12-12-2010, 07:02 PM
#16 |
Oddometer: 74
I did the jesse mod on my previous Dr and transferred everything back to stock but the slide piston with the extra hole drilled in it. The throttle seemed to be a bit to abrupt on deceleration. The throttle is very snappy as for as the thottle body spring back is conserned, it just seems to be a little long on deceleration. this bike only had 495miles put on it from oct 08 unil now so no telling what might have a little gum still holding on in the carb. Maybe it will subside once it has some real miles put on it.
12-25-2010, 08:39 PM
#17 |
Oddometer: 1,652
I removed the airbox snorkel and opened up the top.
After much experimenting, including initially making up my own needle from and old FCR needle I had lying about, I got a Dynojet kit from Procycle. Much more experimenting, and this is where I'm at: Main 145 Pilot 37.5 FS 0.875 turns DJ needle 4th clip from bottom drilled slide 800 m Leaner than most, but now working well with no surging and good economy, and pretty clean roll on from a closed throttle. Still no FCR, so I'll do that next. Nevertheless its the best DR650 with BST40 I've tried to date. More of my DR650 stuff if you follow the link in my signature. Steve |
12-25-2010, 08:54 PM
#18 |
Armature speller
Oddometer: 6,769
12-25-2010, 09:07 PM
#19 |
Oddometer: 1,652
Good question, a drilled Mikuni. I have experimented with DJ vs Mikuni and Keihin previously in other bikes and although I'm aware of the supposed differences re approach and departure profiles, they all seem to work pretty much the same for me over the years. All I do is gauge them with my jet drills, and that works for me. I leaned off the main from the supplied DJ jets to my drilled 145 and its leaner, although the 'book' says it should be richer.
A stick of solder and a set of jet drills and you can have most mains to play with. Dunno ![]() Steve |
12-25-2010, 10:16 PM
#20 | |
Armature speller
Oddometer: 6,769
12-25-2010, 11:32 PM
#21 |
Oddometer: 1,652
I had a DJ 150 in it and wanted it a bit leaner. Its the smallest the kit comes with. I found an old Mikuni main in my bits and drilled it to 145 with a drill. It feels leaner than the DJ 150, and gave me what I was after.
I could have soldered up a DJ jet and drilled it out, but I already had the Mikuni jet, so I thought I'd experiment and see what happened. All seat of the pants stuff though, so who knows. I also neglected to add that the pipe comprises a FMF Powerbomb header and Megacycle muffler and tailpipe. Steve |
12-26-2010, 12:18 AM
#22 | |
Armature speller
Oddometer: 6,769
A DJ 155 would be about right with a bit of altitude and/or not much air box cutting. I was running a larger pilot (+2) and pilot air (+1) too. |
02-09-2011, 08:13 AM
#23 |
Butler Maps
Oddometer: 14,431
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
02-09-2011, 11:45 PM
#24 | |
Oddometer: 1,652
Steve |
04-30-2011, 12:19 PM
#25 |
back in the saddle again
Oddometer: 590
Just go my Mikuni BST40SS so-called Carb overhaul kit. Anyway I am looking at the rubber-tipped needle. On other carbs I have overhauled the needle moves up and down with float action. This needle has a pin on the top that moves - it's kinda like a plunger or somthing - when the float moves up and down it just presses on the pin (plunger) and it moves down. The old float pin-needle or whatever you want to call it I removed the pin (plunger) on top does not move at all (of course this may be why it was flooding all the time. Can anyone shed any light on this? I got no instructions with the ProCycle kit.
TheCowboy |
05-01-2011, 04:49 AM
#26 |
Oddometer: 590
Disregard last post - I have fuel in the crankcase - a hole new problem
05-01-2011, 02:02 PM
#27 |
Armature speller
Oddometer: 6,769
05-03-2011, 07:17 AM
#28 |
Buell me
Oddometer: 2,020
DynoJet vs Mikuni mainjet sizing comparison...
05-04-2011, 12:28 AM
#29 |
Inciteful
Oddometer: 412
A/F monitor
Years ago a buddy installed a portable A/F monitor on his flatttracker ATK and was very happy with his tuning result.
The May issue of Motorcycle Consumer News has, on the back cover, a glowing write-up of the NGK Powered AFX Air-Fuel Monitor. Dave Searle at MCN states, "Air-fuel ratios by themselves are not the final answer, but they're close, and from that baseline, additional dyno or stopwatch tuning to totally perfect the setup will require less time and money." My thought, exactly. I'm guessing the tuning arrived at using one of these devices is satisfactory for 98% of DR riders. Reading some of the anguished emails from riders soliciting tuning help makes the $260 cost a cheap investment for mental health. Searle states 13:1 is the optimal A/F ratio for power and cooling on the DR. Lex
The older I get, the better I was. |
05-05-2011, 12:33 AM
#30 |
Armature speller
Oddometer: 6,769
Carb MainJet equivalents...
PHP Code:
