Old 11-11-2010, 05:54 AM   #1
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
DR650SE Index Topic #11- EXHAUST
The factory muffler is not nearly as restrictive as things are on the intake side, but there is some corked-up power to be found by switching mufflers. But often the attraction of swapping exhausts is just as likely to be the weight savings, as the stocker weighs in at nearly 15 pounds.
Please share your exhaust improvements...
-GSXR MUFFLER
-AFTERMARKET MUFFLERS
-HEADER GRIND
-OVERSIZED PIPES
-SPARK ARRESTORS
-POLISHING HEADER
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 11-11-2010, 07:27 AM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
ground header welds & gsxr muffler here.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 11-11-2010, 07:29 AM   #3
monkeyfez
Enabler....
monkeyfez's Avatar
Oddometer: 5,000
ditto. Works great. SOunds nice. Not even a little loud just nice. Much lighter and with the carb/airbox mods made a nice improvement. Also it just looks better than the stocker.
"When the monkey tells you to give it up, give it up." ~ Bubba Satori
monkeyfez is offline   Reply With Quote
Old 11-11-2010, 01:23 PM   #4
GutterTrash
GutterTrash's Avatar
Oddometer: 601
i managed the header grind a couple weeks ago, definently sounds like it breathes better, got a little throatier.
the over-weld was a good 1/4 inch all the way around with a spot where the welds overlapped to about a good 3/8
scored a mis-labeled gsxr1k can last week off fleabay and saving up for the mid kit now,,, unless i can do as good with homemade. might still checkout the home brew route.
GutterTrash is offline   Reply With Quote
Old 11-15-2010, 05:52 PM   #5
ER70S-2
ER70S-2's Avatar
Oddometer: 6,870
Stock exhaust dimensions:
Inlet: ID = 1.4"; OD = 1.51"
Outlet: ID = 1.135"; OD = 1.265"
If they removed the stock inner tube (the one that sticks out about 1/4"), when gutted, that will leave a hole; ID about 1.386"
FMF Model #S9000 Approved Spark Arrestor (thanks to mx_rob)(also available at Dennis Kirk, I think), is 1.650" OD and 3.38" long
For reference the GSXR muffler x40F0x outlet; ID is 1.680"
GSXR install (again thanks to mx-rob):
https://docs.google.com/present/view...c203OWhm&hl=en
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-25-2010, 01:50 PM   #6
mr openroad
Target Fixated
mr openroad's Avatar
Oddometer: 4,105
for the cost the gain in my opinion is not great enough, I just assume put that money into a bigger piston or suspension mods.
mr openroad is offline   Reply With Quote
Old 11-25-2010, 04:45 PM   #7
sandwash
sandwash's Avatar
Oddometer: 1,365
D&D with 2 brothers mid pipe
97dr650
sandwash is offline   Reply With Quote
Old 11-28-2010, 09:01 AM   #8
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Bump
Old 12-09-2010, 01:44 PM   #9
NYTrainer
NYTrainer's Avatar
Oddometer: 145
DR 650 Intake/Exhaust Mods
The bike had the Dynojet carb kit & cut airbox when I bought it.
I added K& N Filter, FMF Q4 Muffler W Powerbomb Header.
Big savings in weight & improved power, but a little loud!
NYTrainer is offline   Reply With Quote
Old 12-09-2010, 05:02 PM   #10
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,887
gsxr-1000 TI can
a bit vocal for me, but hard to hush a big thumper without killing it
plugeye is offline   Reply With Quote
Old 12-24-2010, 08:55 PM   #11
ER70S-2
ER70S-2's Avatar
Oddometer: 6,870
Eek Exhaust Header Glowing Red
http://www.advrider.com/forums/showthread.php?t=621819
http://www.advrider.com/forums/showp...ostcount=46996
2013 WR250R
ER70S-2 screwed with this post 04-04-2011 at 12:38 PM
Old 12-26-2010, 02:56 AM   #12
rivercreep
Oddometer: 3,243
I'm using a cheap CZR pipe for the winter so it can take the beating from the salt instead of the stocker.
Really too loud for my tastes but, it's not like I'm off-roading the thing in the winter (more commuting). F.W.I.W. Since I had already rejetted for the air-box mod she really came alive all over the rev-range. What's really funny is that even after re-gearing 4 teeth bigger on the rear, my mileage has stayed the same with an avg. of 54mpg.
This spring I'll be looking into the 2-bros pipe with the added noise restrictor. (I've really grown to like the big singles sound...just not quite this loud)
rivercreep is offline   Reply With Quote
Old 12-26-2010, 08:08 AM   #13
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,000
Careful!
Sometimes these changes come at the expense of loss of bottom end power which on a DR is a no no. You can easily gain top end and drop a little weight get more noise which you think means more power but lose that precious bottom end. Fine idea on a sreet bike but lousy on a dualsport. You usually end up losing gas milage too. So be very careful with so called power mods.
RED CAT is offline   Reply With Quote
Old 01-04-2011, 09:59 AM   #14
sandwash
sandwash's Avatar
Oddometer: 1,365
Thats not going to happen with this bike,but hey the pumper carb will take care of that.
97dr650
Old 01-10-2011, 07:24 PM   #15
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
2001-2003 GSXR muffler, with the modified Two Brothers mid-pipe as sold by Kientech (it includes muffler gasket and mounting hardware).
OEM header pipe, after an evening with a wire wheel, emery cloth, steel wool, cotton buffing wheel, Autosol metal polishing cream, and lots of elbow grease.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Times are GMT -7.   It's 03:12 AM.
