12-04-2010, 03:34 PM
#46 |
Oddometer: 1,619
$3000.00 is what the PO wanted for my '05 650. I ended up trading him an excellent shape '01 XR650R and $500.00 cash.
2006 KLR650 2002 Yamaha FZ1-2002 Husaberg FC550E w/2008 FE550E engine-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
12-04-2010, 09:37 PM
#47 |
r-u-n-n-o-f-t
Oddometer: 12,174
Thanks....that's what I was afraid of. He's asking $3850 and doesn't want to come down.
IBA #11735 . 1968-present |
12-05-2010, 05:57 AM
#48 |
10 fingers 10 toes
Oddometer: 12,006
I'm seeing a few 550s for sale. Not to many 650s. My 650 only reved to less than 9000 rpm. While my 525 hit 14000 rpm. The 650 made strong torque everwhere. The 525 not so much.
So my question is: where does the 550 fall in on this curve? Is it a low rever like the 650? Or a high rever like the 525? Where does the torque start to really kick in. I would love to pickup another tractor pulling rig.
Why are we stopping?: Wayne Weber |
12-06-2010, 06:55 AM
#49 |
Oddometer: 369
Does anyone else find it impossible to find neutral while the bike is running? This is my first hyro clutch bike, so I wonder if this is a Husaberg trait or just user error.
12-06-2010, 07:11 AM
#50 | |
Oddometer: 4,900
![]() The KTM with it's long stroke engine doesn't go to 10000 either.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
12-06-2010, 07:39 AM
#51 |
Oddometer: 1,619
My 650's kinda the same way. Not impossible but certainly harder than the Japanese bikes I've owned. I usually just click it into neutral as I'm rolling to a stop.
12-06-2010, 09:41 AM
#52 |
Dual Sport Addict
Oddometer: 987
1995 501
The guy I got this bike from said that it was owned by Rick Boseworth of Portland OR husaberg fame. I dont know if this is true or not but it was in good shape for its age and ran fast, I never had a problem with it.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
12-07-2010, 04:43 AM
#53 |
r-u-n-n-o-f-t
Oddometer: 12,174
A couple more questions about the '06 FE550E...
* Oil capacity - don't see it listed in official specs, only mentioned in the occasional oil thread at ~ 1 liter. Is it like the KTM RFS and all in one place, or like the newer motors and in separate transmission and crankcase volumes? * The one, large radiator - easy to put a fan kit on? Does it tend to run hot in slow technical stuff, or does that radiator do a good job? * Battery - Is there a common upgrade similar to the KTM RFS, like swapping the Yuasa YTZ7S or YTX5L-BS battery in place of the weaker YTX4LBS. (and is there room for a bigger battery). Important if running a fan...
12-07-2010, 04:51 AM
#54 | |
Guns are for pussies
Oddometer: 13,783
The rad has holes in it for a fan. Seems to run cooler than my 525 ever did. Just like the RFS bikes in the oil dept. I just upgraded to one of those new style lightweight lithium batteries.
Just say'IN |
12-07-2010, 06:56 AM
#55 | |
r-u-n-n-o-f-t
Oddometer: 12,174
How about stator rewinds? I emailed Rickystator to see if they were the same unit as KTM RFS, or if they rewound 'berg stators. I saw the Sparks rewind thread in Husaberg Unofficial as an option as well, and floating the ground. IF I pick up this bike, I don't plan on running tons of accessories...no heated gear, etc. Most likely an 8" racelight in reasonable wattage, and a GPS (no current draw at all practically speaking) I just want to keep the battery charged and be able to run a fan and a decent light.
12-07-2010, 08:44 AM
#56 | |
Oddometer: 512
My 650 boiled over 2 times early on, but the '06 and up had better air flow from a redesigned tank. I bought a fan kit, but overheating hasn't been a problem with the Clark tank. Also, '06 and up have a bung in the radiator for the fan's temp sending unit. If I ever install the fan, I'll put a switch on it as I think runs even after you shut off the engine.
http://www.sharetrails.org/ http://www.americansandassociation.org/ "Yeah, well, you know, that's just, like, your opinion, man"-THE DUDE |
12-07-2010, 10:41 AM
#57 |
r-u-n-n-o-f-t
Oddometer: 12,174
thanks....there's a wealth of information out there, and I'm beginning to scratch the surface of it a bit.
It's super easy to get a bike plated in CO, beyond that I'd like it to be done right with possibly a Trick dualsport kit....I emailed Dale the other day. I see that Clarke has their 4 gallon tank on their site for $188....cheaper than my 'usual' place, JustGasTanks.
12-07-2010, 02:36 PM
#58 |
Purveyor of Light
Oddometer: 3,646
Even with the discount?
www.JustGasTanks.com 5% discount to ADVrider inmates, coupon code: Advrider
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
12-07-2010, 03:47 PM
#59 | |
Oddometer: 13,783
Just say'IN |
12-07-2010, 04:57 PM
#60 |
Purveyor of Light
Oddometer: 3,646
Take a look at the LEDs in my sig
I'm gonna put a couple of the 10 watts on my 98 400FE
