Old 01-08-2011, 10:42 PM   #1
cyborg OP
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,263
Shorai battery for KTM990/LC8
I didn't find many pictures of the new Shorai battery alternative for the LC8 in OC so I thought I'd post my install.
Shorai is a new company in the US. I met the President of Shorai USA, David Radford, at the Seattle Motorcycle Show this year. The batteries looked amazing, and so light I thought they were just demo cases with nothing in them, but David said no, they were the real thing.
Read up here:
http://www.shoraipower.com/
I got one for my 2007 KTM 990S. The original lead acid battery was finally dying and I needed a new one. I wanted to try something new and these appeared just in time. I decided to give this new Lithium Iron Phosphate battery technolgy a try.
I chose the LFX18A1-BS12. It came in a box with a selection of sticky-one-side foam strips to help it fit the usually larger space the OEM battery took. You have to trim to whatever fit you want
Here is a physical comparison of the
OEM 8.6lb Lead/Acid v.s. 2.12lb Shorai (6.48lb difference)
weighed on my digital postage scale at home, not a lab test scale.
Front
Side
Top
I trimmed a few foam pieces and installed in the sides of the rubber OEM battery base
Then installed the battery in the rubber base
and installed in the bike. Note the foam strip I used in the top lid of the battery box to help hold the little Shorai battery in place.
That's it. Quick and easy install.
I topped off the battery with a Shorai approved Battery Tender
or
Then came the test. WOW! It cranks the bike with serious authority easily as good or better than the OEM Yuasa lead/acid, even at 30F in my garage. Bike fired right up first crank. At real cold temps, the first cranking cycle may seem slow, but it heats the battery internally (a good thing) and 2nd crank cycle and after will be full force. I was impressed. Tried half a dozen starts after the first one and it spun the bike over quick every time!
Happy customer so far.
Now for the long term testing with my all year, all season commuting and trips, heated gear, etc...
BTW, I got mine at the first local biz to get them in the Seattle area, I was anxious They also offer an ADVrider discount.
http://www.advmachines.com/category_s/77.htm
other stocking dealers listed here:
http://www.shoraipower.com/t-shorai-dealers.aspx
cyborg screwed with this post 01-21-2011 at 10:47 AM
cyborg is offline   Reply With Quote
Old 01-08-2011, 11:08 PM   #2
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,853
Thumb
Thanks for the pics and write up. I am in the market for a new battery too. How much are they?
"Experience alone is not the great teacher; Experience has to be multiplied by intelligence to yield sustained progress." Phil Schilling
Deuce is offline   Reply With Quote
Old 01-08-2011, 11:14 PM   #3
cyborg OP
cyborg's Avatar
Oddometer: 5,263
Don't know for Canada, got mine in WA here:
This link has prices. They are in Bellingham, close to the border
Old 01-09-2011, 12:36 AM   #4
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,853
Thumb
Fair price as far as I can tell. I will give Alternate Cycle in Kamloops a shout. He seems to be the only dealer in Canuckistan so far. Cheers
Old 01-09-2011, 06:54 AM   #5
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
very cool cyborg. i just bought the same battery from cj. looks like the install was a piece of cake. did you have to do anything funky with the connections? or did they land right on the posts?
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 01-09-2011, 12:27 PM   #6
cyborg OP
cyborg's Avatar
Oddometer: 5,263
The Shorai sits about a 1/2 inch further inwards than OEM in my install but the cables had no problems connecting.
Old 01-09-2011, 02:46 PM   #7
proeasy
Oddometer: 359
These guys had a booth/display at the Motorcycle Show this weekend in Detroit (Novi) Amazing how light it was compared to lead acid.
Will be interesting to follow field performance
Paul
proeasy is offline   Reply With Quote
Old 01-10-2011, 12:47 AM   #8
motorzen
Internet Antagonist
motorzen's Avatar
Oddometer: 114
motorzen likes this!
Thanks for the writeup cyborg! Good info.
If I can get my 6 month old "batteries plus" battery going, I'm gonna ride up to bellyham to grab one of these.
KIVA.ORG TEAM ADVrider >>> Motorcyclists helping motorcyclists with microloans around the world
motorzen is offline   Reply With Quote
Old 01-10-2011, 06:58 AM   #9
hilslamer
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,786
Good post, thanks...I was goin got do this but have been too distracted with other stuff. Looking forward to seeing how all of these batteries last or work int he longer run...I would gladly buy one a tthe same rate the lead-acid batteries have died on me just on account of the starting and reserve power, not to mention the weight savings.
Cheers!
hilslamer is offline   Reply With Quote
Old 01-10-2011, 10:15 PM   #10
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
Worth the weight? Hopefully...
Thank you for taking the time to provide the comparison and details of the simple install. Like others, I too will be interested in seeing how this battery holds up over time. The weight savings seems substantial, even though to begin with that mass is already about as low as it can get on the bike. Should help with pulling off those nac-nacs a little quicker now!
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 01-11-2011, 12:30 PM   #11
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 539
Cyborg,
+1 on the excellent write up and pics. Good Job
I have the TurnTech 5.0 Amp Hour battery which is I believe a similar type battery in my 450 2008 xcrw. The battery is about a year old and has never fail except once. I was riding with lights on, fan going and stopped by a sheriff. I left the lights on for a few minutes, trying to be a nice safe guy. It would not electric start but kicked right over with the Ol' foot. Since then I think 5ah is a little low.
Question: your bat Cyborg is a LFx18A1-BS12. Is it is a 18Amp Hour? I should call the company but Just wondering out loud?If so that would be great for my 990.
KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 01-11-2011, 03:07 PM   #12
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
KJ
Yes, That's what the "18" stands for in there Part number system.
Great write up Cliff.
We're stocking these and getting all our 950/990's setup w/ these for this season's trips. Can't wait to get back to Moab in March.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 01-12-2011, 01:03 AM   #13
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,202
Are you sure ? I thought they were BS12 - 12Ah batteries. 18Ah is way over kill, no ?
edit : just checked their website and found that you were indeed correct. BS12 = 12V. Sorry for that.
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 01-16-2011, 10:31 PM   #14
cyborg OP
cyborg's Avatar
Oddometer: 5,263
The more Ah the merrier when you run extra loads like heated gear & grips or you forget the GPS on when the bike is off . I'm sure a lesser Ah version would work just as well in terms of starting the bike. The Ah doesn't relate as much to starting, just longer term drawdown if your alternator is not quite keeping up. The cranking amps is what is of more concern for spinning the starter quick. You can go way overkill on cold cranking amps if the bike say only uses 200CCA peak and you get a 480CCA battery. The system can't use/doesn't need that much current. I don't know what my 990S uses peak, but the OEM Yuasa is 190CCA IIRC and the Shorai spins the bike harder and faster than the lead/acid Yuasa so I don't think I need much more.
Old 01-20-2011, 05:07 AM   #15
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,215
Older bike compatibility?
Never mind - followed linky to Shorai site and getting a yes to part number!
Any of you EE types have thoughts on working with an older scoot?
This one needs new battery -
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen screwed with this post 01-20-2011 at 05:14 AM
Sutherngintelmen is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
