Old 01-06-2011, 12:37 PM   #31
Brauhausbier OP
Searching for IPA
Brauhausbier's Avatar
Oddometer: 1,356
Originally Posted by mcma111 View Post
Boy, that's about $60.00 to $135.00 more than the guy near me charges for an XR frame and bits. Side stand, peg mount, etc.
Thanks Steve. I'll keep hunting around. I'm still getting a frame of reference on powdercoating Cheers!
Brauhausbier screwed with this post 01-07-2011 at 01:43 PM
Brauhausbier is offline   Reply With Quote
Old 01-06-2011, 02:50 PM   #32
WB-PDX
WB-PDX's Avatar
Oddometer: 3,557
Originally Posted by Garthe View Post
Isn't that a lot ($ 1,500) to spend on a XR 600 R that looks like that and you have to tear it apart and rebuild it from the ground up.
The bike came with $500 (used parts value) worth of uninstalled 'extras', a plate with brand new tags, and a BD kit with all the fixings - It was a good value in any location.
I know the bike *looks* stock in the pictures, but the list of parts\mods the bike had when sold is massive.
There's also no reason anyone 'had' to tear that bike apart.
WB-PDX screwed with this post 01-06-2011 at 03:28 PM
WB-PDX is offline   Reply With Quote
Old 01-06-2011, 03:39 PM   #33
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
I still feel good about the deal. I'm not complaining. I was looking for a cheap XR that I could rebuild. I must be going through that mid-life crisis that I was hearing about...adding more projects into one's life must be a sign.
You have to admit wade, that bike had not been cleaned in years
Old 01-06-2011, 03:52 PM   #34
WB-PDX
WB-PDX's Avatar
Oddometer: 3,557
I hosed it off, sprayed it with cleaner, then hosed it again, and wiped it down after every ride.
Old 01-06-2011, 03:53 PM   #35
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
no worries..every part will get shiny once again
Old 01-06-2011, 04:05 PM   #36
Dino3310
Oddometer: 625
Send a message via MSN to Dino3310
i thought it was a good deal for the buyer, you would pay a shit load more over here for one so 1500us would be a steal for me
Dino3310 is offline   Reply With Quote
Old 01-06-2011, 04:51 PM   #37
mcma111
mcma111's Avatar
Oddometer: 8,008
Ya get better results if you give it a little hand work. You know, a brush or a sponge. Works wonders on that sticky mud. Eh?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-07-2011, 10:42 AM   #38
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 8,608
Super ! ! ! Another thread to follow during these cold winter months. I enjoy seeing what you guys are up to even though I'm doing good to know the difference between a screw driver and a hammer. Maybe if I follow enough of these I will absorb something.
Subscribed.
2013 Hells Canyon/Wallowa Valley Gathering: http://www.advrider.com/forums/showthread.php?t=843668
"Always be a first-rate version of yourself, instead of a second-rate version of somebody else." - Judy Garland
Ladybug0048 is offline   Reply With Quote
Old 01-10-2011, 03:50 PM   #39
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,135
If "more projects" means one is having a mid life crisis, my mid life crisis is the most project-loaded one in history!
See post #88:
http://advrider.com/forums/showthrea...=464630&page=6
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 01-16-2011, 02:12 PM   #40
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
High freezing levels on Mt Hood = no snowboarding this weekend (rain at 10K feet).
But another free day for the XR rebuild project. This is keeping me busy in mid winter
Had the grateful help of our resident PDX airline pilot FlyJosh yesterday to help me finish stripping down the XR to the frame and get the top end off the motor
Rear Swing Arm Removal
This XR is grimy, oily, and just plain caked with layers of grease and road grime
However...not one bolt was over torqued or rusted together I was amazed.
Old 01-16-2011, 02:26 PM   #41
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Next up Headers - extra crispy
Steering Head - the breaking bar I picked up recently for doing a valve adjustment on my KTM950 is really coming in handy today Picked up a 30mm socket last night just for this job. Glad I did
Stem Bearings and races look damn good!
Question for those XR folks out there...I'm concerned by the play of the front sprocket on the spline. There is some forward and rear play of the sprocket on the spline. Not sure if this is typical, or if the sprocket is worn, or the spline is worn? Here are a couple of pics to show the play:
Old 01-16-2011, 02:45 PM   #42
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Now on to the motor - first up valve cover removal
Check out how bright and shiny the inside of the motor is
Cam Chain Tensioner
Hot Cam looks in very good shape
Cam Journals look good
Removing head
Head is off!
Piston looks original and is a 97mm (a bit worn at 96.7mm)
Valves appear to be in good shape
Old 01-16-2011, 03:14 PM   #43
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Needed to make a tool run to Harbor Freight to remove the cylinder base..I did not have any rubber mallets. Brought back a one and a two pound rubber mallet for this job (and some fresh JB weld-FlyJosh took a hammer to the fins on the cylinder while I wasn't looking and snapped off a corner. I'm going to see if I can JB weld that corner back on at some point).
Success! The two pound mallet did the trick! Found the tip on TT! Hit from underneath in an upwards motion. One good blow and that did the trick! (see the missing fin corner from Flyjosh's hammer)
Sleeve looks amazing just like the rest of the internals
Ughhhhh.....got the motor off the frame
For the final push for tonight my wife Debbie joined me in cleaning up the frame. I hope to get the frame and a few parts into the paint shop this week
Looking ready for the paint shop
This week - get frame and parts to a paint shop (prep and powdercoat), order new 100mm JE Piston and sleeve, make an appointment at RB Designs www.rb-designs.com for a re-sleve and valve job, and hopefully pick up the suspension from Promotion Suspension this week www.promotionsuspension.com. This should keep me busy.. Cheers!
Old 01-16-2011, 07:54 PM   #44
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 9,842
Some (not much) play is normal, but if you have a too-hard aftermarket sprocket you could end up with this:
If your splines are straight you're good, but I recommend running only OEM front sprockets.
I have be running aftermarket fronts on my XL500 since 1979 with no ill effects, but as you can see in the pic, my XR600 was not so lucky.
I will buy no more aftermarket front sprockets.
Edit: I see you have the finer spline. I don't know whether play of any amount is normal on that model, but still, any damage should plainly show. And, I would still use only OEM sprockets.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 01-16-2011 at 08:37 PM
MortimerSickle is online now   Reply With Quote
Old 01-16-2011, 08:32 PM   #45
flyjosh
Stave It Off!!!
flyjosh's Avatar
Oddometer: 249
That engine was beautiful.
And that chipped fin gives it some street cred
Joshua, the Inuit hater
2001 KLR650...I think I got the slow one.
1972 F6 (gone)
flyjosh is offline   Reply With Quote
Times are GMT -7.   It's 01:19 PM.
