Old 10-31-2006, 08:50 AM   #61
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,314
Originally Posted by rdcyclist
...the Audiovox unit has an upper limit on VSS pulses/mile of 8k.
The GS sensor is probably around 80k per mile. Not even close!!
AntonLargiader is online now   Reply With Quote
Old 10-31-2006, 07:10 PM   #62
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,213
As I recall, the groove only wraps around the front of the twist grip tube. I suppose if you could make a housing cover with a return cable provision and the tube was groovy enough then a push-pull throttle system could be retrofitted.
This issue irritated me to no end since the Bowden cable box was set up for the return cable but the throttle assembly didn't have any way to make it work. Seems stupid to me...
What about the possibility of just eliminating the BMW throttle grip assembly and buy something designed for a "pure" dirt bike and butting it up against the switchgear on the right grip? I've seen some pretty compact ones but never looked really closely. Definitely though they were double cable.
As a side note there are some cables made for push/pull work but they're heavy thick and expensive. Doubt they'd make for a good solution. I've never had a return ability in my cars and trucks so I wouldn't worry too much about that part.
Riding season is finally getting in gear!<br><br>Pat<br>aka Geeeze
daGeeeze is offline   Reply With Quote
Old 10-31-2006, 09:08 PM   #63
Crilly
Oddometer: 795
The reason I asked about it turning off going down hill is because some of the new bikes turn off the ignition when the throttle is closed. But by the poping of the GS i guess they do not. My Buell and V-rod would shut the cruse control off. Thats is why I went with the proxcimity switch.
Crilly is offline   Reply With Quote
Old 11-12-2006, 08:29 PM   #64
rprade
rprade's Avatar
Oddometer: 65
I know I am late on this thread, but I m working on a cruise control for my K1200S and will be on my soon delivered R1200GSA. I chose the Rostra electronic cruise control to avoid the need for a vacuum accumulator for a vacuum actuator. The K1200S and the R1200GS have a connector near the front of the bike for connection to the GPS accessory. This connector has three wires:
Brown = ground (pin 1)
Blue/Green = TAA (pin 2)
Red/White = switched power (pin 3)
I will be hanging a scope off of the TAA lead next weekend, but I am fairly sure it is a conditioned speed pulse from the ZFE (chassis control module). This would be used by a GPS employing dead reckoning, not currently used by BMW. The Rostra unit also looks at an engine tach pulse and disengages the cruise control in the event of throttle runaway.
The Rostra has all of the electronics and a throttle servo in one module and can be purchased for about $200. Here is a link to Rostra controls website.
Randy Prade
Aurora, CO
Alaska - Arctic Circle 2007
Experience is a hard teacher because she gives the test first, the lesson afterwards.
rprade is offline   Reply With Quote
Old 11-12-2006, 08:47 PM   #65
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,144
This thread has HoW written all over it...
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 11-13-2006, 03:40 AM   #66
AntonLargiader
Oddometer: 4,314
Yes indeed, TAA is a conditioned speed signal. I hadn't realized it was there on the earlier Hexheads but it is. The GS should have it as well.
Old 11-13-2006, 08:40 AM   #67
daGeeeze
Geeezed lightning
daGeeeze's Avatar
Oddometer: 2,213
sweet. I'd heard about this but hadn't see details.
Great news. Plus I also have that unit already; just no time to install it or expiriment with it. Any plans on cable handling?
Thanks and keep us posted please!
Old 11-13-2006, 10:29 AM   #68
rprade
rprade's Avatar
Oddometer: 65
My GS won't be here until the end of the month, but I am starting on the K1200S this weekend. That will allow me to resolve some of the issues such as interfacing the brake (and clutch, if possible), power, tach pulse, and control switching. Hopefully resolving those issues will make the install on the GS a little easier.
For cable handling, I am going to look at parts data tomorrow and see what can be done to turn the GS throttle cable splitter into one like the RT uses. I am hopeful that the parts can be ordered to convert the GS splitter. I will not try to add the second cable back up to the throttle grip, but would like to interface the cruise servo to the cable splitter in the same fashion as on the RT.
Randy Prade
Aurora, CO
Old 11-13-2006, 01:39 PM   #69
bonox OP
Tryin Hard
Oddometer: 2,998
bonox is offline   Reply With Quote
Old 04-28-2008, 08:44 AM   #70
lemonhart
Oddometer: 31
Audio Vox cruise control install
I am in the middle of installing a AudioVox ccs 100 and and was wondering.
Did anyone ever come up with a definitive answer as to whether this does in fact work as a VSS signal for the cruise control?
Also if it works does that mean you don't need to tap into the coil and if you still do where is the best place to do it?
TIA
lemonhart is offline   Reply With Quote
Old 04-28-2008, 05:06 PM   #71
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
It looks like the VR sensor is too 'fast' for the Audiovox. Go for seeing about using the TAA signal.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 12-29-2010, 01:15 AM   #72
kpavey
K12Sman
Oddometer: 5
TAA signal
So did you manage to get the VSS to work with the cruise kit? Has anyone measured the VSS signal, and can characterise it? Square wave, 5V, analogue, with variable pulse width wrt speed?
kpavey is offline   Reply With Quote
Old 12-29-2010, 05:06 PM   #73
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
This is a guess, but it isn't a wild guess. The TAA signal is probably a digital signal, with a variable frequency wrt speed.
In the case of the BMW motos, it is a 'manufactured' signal based on a the sinusoidal signal from Variable Reluctance wheel speed sensor.
Some automobiles use the term VSS to describe the signal from the pickup on the transmission output shaft.
With a couple of different checks with a good digital meter you can probably get a good enough 'picture' of the signal to know if it will work with the cruise control.
Old 03-15-2011, 11:21 AM   #74
dede
Lefty
dede's Avatar
Oddometer: 162
[/QUOTE]
Poolside; Please describe in layman's terms the tests you refure to here, I have the unit hooked up and passing the testing cycle but don't know how to check the pulse count. I am using the three prong plug under the beak on a 2009 GS as described in a nearlier post with a Rostra CC. I need the pulse count to set the dip switches to the proper range. The only reading I get with a digital meter set to VDC is 12V.
The democracy will cease to exist when you take away from those who are
willing to work and give to those who would not. Thomas Jefferson
dede is offline   Reply With Quote
Old 03-15-2011, 12:33 PM   #75
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
We'll give it a try.
First, I have no idea what "passing the testing cycle" might mean.
What does the meter read on VAC with the wheel spinning?
Most digital meters have a frequency counter, does your meter have one?
Times are GMT -7.   It's 08:00 AM.
