Old 12-11-2010, 10:20 PM   #61
mtb_man
Unfettered
Oddometer: 171
The journey of 1000 miles begins with a eBay RC8R motor and some determination...
Keep us posted.
04 KTM 950 ADV
08 KTM RC8
Gone but not forgotten:
06 KTM Super Duke,
05 Kawasaki ZX636, 05 Suzuki DR650
When you are great, candor is often perceived as arrogance.
mtb_man is offline   Reply With Quote
Old 12-14-2010, 05:19 AM   #62
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
Just joined this forum and reading what my workshop tenant has in store for the pit bike...crasy!
I look forward to recieving the engine in the mailbox....
Locul, write the hill climper dude and ask for the drawings of the custom brackets on each side of the engine. Then we find some local who will carve them in wood or even better...alu.
Søren
SorenSand is offline   Reply With Quote
Old 12-14-2010, 12:31 PM   #63
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
So many great ideas...which to choose
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 12-17-2010, 12:22 PM   #64
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
Got a pallet of power today.
Comparison right away.
KTM 530 EXC-R 08
Old 12-17-2010, 12:55 PM   #65
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
too many sexy engines on the bench I dont think I can take it anymore
looks like its time for some welding and grinding...
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 12-19-2010, 09:04 AM   #66
yellowbronco
yellowbronco's Avatar
Oddometer: 209
There has been mention that the oil tank will be an obstacle to installing this engine in the Adventure. Looks to me like it just takes up the space where the battery resides on the LC8. Just find a new spot for the battery and you're golden.
Question: Do you expect the stock Adventure radiator to be sufficient? What are your plans as far as cooling?
Tom
08 KTM 320 SXF, '07 Beta Rev 3,
Frankenberg 501, '96 Husaberg FC600, '68 Yamaha DT1, '74 Bultaco Alpina 250, '84 Husqvarna WR400 - My Dad says I've never seen a motorcycle I didn't want to own...
yellowbronco is offline   Reply With Quote
Old 12-19-2010, 12:10 PM   #67
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
Battery is already under the seat.
I´ve been looking only slightly into this problem which cooler to choose.
RC8R runs 2.6l
LC8 runs 2.1l
THe extra 0.5l have their rights i think.
Will have to try an RC8Rs standardcooler. Though it would be difficult, regarding full suspension use(which i plan for).
The garage i work in, is getting a new floor and the cement need to cure. In 10 days there should be a go on this. Tearing down the Old and try to measure something useful.
KTM 530 EXC-R 08
Old 12-19-2010, 03:40 PM   #68
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
If the oil tank doesnt fit, i'd remove it and fab one to fit under the seat, similar to powercells.
Standard radiator could be used, instead use a second cooling fan, and oil cooler (if it doesnt already have one)
Interested to know the weight of it..
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 12-19-2010, 04:19 PM   #69
mookymoo
Mookish Mook
Oddometer: 4,393
The RC8 has a water-cooled oil cooler.
mookymoo is offline   Reply With Quote
Old 12-19-2010, 11:52 PM   #70
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
The RC8 oil tank will not be removed. It's casted as a part of the engine and there are no external hoses or tubes to lead oil from the tank to the engine.
W can't wait to get the bike up on the lift and strip it down...we will know so much after that!
Søren
Old 12-20-2010, 01:46 AM   #71
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
Like Søren said. We can´t move the oiltank as its a prat of the engine.
Actually i´ve thought about using the standard radiator with twinfans.
Weight, well my estimate would be a standard 950 adv(220kg empty + 10kg). I will try keep weight down using some of pete640 carbon stuff, bashi etc). Shorai battery http://www.shoraipower.com/p-155-lfx18a1-bs12.aspx.
BuTT at the end of the day, it will still be a graveltourer. If someone have any ideas, regarding weightsavings, buildwise...blabla...please join the thread.
KTM 530 EXC-R 08
Old 12-22-2010, 03:38 PM   #72
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
Radiator...
I have some questions regarding cooling?
It could shorten up my headache if i could keep my standard cooler/radiator. BUT(T) the RC8R cooler has two(2) outlets, one(1) for each cylinder. Would/could anyone make a qualified guess if i just could make an Y-piece from the standard radiator?
Reason is that i don´t need to think about clearence with fully compressed forks.
Mikael
ps: it will be doublefanned.
KTM 530 EXC-R 08
Old 12-22-2010, 06:09 PM   #73
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
Radiator...
Mikael
not that qualified but...
I cant see why you couldn't split off in the front cylinder with an adaptor (T or Y) and continue to the back cylinder and do same for the returns?
Not sure how the RC8 factory routing is but it'll be a tight squeeze on the ADV with the tanks.
looking forward to this
Old 12-22-2010, 06:46 PM   #74
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
just looking at the RC8 cooling schematic and it seems to be just one return coming off the lower thermostat.
The one thing that troubles me a bit is that there's one cold and one hot thermostat maybe its there to keep the engine at same temps through intake/return, or fine tune temps between top and bottom?
Old 12-23-2010, 05:56 AM   #75
K2m
....58....
K2m's Avatar
Oddometer: 2,242
There's a radiator available on EBay
And there is the answer to this problem. You could use a "Y barbed reducer" (Two small pipes into 1 larger pipe)
http://cgi.ebay.co.uk/KTM-RC8-Radiat...item35ae43e6c6
I LOVE THIS PROJECT
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Times are GMT -7.   It's 02:16 AM.
