? Where does the torque start to really kick in.
I would love to pickup another tractor pulling rig.
With my feet on the ground, my nose in the air
I am riding just fast enough to feel the wind in my Hair.
Hair is offline   Reply With Quote
Old 12-06-2010, 07:55 AM   #49
wallache
wallache's Avatar
Oddometer: 378
Does anyone else find it impossible to find neutral while the bike is running? This is my first hyro clutch bike, so I wonder if this is a Husaberg trait or just user error.
wallache is offline   Reply With Quote
Old 12-06-2010, 08:11 AM   #50
LukasM
Oddometer: 5,386
What kind of 525 revs to 14000 rpms?
The KTM with it's long stroke engine doesn't go to 10000 either.
Old 12-06-2010, 08:39 AM   #51
brucifer OP
brucifer's Avatar
Oddometer: 2,384
My 650's kinda the same way. Not impossible but certainly harder than the Japanese bikes I've owned. I usually just click it into neutral as I'm rolling to a stop.
Old 12-06-2010, 10:41 AM   #52
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
1995 501
The guy I got this bike from said that it was owned by Rick Boseworth of Portland OR husaberg fame. I dont know if this is true or not but it was in good shape for its age and ran fast, I never had a problem with it.
jessepitt is offline   Reply With Quote
Old 12-07-2010, 05:43 AM   #53
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,834
A couple more questions about the '06 FE550E...
* Oil capacity - don't see it listed in official specs, only mentioned in the occasional oil thread at ~ 1 liter.
Is it like the KTM RFS and all in one place, or like the newer motors and in separate transmission and crankcase volumes?
* The one, large radiator - easy to put a fan kit on? Does it tend to run hot in slow technical stuff, or does that radiator do a good job?
Battery - Is there a common upgrade similar to the KTM RFS, like swapping the Yuasa YTZ7S or YTX5L-BS battery in place of the weaker YTX4LBS. (and is there room for a bigger battery). Important if running a fan...
Old 12-07-2010, 05:51 AM   #54
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
The rad has holes in it for a fan. Seems to run cooler than my 525 ever did. Just like the RFS bikes in the oil dept. I just upgraded to one of those new style lightweight lithium batteries.
Just say'IN
crankshaft is offline   Reply With Quote
Old 12-07-2010, 07:56 AM   #55
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,834
thank yeeew...
How about stator rewinds? I emailed Rickystator to see if they were the same unit as KTM RFS, or if they rewound 'berg stators.
I saw the Sparks rewind thread in Husaberg Unofficial as an option as well, and floating the ground.
IF I pick up this bike, I don't plan on running tons of accessories...no heated gear, etc. Most likely an 8" racelight in reasonable wattage, and a GPS (no current draw at all practically speaking)
I just want to keep the battery charged and be able to run a fan and a decent light.
Old 12-07-2010, 09:44 AM   #56
Huskyfatman
Huskyfatman's Avatar
Oddometer: 1,241
thank yeeew...
I think Hair used a Trail Tech stator, but my memory's bad. My '05 is a Euro street legal model and has the headlight a tail light running of the AC lead, and the battery (DC) runs the horn and turn signals, works pretty good. 60watt headlight is max, with an LED tail light, at least on mine. The Trail Tech race light with a 55w bulb does pretty good.
My 650 boiled over 2 times early on, but the '06 and up had better air flow from a redesigned tank. I bought a fan kit, but overheating hasn't been a problem with the Clark tank. Also, '06 and up have a bung in the radiator for the fan's temp sending unit. If I ever install the fan, I'll put a switch on it as I think runs even after you shut off the engine.
http://www.sharetrails.org/
http://www.americansandassociation.org/
"YOU KNOW. . . . . .WE ARE LIVING IN A HEAT LAMP SOCIETY!"-Ron Perez 2002
Huskyfatman is offline   Reply With Quote
Old 12-07-2010, 11:41 AM   #57
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,834
thanks....there's a wealth of information out there, and I'm beginning to scratch the surface of it a bit.
It's super easy to get a bike plated in CO, beyond that I'd like it to be done right with possibly a Trick dualsport kit....I emailed Dale the other day.
I see that Clarke has their 4 gallon tank on their site for $188....cheaper than my 'usual' place, JustGasTanks.
Old 12-07-2010, 03:36 PM   #58
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Even with the discount?
www.JustGasTanks.com 5% discount to ADVrider inmates, coupon code: Advrider
Old 12-07-2010, 04:47 PM   #59
crankshaft
crankshaft's Avatar
Oddometer: 14,003
thank yeeew...
I'll let you know how my stator upgrade works out. I've got the stock stator that I pulled out of my 400 EXC, so I'm going to pull the side cover off my 550 and see if they're the same. I think they are but I want to be sure before I buy the TT kit. I'm running my 550 in a Rally in February and the last stage is usually in the dark, so I'll need the DC power for an HID headlight.
Just say'IN
Old 12-07-2010, 05:57 PM   #60
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Take a look at the LEDs in my sig
I'm gonna put a couple of the 10 watts on my 98 400FE
Times are GMT -7.   It's 06:22 AM.
